NSF to PST Converter Tool
nsf to pst nsf converter lotus notes nsf to pst converter
  • Please log in to reply
6 replies to this topic
#1 JerryB
JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 160 posts
Posted 16 January 2018 - 04:32 AM
If you want to migrate from Lotus Notes to Outlook, you must convert NSF to PST format. Since Outlook doesn't support NSF database format, you can't import or export NSF files directly to Outlook. But you can try here something that will surely help you. You can save NSF files data into any such format which is supported by Outlook client. Luckily Lotus Notes provides you two file formats into which you can save NSF files data: Comma Separated Value and/or Structured Text. And the best thing is that both these file formats are supported by Outlook client. So first you can save your NSF files data into any of these formats. And after that, you can import this new file to Outlook client by using its Import feature. Refer to this blog post complete information:- http://migrateemails...rosoft-outlook/
#2 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 18 January 2018 - 07:05 AM
Take your time to complete this manual process and also you have to be technically sound to execute the process. If you not have the Lotus Notes and only have the NSF file, then you can use this third party NSF to PST converter that doesn’t required Lotus Notes to execute the conversion.
If you want to convert NSF to PST file data manually then visit here: https://mannathelpin...-notes-nsf.html
#3 selvi
selvi
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 18 January 2018 - 09:55 AM
Hi
To Convert NSF to PST you can download the free tool. This software is developed with the smart and user-friendly interface which helps users to work with the converter tool without having the technical knowledge. It never harms the original content.
Thanks
Selvi
#4 santiano
santiano
    Member
  • Members
  • PipPip
  • 27 posts
Posted 23 January 2018 - 12:48 PM
NSF to PST is an ultimate email recovery program which is capable of recovering all the corrupted or damaged emails from Lotus Notes files like address book, journal, calendar, contacts, notes and tasks, email attachments etc to Outlook files without hampering the integrity of the converted NSF files.
#5 John11
John11
    Advanced Member
  • Members
  • PipPipPip
  • 72 posts
Posted 24 January 2018 - 04:18 AM
Learn the complete details of NSF to PST conversion here:  Manual Conversion of NSF to PST .  Here you will know the easy manual steps that without making changes in the original NSF file imports all the NSF file data into PST file format.
#6 iitgeetamalik
iitgeetamalik
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 12 February 2018 - 12:16 PM
As we know that MS Outlook and IBM Lotus Notes both are different email programs that stores, mail data into their data file (.pst for MS Outlook and .nsf for Lotus Notes). The structure of both data files is different and not supported by each other that’s why user require NSF to PST conversion to access their Lotus Notes emails, contacts and other items in MS Outlook. You can download free to use nsf to pst converter in order to perform conversion.
http://www.mailsdadd...-pst-converter/
#7 alayenawill
alayenawill
    Newbie
  • Members
  • Pip
  • 5 posts
Posted 14 February 2018 - 08:26 AM
Hey if you think which is best application for recover NSF data to PST then I suggest you can quickly download Free SysInspire NSF to PST Converter software for secure database recover from NSF file to PST file. This is new technology in this field for understating how to work this application you can try free demo version of this software for convert 25 NSF emails to PST or other formats from per folder
Read More:- http://www.sysinspire.com/nsf-to-pst-converter/
Also tagged with one or more of these keywords: nsf to pst, nsf converter, lotus notes, nsf to pst converter
