OST to PST Converter
ATS OST to PST Converter OST to PST Export OST to PST Converter Convert OST to PST
  • Please log in to reply
2 replies to this topic
#1 warnersina
warnersina
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 12 February 2018 - 10:08 AM
Recover your Outlook OST mailbox with the help of ATS OST to PST converter. According to the user feedback it is working excellently and providing desired results, you just need to download it and follow the step by step process, it will take a few minutes after that it is ready to use, I would recommend you to download its trial version which enables you to access your 30 email items of each folder helps you to take decision whether it matches with your needs or not.
Read more info:    OST to PST Converter
#2 mikeswan
mikeswan
    Member
  • Members
  • PipPip
  • 19 posts
Posted 12 February 2018 - 11:41 AM
OST to PST Converter repairs corrupt OST file and successfully open OST file into new or existing PST format. Also, it retrieves orphaned OST emails with all email attachments, and properties then convert into multiple readable formats - PST, MSG, DBX, EML, TEXT and HTML file. This software works on all supported versions of Exchange Server 5.0/5.5/2000/2003/2007/2010/2013/2016.
Download demo - http://www.convertosttopstfree.org/
#3 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 13 February 2018 - 06:54 AM
Specifically programmed to provide instant results, OST to PST Converter extracts all the unreadable items in the accessible and readable offline storage files. As the name suggests, it actually extracts the inaccessible and orphaned OST and recovers all the mailbox items into PST file format. With its innovative GUI, the tool is user-friendly and makes the conversion process a lot smoother.It can recovers PST, EML, MSG and DBX emails and make them easy accessible for Outlook Express and MS Outlook.Recommended to use 100% Free Trial version, will see you the preview of recovered or Converted Emails.
Also tagged with one or more of these keywords: ATS OST to PST Converter, OST to PST, Export OST to PST Converter, Convert OST to PST
