MERGE PST
  • Please log in to reply
1 reply to this topic
#1 sheely
sheely
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 13 January 2018 - 07:10 AM
How can I merge contacts and Archive data file  while merging two large PST files?
#2 amazsilong
amazsilong
    Member
  • Members
  • PipPip
  • 15 posts
Posted 13 January 2018 - 07:12 AM
1. Open “Microsoft Outlook” and locate PST files which you want to merge.
2. To create Outlook Data File, select "New Items” >> “More Items” >> “Outlook Data File”.
3. Create or Open Outlook Data File window will be opened. Specify a name to new PST file and click “OK”.
4. You can see the new Outlook PST file in the navigation tab. Now, Click on “File” tab >> “Open” >> “Import” option.
5. Import and Export wizard will open. Choose “Import from another Program or File” option and click on “Next” button.
6. Select “Outlook Data file (.pst)” and click on “Next” button.
7. Click on “Browse” button to choose the PST file, select “Do not import duplicates” check box and click on “Next” button.
8. Choose the folder to import and select “Include subfolders” and “Import items into the same folder in” both the check boxes, and then click on “Finish” button.
http://www.mergeoutlookpst.com/
