Are you frustrated by doing same conversion process from OST to PST with different software available in the market, I would like to refer you a software ATS OST to PST converter which is designed by professional and its simple interface will amaze you, also it gives you an option of splitting file if your PST file is very large in size so you can break it into smaller PST files. The best thing is that it support Office 365 and is able to export OST files directly into Live Exchange server.
Read more information:   https://gallery.technet.microsoft.com/office/Exchange-OST-to-PST-12f7656a
Through PDS OST to PST converter application you can repair damage or corrupted OST File and also recover single & multiple emails in safe manner. It converts OST File into PST File and some other formats such as: - EML, HTML, MSG, MBOX and PDF with all emails properties like as (To, CC, BCC Subject, Date Time) including attachments/ zip attachments/ contacts/ calendars/  images/ videos/ appointments etc/. It split large PST File into small PST File 1 GB to 5 GB. Thereby this technology user can re-open OST File in safe mode. Software works on all MS outlook version from: - 97 to 2016.
Read More Information about This Software :-  OST to PST Converter
I would also like to suggest here another very proficient and comprehensive OST to PST conversion software, which can easily repair corrupt OST and convert them in PST formats without facing any issues. The software also provides an option to recover lost or inaccessible Outlook mailbox items from corrupted OST file. For more, visit: https://www.convertosttopstfree.org/en/
For best performance in OST to PST conversion, you must try vMail OST to PST converter software. You can easily convert outlook OST file to PST format as well as MBOX, MSG, EML, vCard, vCal & EMLX format without any data loss. vMail OST to PST converter tool supports Microsoft Office 2000, 2003, 2007, 2010, 2013 & 2016 Outlook OST file in Windows XP, 7, 8, 8.1 & 10. Read more- https://goo.gl/j2386W
Try demo version of the software and convert 30 items per folder for free with the preview of the data.
Download Now
Just go and use SysInspire OST to PST Converter software for complete solution and helps to find all problems to regain and convert OST to PST file along with emails, calendars, contacts, notes, task and all other item folders. Exchange OST to PST Converter tool take amazing power for convert OST file to multiple formats such as PST, EMLX, EML, HTML, MSG MBOX, vCard and other formats. First rate SysInspire OST to PST program consent to users for recover selected items from Exchange OST Mailbox and preserve OST emails layout, emails properties- bcc, to, cc, subjects, time and from.
Know more - http://www.sysinspire.com/ost-to-pst-converter/
Conversion of OST file to PST format, you can use effective and reliable manual solution. The solution convert OST file data along with whole corrupted Outlook OST email items such as - Inbox, Outbox, Sent Mail, Note, Task, Journals and Draft etc. It can also support both normal and corrupted OST file and give the output according your requirement.
Get more details about manual solution visit here:- http://migrateemails.com/convert-ost-to-pst-format/
