EDB to PST Converter software
edb to pst edb to pst converter exchange recovery
  • Please log in to reply
8 replies to this topic
#1 HerbertPickens
HerbertPickens
    Member
  • Members
  • PipPip
  • 16 posts
Posted 22 November 2017 - 09:08 AM
EDB to PST Converter software has been proved as an excellent utility which recovers all types of data on Exchange Server such as attachments, messages, calendars, contacts, drafts, tasks, notes, journals, distribution lists, appointments, sent items, completely deleted emails, sub-folders, directories and etc.
It also provide to save all corrupt EDB File them in various formats like PST, MSG, EML, HTML, TXT and RTF files format.It solves issues by removing errors from inaccessible Exchange server and makes entire enclosed data readable again.Using this software, you can easily recover corrupted or damaged Exchange server files and saved it into a new EDB format.
It extracts mailboxes from offline corrupt edb files and move it to live exchange server, pst, eml, msg, html, Text, rtf file.with this software you can easily repair single or multiple mailbox items from Exchange EDB file and also Extract Mailbox from EDB file into Outlook PST file formats without making any changes.It supports all versions of MS Exchange server and all updated Windows OS versions.
Thanks & Regards,
HerbertPickens
  • HerbertPickens likes this
#2 Doriscaudills
Doriscaudills
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 22 November 2017 - 10:10 AM
Powerful EDB to PST Converter is a professionally designed tool which is effectively and efficiently converts EDB (Microsoft Exchange Database) files offline and online into PST (Outlook Data) files. With this conversion utility, you can extract all the important contacts, emails, sent items, and attachments.It can flexible enough to convert EDB files into EML, PST, RTF, MSG, HTML and PDF files.It supports MS Exchange 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.It avoids all the manual re-configuring process in MS Exchange. All you have to select the offline users and export the same on Live exchange server ( Download the Free trial version of EDB to PST Converter software, in free trial version you are allow to export 25 items per exchange server mailbox to outlook pst file )
#3 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 84 posts
Posted 28 December 2017 - 07:35 AM
To export all EDB contained Email, Message, Journal, Contacts, Calendars, Reminder, Appointment, Notes, etc. created by Exchange Server Account to an Outlook PST here's manual step solution which I am going to share with you. If you're wondering or wishing to import EDB file in Outlook Email Client application then must see how manually we can do this with any expert technical knowledge. To see manual process visit: Convert EDB to PST
#4 abrilnathan
abrilnathan
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 01 January 2018 - 12:56 PM
A well-equipped Tool is available; download this EDB to PST Recovery Software that securely works for recovery of corrupted or deleted folders items from exchange server supported every version included 2013/2010 to 97. This EDB to PST Recovery Software perfectly recover selective folders from EDB files and restore selective items of EDB files to PST Outlook file, EML, MSG and HTML format with emails, contacts, calendars, task, notes, inbox items, outbox items and appointments. There is the best way for recovery the EDB file emails with attachments is EDB to PST converter Software that supports all issues of EDB file to fix them and makes it again useable by conversion all emails or mailboxes items of EDB files to PST Outlook file.
Download Free: http://www.esofttool...-converter.html
#5 John11
John11
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 02 January 2018 - 07:14 AM
Here you will learn best solution to convert EDB file into PST format, but if you want to perform this task manually then you can use any manual techniques. There are two manual techniques available such as- inbuilt ExMerge.exe utility or PowerShell Command Line tool. Both techniques effectively recover data from corrupted as well as normal EDB file and convert into PST format.
Check here:  How to convert EDB to PST
#6 kennyomega481
kennyomega481
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 02 January 2018 - 11:21 AM
EDB to PST converter easily recover corrupt EDB file and allow its user to convert them into multiple formats such MSG, EML, vCard, vCal, MBOX and EMLX and vCard with all data. It gives option 30 days money back guaranty.
Read more: InQuit EDB to PST
#7 santiano
santiano
    Member
  • Members
  • PipPip
  • 25 posts
Posted 03 January 2018 - 12:56 PM
EDB to PST Converter Software offers the seamless conversion of Exchange database files into Outlook PST files. There is no change made in the original file format. The migration is performed with user-friendly and safe way.
#8 luciferr
luciferr
    Member
  • Members
  • PipPip
  • 12 posts
Posted 08 January 2018 - 04:58 AM
This Exchange EDB to PST Converter software is provides you easy and safe way to recover damage exchange EDB file after that you can convert EDB Emails data into working PST outlook with other format like as:- EML/MSG/HTML and it also split heavy size of recovered PST file upto 5GB. This smart and effective EDB to PST conversion software extract Emails from damage exchange EDB database.
#9 abrilnathan
abrilnathan
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 11 January 2018 - 09:47 AM
Download Most Wonderful eSoftTools EDB to PST Converter that helps to recover EDB mails & convert them into PST, EML, EML, MSG and HTML format along with contacts, calendars, task, notes, inbox items, outlook and appointments etc. EDB to PST Recovery Software helps users to repair corrupted EDB file and convert EDB to PST Outlook file without difficulty.
Get Details: https://gust.com/acc...server-recovery
Also tagged with one or more of these keywords: edb to pst, edb to pst converter, exchange recovery
