KNRover Posted February 26, 2018 Report Share Posted February 26, 2018 I have noticed for some time now that Run commands I enter (e.g., %temp%, services.msc, regedit, etc.) are wiped out when WRC is run. I can find no setting that tells it NOT to delete these. Is there some way to prevent the program from deleting Run commands? Megangob, FortopR, AnthonyPoelf and 15 others 18 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 27, 2018 Report Share Posted February 27, 2018 You can unchecked this entry: User MRU lists. Or, you can add this to exclusion list HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU\, then wise registry cleaner will not clean Run Command hisstory. Link to comment Share on other sites More sharing options...
KNRover Posted February 27, 2018 Author Report Share Posted February 27, 2018 Having to uncheck "User MRU Lists" every time WRC is run would be a pain, and not remembering to do it one time would wipe out all Run commands. However, I entered the registry entry exclusion, and that works perfectly! Thanks. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 28, 2018 Report Share Posted February 28, 2018 You are welcome! Link to comment Share on other sites More sharing options...
