EDB to PST Converter
edb to pst edb to pst converter edb to pst recovery
  • Please log in to reply
3 replies to this topic
#1 abrilnathan
abrilnathan
    Member
  • Members
  • PipPip
  • 14 posts
Posted 03 February 2018 - 12:08 PM
eSoftTools EDB to PST Recovery is the best and safe to use application that easily recover data from inaccessible exchange EDB file and convert EDB file to PST Outlook file without difficulty. By taking help of EDB to PST converter Software you can recover selective single and multiple mailboxes from Exchange file and restore them into PST, EML, MSG and HTML format.
Get Details: https://www.trepup.c...dbtopstrecovery
#2 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 05 February 2018 - 04:21 AM
When it comes to convert the corrupted EDB files to PST, Exchange EDB Recovery plays a very significant role.This tool helps the user to extract the mailbox from damaged EDB file and save it to new PST to easily access from the outlook.This also proves to be beneficial for the user as it recovers file from the backup of EDB and saves it in PST format.The software enables quick search to generate the required mails into the new PST format.To convert EDB to PST, all you need to perform three simple steps:
  • Download and install free trial version of Exchange EDB to PST Converter
  • Browse and Select the EDB file and then recover data
  • Restore the data in new PST file
#3 John11
John11
    Advanced Member
  • Members
  • PipPipPip
  • 72 posts
Posted 05 February 2018 - 05:08 AM
Use the Microsoft free utility ExMerge.exe for the conversion of EDB file into PST format. This utility recovers emails from corrupted as well as normal EDB file. If you already use this tool and still facing problem, then try another manual technique. PowerShell Command Line Tool is another solution to convert EDB to PST. But this tool requires good knowledge of PowerShell Command Line Tool.
Read more information here:  Manual method of EDB file into PST format
#4 luciferr
luciferr
    Advanced Member
  • Members
  • PipPipPip
  • 30 posts
Posted 12 February 2018 - 12:45 PM
Stella have gives you better solution for quickly recover EDB file database and the solution is best Exchange EDB to PST converter software that deeply scan exchange EDB file data and convert EDB emails data into working PST outlook with some other format like as:- EML/MSG/HTML and MBOX after that it open exchange EDB emails into working MS outlook with its E-mails properties like as:- to/bcc/cc/subject/date/from as well as it also support exchange version as:- 5.0/5.5/2000/2003/2007/2010/2013 and 2016.
See more detail:- https://gallery.tech...covery-bd9977aa
Also tagged with one or more of these keywords: edb to pst, edb to pst converter, edb to pst recovery
