jerry10
Outlook PST Split Data
Split PST File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. The software makes you sure that no actual data deleted during the process.This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows.
MS Outlook is the biggest tool which leads to enhance the rapid growth of communication that is essential for an organization. Due to frequent communication demand, the file size is constantly being increased with the growth of organization. In this case, Split PST Tool is very helpful which helps to split large sized PST file into several small sized PST files. This is used for getting better performance of Outlook in moving, searching, opening, copying, exporting and so forth. This split pst software can split all types of Outlook items like contacts, emails, calendars, journals, tasks and notes to smaller PST files.As we have discussed that it has a limit of 2 GB imposed by Outlook. If the limit exceeds to 2GB, you can't switch to the new version of Outlook. In this way, we need to use PST splitter for the solution.
software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. The software makes you sure that no actual data deleted during the process.This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows.  visit at : https://www.softknoll.com/split-pst/
The manual tricks to merge PST files are a very lengthy task, though sometime successful. So you must go for easy technique like third party tool you just need to download the free demo version of SysInfo PST Merge Tool and check some of their stunning functionalities. PST merge tool is the perfect solution for merge two PST files and keeps them as a backup for future use with no file size limit issues. PST Merge Software accepts the list Outlook PST files that users selects to merge and then store it as a single file so that user gets similar data at one place.
