margrethevestager
OST to PST Converter
if you don’t have technical skills to recover your damaged data, it might be a critical issue for you, in this I like to suggest a third party tool and I am using ATS OST to PST converter for a long time, I purchased it because it support all the version of MS Outlook from 97, 98, 2000, 2002, 2003, up to 2016 and apart from this it also support office 365 and Live Exchange server.
Get more details:   https://gallery.technet.microsoft.com/office/Exchange-OST-to-PST-12f7656a
With a comprehensive and secure OST to PST conversion software, one can easily repair corrupt OST file and convert them in PST formats within few clicks. You can also try it to recover lost or inaccessible Outlook mailbox items. To know more about the tool, visit:
PDS OST to PST converter is best option if you are searching tool for converting OST to PST file. It can convert your single and multiple mailbox emails, attachments, inbox, journals, tasks, outbox, notes (to, cc, bcc, date, subject and time) into PST, EML, MSG, HTML, PDF and MBOX without creating any frenzy situations. This application can recover your deleted folder files in few clicks .it supports Microsoft Outlook versions from 97 to 2016.
Read More: http://www.perfectdatasolutions.com/convert-ost-to-pst.html
OST to PST Converter can easily convert a large number of OST file into PST file with single go. It has the capability to convert several large OST file into PST file with accurate message formats. If your OST file got corrupted due to some virus attack you never have to worry about the loss of data. This OST to PST Converter accurately converts all information contained in your OST files and folders into PST file and other new formats like PST, MSG, DBX, EML, MBOX & Archive.
Download free version of this software, here:- http://www.migrateemails.com/convert-ost-to-pst-format/
Sysinfosoft OST to PST Converter tool is providing a complete solution to convert OST to PST, EML and MSG format. This tool also lets users migrate OST to Office 365, and Live Exchange server. It also allows users to save OST data into HTML, RTF, Cal, vCal, and vCard format. This tool has a free trial version and a good technical support team as well.
Read More: http://www.sysinfosoft.com/ost-to-pst-converter.html
OST to PST conversion is possible in manual way, if we access exchange server. But if you are not able to approach it then we have only single solution that is third party tool. MailsDaddy OST to PST converter is a prominent and effective program to convert OST file into PST file format. It is very fast export OST file into PST as well as it also convert orphaned and corrupted OST file. After the conversion it holds data infrastructure, Rich text formatting and Meta data from beginning to end.
Smart features of this OST to PST converter
  • Quick scanning process
  •  Recovers emails, contacts, tasks and calendars.
  •  Complete preview of OST file data with attachments.
  •  Allows splitting converted PST files into required size of data files.
  •  Quickly export OST to PST, EML, MSG and MBOX file formats..
  •  Supports all MS Outlook older and earlier editions.
you can Convert OST to PST Manually. This method is used to convert OST file into PST Outlook file with emails, contacts, calendars, task, notes, inbox items, outbox items, and other folders.
Note: When you feel It is lengthy method then you must try an expert method.
For best and reliable method you should use expert Online OST to PST Converter tool. By using OST to PST software, you can easily convert ost file into PST as well as export corrupt OST file into PST format.
