Cadillac Bill Posted January 2, 2018 Report Share Posted January 2, 2018 How to automatically close Chrome & IE during autoclean? I have automatically Wise 365 running and the program stops and asks me to allow the program to close Chome or IE in order to clean their caches. Can the program to close Chrome and IE on its own, or ignore? sapedJet, yapedJet, Sophiebairm and 12 others 15 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 2, 2018 Report Share Posted January 2, 2018 Hi, Sorry, wise care 365 doesn't have this option. we just want to notice user his/her browser is running now in case wise care 365 close your important page. You can try this, create a auto-clean task (on bottom left cornor), wise care 365 will skip browser if it is running. Cadillac Bill 1 Link to comment Share on other sites More sharing options...
Cadillac Bill Posted January 2, 2018 Author Report Share Posted January 2, 2018 Thanks, this makes sense. Will set it up like you said. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 3, 2018 Report Share Posted January 3, 2018 You are welcome! Any question, please feel free to contact us. Link to comment Share on other sites More sharing options...
Cadillac Bill Posted January 3, 2018 Author Report Share Posted January 3, 2018 "You can try this, create a auto-clean task (on the bottom left corner), wise care 365 will skip browser if it is running." Seem to can't find the "auto-clean task" on the bottom. I am using Windows Seven. There is a link about 'custom settings" but won't help Link to comment Share on other sites More sharing options...
xilolee Posted January 3, 2018 Report Share Posted January 3, 2018 Where it says OFF (it's a button), then there's the alarm clock, then "Clean up your computer regularly". You can create a scheduled task from that interface, without having to create one directly from windows task scheduler. Link to comment Share on other sites More sharing options...
