I would also like to recommend another effective and more advanced software named as Kernel for EDB to PST Converter. With this utility, you can very easily and quickly move EDB file of Exchange database to Outlook PST formats without any hassle. This utility also supports to fix EDB corruption issues and recover all stored mailbox items. Its compatible  with all versions of Exchange Server and MS Outlook. For more information, visit: https://www.nucleustechnologies.com/edb-to-pst.html
Good solution  for EDB corruption issue the nice EDB to PST converter software , which will definitely helps to repair EDB file and then systematically recover whole EDB data to new PST applicable form with full attachments like as- inbox item/outbox item/contacts, Tasks, Notes, Calendars, Journals, Reminders etc.
  Export EDB to PST free tool able to convert entire EDB mails to PST and another  new formats EML/MSG/HTML.
Instead thinking so much about its quality first try its FREE DOWNLOAD DEMO version which allow to recover 25 mails at no cost.
Click  here to more knowledge
http://www.gstechsoftware.com/2010-exchange-edb-to-pst.html
Download the Best EDB to PST converter online tool from GSTECH platform which especially invented to resolve EDB corruption/lost/inaccessible issue. This Exchange EDB repair application has nice technology to fix EDB issue once again and recover whole mails from EDB mailbox and then safely export EDB to PST or  another multiple access forms like MSG/EML/HTML with recovery of entire EDB database in safer manner and also keeps safe internal data.
First GSTECH Developers provides you a good chance to check software efficiency in the form of free demo version so go ahead with this link and download demo form.
Click on below path to know more information
Just try perfect EDB to PST converter software to unwanted exchange mailbox errors and also allows to simply recover EDB file errors after that you convert EDB file to PST with its emails properties like as:- to, bcc, cc, subject, date and draft. Stella Microsoft EDB to PST converter software fix exchange EDB mailbox from all version of EDB file as:- 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
Read more detail from here:- https://sites.google.com/view/convertedbtopstsoftware/
https://www.stelladatarecovery.com/exchange-edb-to-pst.html
Be Smart guys, out of millions online EDB recovery product choose the perfect solution as GSTECH EDB file recovery software with latest technology which made by GSTECH engineer team with high tech solution to repair EDB file in safe manner. This EDB conversion tool has wonderful  power to recover EDB data to PST or another new accessible forms like- MSG/EML/HTML. The tool has talent to convert EDB emails from mailbox with entire database (outbox item, inbox item, calendar, meta data). Its has no any issue what EDB platform you run because its capable to works for all EDB platform and windows OS.
first you can check its quality to use Free download demo version which will recover 25 emails at no cost.
Get unlimited info to click below link
this gives EDB to PST converter tool as freeware demo version that will read your edb database file and demonstrate to you
each mailboxes and their separate emails, contacts, timetable, notes, tasks, diaries and so on. Freeware demo version tool
can be used for the conversion from EDB to PST. On the off chance that you have to save large exchange mailbox to pst file
then you require a licensed version of  Exchange Server Recovery Software.
By using smart EDB to PST software that easy and qualified tool to get rid exchange EDB file errors and export EDB file data into new created PST file with all attachment as:- body content, image heard and appointment and support exchange server version 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016 after that it provides you option for divide heavy size of recovered PST file upto 5GB
Reaad more :- https://www.stelladatarecovery.com/exchange-edb-to-pst-converter.html
Edited by samsamith
The best solution for EDB to PST issues Bitdataconversion EDB to PST converter, Which definitely helps you to recover and convert Corrupted  EBD files, it is a fast and reliable solution for EDB files, it can also help you to Migrate Exchange EDB files into Office 365 And Live Exchange Server mailboxes, you can save your recovered mail into multiple email format such as .eml, .msg, .html directly Into disk directory.
For more information click here: http://www.bitdataconversion.com/edb-to-pst-converter.html
Download link :-   http://www.edbtopstconverter.osttopstconverter-tool.com/
If you want to discover a EDB to PST converter Tool, then I personally recommend you that particular tool, I have found at here:-
Bitdataconversion EDB to PST Converter is a reliable and safe solution to recover corrupted EDB files and Export EDB to PST, EML, MSG, Office 365 and Live Exchange server. It also helps to save EDB data into HTML, RTF, Cal, vCal, and vCard format. This EDB to PST tool has a free trial version and a good technical support team as well. I personally use this tool then I suggest you. Try to use this tool its user interface very easy to use.
