Export OST to PST format
ost to pst ost to pst converter ost to pst conversion ost recovery
  • Please log in to reply
33 replies to this topic
#21 virat8586
virat8586
    Member
  • Members
  • PipPip
  • 10 posts
Posted 29 January 2018 - 12:52 PM
best-free-OST-to-PST-converter-1024x576.
Would like to refer you this article to get a list of some of the best free tools to import files from offline OST format to Outlook PST format.
Which Are The Best Free OST To PST Converter (A Review Guide)
#22 helengilbert473
helengilbert473
    Advanced Member
  • Members
  • PipPipPip
  • 54 posts
Posted 02 February 2018 - 05:39 AM
OST to PST converter tool to recover corrupt files very easily and convert OST email into EML, MSG, PST and HTML formats. OST converter is easy way to conversion of OST files into PST files. OST to PST software successfully supported all version of MS Outlook platform.
OST to PST converter software performs flawless OST file recovery and OST to PST conversion. This tool is capable of saving recovered files in PST, EML, HTML, and MSG formats.
  • helengilbert473 likes this
#23 romansinas
romansinas
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 05 February 2018 - 07:13 AM
OST to PST converter repairs and recover all deleted and damage OST files data and convert into PST files format without any data failure. It is very fastly convert damage OST file to PST file.
Visit more details:    OST to PST Converter
#24 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 47 posts
Posted 05 February 2018 - 08:45 AM
Easily repairs damaged OST File data and quickly recover corrupted OST File emails folders items and also recover deleted mailbox items using the PDS OST to PST Tool. It convert OST File into PST File and multiple formats EML, HTML, MSG, MBOX, and PDF (to, cc, bcc, time and date etc.)It gives naming convention option to save your data: - from “subject, from + subject+ date, subject + date, from+ subject, date” It works on all outlook version from :- 97 to 2016.
Read More Information about This Software :-  https://gallery.tech...to-PST-508fcf9a
#25 shivguptag
shivguptag
    Advanced Member
  • Validating
  • PipPipPip
  • 110 posts
Posted 05 February 2018 - 10:48 AM
I would also like to recommend another proficient and reliable OST to PST conversion software, which can very easily and quickly fix Outlook OST errors and convert then in PST formats without any hassle. You can also use it to recover deleted or permanent deleted Outlook mailbox items. For more information, visit: https://www.converto...pstfree.org/en/
or
https://emailsmigrat...ost-to-pst.html
#26 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 93 posts
Posted 05 April 2018 - 09:46 AM
With OST to PST Converter software which repairs corrupt OST data and converts OST to PST quickly, while maintaining the original hierarchy of folder without any data loss. It is intuitive and designed well. Even a non-technical user can handle this program. Use free trial version of this software and more details click this Visit link:- http://www.osttopstapp.com/
#27 kagasgeorge
kagasgeorge
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 05 April 2018 - 11:35 AM
<p>Go to download best GSTECH 2016/2010/<a href="http://www.gstechsof...ost-to-pst.html">2013&nbsp;Outlook OST to PST Recovery</a> Software now to recover each emails (inbox/outbox/contacts/calendar/deleted items/Meta Data)and other databases. Convert Offline&nbsp;<span style="font-size:10pt;font-family:verdana, sans-serif;color:rgb(85,85,85);">OST 5.0/OST 5.5/ OST 2000/OST 2002/ OST 2003/ OST 2007/ OST 2010/ OST 2013/ OST 2016 and export them into Microsoft Outlook app up to PST 2016 wi</span>th entire details given in your OST file.</p>
<p>&nbsp;</p>
<p><strong>Download FREE<a href="http://www.gstechsof...-converter.html"> Outlook OST to PST Converter</a> Tool </strong>to check out the fine qualitative way to recover OST to PST.</p>
<p>&nbsp;</p>
<p><strong>READ MORE</strong></p>
<p><a href="https://sonithfernan...e.com/osttopst/">https://sonithfernan...e.com/osttopst/</a></p>
#28 marcobrown
marcobrown
    Member
  • Members
  • PipPip
  • 25 posts
Posted 06 April 2018 - 06:16 AM
Hi, Felix Lemus
If you want to export OST to PST file format than you can use Exchange OST Recovery Freeware Software..this tool can repair & recover Corrupt Outlook OST Files within a minutes...This utility runs smoothly on all versions of Windows OS..
​I hope this will surely help you!
Regards
Marco
#29 ratishwebpromotion
ratishwebpromotion
    Member
  • Members
  • PipPip
  • 17 posts
Posted 06 April 2018 - 07:37 AM
To migrate your OST file to PST file format you can simply try third party OST to PST converter tool. For your convenience you can download an effective OST to PST converter software from http://goo.gl/6oH68O
#30 marcobrown
marcobrown
    Member
  • Members
  • PipPip
  • 25 posts
Posted 09 April 2018 - 06:01 AM
Hey FelixLemus
I would like to recommend you OST Recovery tool for export OST to PST file format..
This tool help users to save the recovered files in different other formats like PST, DBX, EML, MBOX & Archive format..
Thanks!
Regards
Marco
#31 davistaylor
davistaylor
    Member
  • Members
  • PipPip
  • 19 posts
Posted 09 April 2018 - 12:17 PM
Get a chance to export OST into multiple formats like as
OST to PST
OST to HTML
OST to EML
OST to MSG
OST Contacts to Vcard (.vcf)
Recover OST to PST from various Offline Microsoft OST formats like as
OST5.0
OST 5.5
OST 2000
OST 2002
OST 2003
OST 2007
OST 2010
OST 2013
OST 2016.
After enriched with multiple features GSTECH OST to PST Converter becomes more powerful and probable to convert OST to PST File
FREE DOWNLOAD is always beneficial for every user related to matter of any tool and services, it saves always time and money both, so be quick to view the demonstration for OST to PST Conversion Tool
#32 smithjohn
smithjohn
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 14 April 2018 - 12:15 PM
I am also using this tool for the migration of OST data into PST. Try this software for converting your OST to PST files.
#33 selvi
selvi
    Advanced Member
  • Members
  • PipPipPip
  • 34 posts
Posted 16 April 2018 - 12:58 PM
Hi
Learn different types of methods for converting your Offline folders into PST file format.
Read here for more information:-  How to open OST file in PST file format
Thanks
Selvi
#34 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 186 posts
Posted 17 April 2018 - 08:34 AM
OST to PST converter tool smoothly recovers OST files troubles and transfer OST file to PST file format. This is secure way to convert OST file to PST file format. To know more about the application visit http://www.recoveryd...-converter.html
Also tagged with one or more of these keywords: ost to pst, ost to pst converter, ost to pst conversion, ost recovery
