Virtual hard disk (.vhd) file may become inaccessible or fail to run on a Virtual system due to corruption. As no computer file is immune to corruption, so as the VHD file.You may lose all your crucial data forever which are saved in your virtual hard disk. The common reasons for corruption in VHD files are: virus infection, bugs attack, abruptly system shutdown, physical storage failure, malfunction virtual machine, transferring files over faulty network, etc.
Whenever a VHD file gets corrupted, you’ll receive error messages on your screen.There are many software are available in the market, you can choose anyone of them. Here comes VHD Recovery Software supports recovery from VHD files created by Microsoft Hyper-V, Microsoft Virtual PC, Microsoft Virtual Server etc.This software has great features and functionalities. And it will give you to full surety for the best access data of the VHD file.
Use Free Trial Version of VHD Data Recovery Utility, In free version you can recover your deleted VHD Data and also repair corrupt VHD file.
Product Link - http://www.pcrecoveryutility.com/vhd-data-recovery.html
VHD Recovery Tool, a secure and reliable third party software, allows its user to recover data from corrupt or inaccessible VHD/VHDX file on a virtual hard disk drive. The software is capable to recover data from a corrupt VHD file created using FAT and NTFS file partition on Windows. For more information about the software, visit- http://www.vhdrecoverytool.com
I would suggest you to try any trusted Software which makes easy to repair VHD files.
Download this free VHD Recovey software and repair or recover damaged, missing files & folders or corrupted VHD files without any data loss.
It is an user-friendly tool and even a non-technical user can easily recover data from FAT, FAT32, NTFS, etc files systems of VHD without any difficulty.
Read more features & download free software from - https://gallery.technet.microsoft.com/Free-VHD-Recovery-to-0cbdeb7d
Hello,
If your VHD file is corrupted and damaged and if you want to recover the data from highly corrupted VHD files then you can try Hyper-V recovery software This helps to recover the data from the corrupted VHD files in just few clicks. This software helps to retrieve the healthy VHD file data. The user can recover any size VHD file data. This software allows to recover the data from FAT and NTFS file system. Data recovery is also possible from Dynamic and static Hyper- V VHD files.
Read more amazing features and download Hyper-V recovery software
Thanks and Regards
Andrew Manson
To recover data from corrupt or inaccessible VHD/VHDX file of a virtual hard disk, I would like to refer a powerful and secure third party software, Kernel for VHD recovery. The software is designed by using an advanced algorithm, which help users to recover complete data with ease. It is the most simple, secure and accurate VHD file recovery software. For more information, go to- https://www.kerneldatarecovery.com/virtual-disk-recovery.html
Hello
if you want to repair your Virtual Hard disk file then I found an informative article for you. Which explains how to repair VHD file. Here is the link https://gallery.technet.microsoft.com/recover-data-from-vmdk-file-b3c8fec1 . In case if you are unable to perform this process with the help of manual method then the user can prefer an efficient  VHD Recovery software. This software is built with strong and powerful algorithms which can easily recover data from Virtual hard disk file efficiently. The user can easily recover most crucial data such as important documents, database files, videos, images etc. VHD recovery software can easily recover the data from the dynamic and static virtual hard disk file of FAT and NTFS file systems. This software is compatible with all windows versions.
Edited by Sofiawatson
spellings mistake
VHD Recovery Software helps to retrieve files that are corrupted, deleted and formatted. It easy recovers all types of data such as images, videos, audio's, archives and etc.  The software provides the excellent way to recover VHD files from the inaccessible state by providing the three effective scanning modes to recover the less and more severe corrupted VHD files. You can download the free version and being a  free version can work on every essential features as in the purchased one.
Click here to know more about the software: www.sysinfotools.com/recovery/vhd-recovery.php
To repair VHD File, you can give a try to remarkable VHD Recovery software. It has a capability to scan and repair VHD file thoroughly. It helps user to recover or restore data files which are severely corrupted, or deleted just in a matter of minutes. It works smoothly on entire MS Windows versions including Win 10.
Hope it helps..!!
Thanks
