Convert OST to PST
ost to pst converter convert ost to pst ost recovery ost to pst conversion
  • Please log in to reply
45 replies to this topic
#41 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 146 posts
Posted 05 April 2018 - 09:37 AM
Want a easy conversion technique for OST file to PST format then you first try the Import / Export method. Its inbuilt feature of MS Outlook. Using this solution you can easily Export all the OST file data and Import into new PST file format. If manual technque is not fulfill your requirement, then you have to use third party software. There are various software available you can do a web search and look into those. For more details please visit :- https://gallery.tech...vertor-1d6c0253
#42 selvi
selvi
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 05 April 2018 - 10:03 AM
Hi
There are many such supportive tools which convert your OST files into PST file format with a single click. This is good for large database but for small files you can try the manual method and convert the files with 0 money wastage.
Read more:- Convert files by manual method
Thanks
#43 marcobrown
marcobrown
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 06 April 2018 - 06:41 AM
Hi Doriscaudills
If you want to convert your OST file to PST file format then no need to worry you can convert via OST Recovery Tool, this utility can recover all your Outlook emails, contacts, task, calendars..Help users to save the recovered files in different other formats like PST, DBX, EML, MBOX & Archive format..
Thanks
Regards
Marco
#44 ratishwebpromotion
ratishwebpromotion
    Member
  • Members
  • PipPip
  • 17 posts
Posted 06 April 2018 - 07:35 AM
To export OST to Outlook PST file user need to use third party OST to PST Converter tool. Visit http://www.recoveryd...-converter.html to download the trial version to check the performance and see the conversion process.
#45 elansmask
elansmask
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 09 April 2018 - 05:52 AM
If you are worried about damaged OST mailbox like Emails, contact, calendar, journal task, drafts, notes, deleted items, and attachment etc. it support window server 2003, 2003 R2, 2008, 2008 R2 2016 and support Live Exchange Server & Office 365, its free trial version is also you can easily download it from Official website, you can access 30 email items of each folder.
Read more info Search in Google:  http://www.bulkecommerce.com/
#46 marcobrown
marcobrown
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 09 April 2018 - 06:09 AM
You can use OST Recovery tooI..I discussed on this topic earlier as well..For more info you can visit here:
http://forum.wisecle...ge-2#entry34301
Thanks
Marco
Also tagged with one or more of these keywords: ost to pst converter, convert ost to pst, ost recovery, ost to pst conversion
