OST to PST Converter
ATS OST to PST Converter OST to PST Convert OST to PST Free Download OST to PST Exchange OST to PST Converter
  • Please log in to reply
7 replies to this topic
#1 warnersina
warnersina
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 09 February 2018 - 08:09 AM
Converting Outlook OST file into PST is the biggest concerns for that person whose precious data is saved in outlook mailbox like Emails, contact, calendar, journal task, drafts, notes, deleted items, and attachment etc. ATS OST to PST converter can give you relief because it converts data without any alteration in old saved data.
Read more details:    https://gallery.tech...r-Free-4a69504c
#2 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 67 posts
Posted 13 February 2018 - 07:02 AM
One of my colleagues recommended me to try OST  to PST Converter tool and I was a bit skeptical using such type of tools. This tool convert my OST file to PST in just 2 minutes. Thank you very much because it saved my data and cleared all my doubts.This has interactive GUI feature which makes the scan for OST files easy and helps you to select the one you need to convert into PST file.The evaluation version is free of cost which enables you to know what is stored inside the tool.
#3 JamesStewart250
JamesStewart250
    Member
  • Members
  • PipPip
  • 23 posts
Posted 13 February 2018 - 07:27 AM
Export OST to PST, a secure and the most reliable third party software, capable to convert unlimited mailboxes from OST to PST in a single attempt. Users can also convert OST mailbox data into various other email formats, including EML, MSG, MBOX and DBX.
Free demo version of the software is also available to download at- http://www.exportost....ost2pstexe.net
#4 luciferr
luciferr
    Advanced Member
  • Members
  • PipPipPip
  • 69 posts
Posted 30 March 2018 - 12:23 PM
Try Dynamic Stella Data Recovery OST to PST Recovery software
#5 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 64 posts
Posted 31 March 2018 - 07:35 AM
Using the PDS OST to PST Converter all OST File users can easily repair corrupt or damage OST File data and recover unlimited OST File size in well safe mode. It converts OST File into PST File and more other formats like as: - EML, HTML, MSG, MBOX and PDF with all emails properties like as: - (To, CC, BCC, Subject Date and Time) including all attachments/ zip attachments/ journals/ contacts/ calendars/ images/ videos/ appointments etc/. It split large PST File into small PST File 1 GB to 5 GB. It gives you naming convention option to save your data from “+ subject date, subject date, from”. It access OST File in readable mode.
Read More Information about This Software :-  OST to PST Converter
#6 jamon99
jamon99
    Advanced Member
  • Members
  • PipPipPip
  • 72 posts
Posted 04 May 2018 - 09:04 AM
Try free OST converter tool to export OST to PST format. The OST to PST converter not only helps you in migrating OST data into PST format, it will also help you in repairing damaged OST file of Outlook 2016, 2013 & all below versions. Visit for more info : http://www.datavare....ter-expert.html
#7 alexaa
alexaa
    Member
  • Members
  • PipPip
  • 28 posts
Posted 05 May 2018 - 09:44 AM
Download the wonderful eSoftTools OST to PST Conversion Software which is good in case of conversion OST File data into PST Outlook file, EML, MSG, HTML, EMLX, MBOX and vCard format. Outlook OST to PST Software allows users convert selective single and multiple folders from OST File and restore all OST file data included- emails, contacts, calendars, task, notes, inbox items, outbox items and appointments. OST to PST Recovery Software successfully recover deleted folders items and maintains folders hierarchy. While conversion it also facilities to convert database to PST Outlook file without creating any problem.
get more info:- http://www.esofttool...topstconverter/
#8 calorina
calorina
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 05 May 2018 - 11:39 AM
For the best OST to PST Converter, user need to download VOOK OST to PST Converter tool. It allows users to convert entire data without any problem. It is so easy to use and provides user to set their desired location of the converted file. It is the best approach through which users can easily get their best results without doing efforts
Also tagged with one or more of these keywords: ATS OST to PST Converter, OST to PST, Convert OST to PST, Free Download OST to PST, Exchange OST to PST Converter
