Convert OST to PST
ost to pst converter convert ost to pst ost recovery ost to pst conversion
  • Please log in to reply
45 replies to this topic
#1 Doriscaudills
Doriscaudills
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 20 November 2017 - 10:12 AM
Microsoft Outlook PST file is a very common type of file which is quite same as others. So, it is also possible that any disaster may happen with crucial OST file. Some errors may happen in OST file like virus attack, Trojan error, synchronizing error, header corruption, file size exceeds the limit of 2 GB, software malfunctioning, software-hardware problems, badly shutdown of system and etc. These all freak errors may cause corruption in OST file. So in that case, the users have only one option to restore MS Outlook OST file to PST that they will go with the process of OST to PST Conversion. It can only be possible with OST to PST converter tool that is designed by new and update technology.
Let’s have a look to its features:
    1. Ensures surety of success with OST to PST Conversion
    2. Extracts all OST corruptions fabulously in minutes with few clicks
    3. Recover MS Outlook files from the badly corrupt OST database
    4. Quick and safe process of OST to PST conversion
    5. Uses effective techniques and methods to convert OST file to PST
    6. Helps to fix OST to PST from all versions including 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
    7. Compatible with Windows 95, 98, 2000, XP, 2003, Vista, 7, 8 & Windows 10.
    8. Convert OST to PST along with shifting complete OST information after recovery.
    9. It supports all the versions of MS Outlook including 98, 2000, 2002, 2003, 2007, 2010, 2013 and 2016.
   10. Free Version Available, will see you the preview of recover original data, integrated with full features.
All in all it is a professional tool which helps to convert OST to PST even at the time when Exchange Server goes down. It is designed to convert OST to PST file so that is can easily be accessed with MS Outlook.
We are here to provide an option to check every feature & capability of Convert OST to PST software. Free Trial version enable you to see the preview of recover OST Emails as well as preview the converted OST file to PST.
To download just click given link - http://www.pcrecover...ost-to-pst.html
  • Nopwailla and JosephSaf like this
#2 steve_trump
steve_trump
    Member
  • Members
  • PipPip
  • 14 posts
Posted 20 November 2017 - 12:44 PM
The OST to PST Converter software enables data recovery from the corrupted OST files into outlook personal files. This recovery software is helpful in recovery and you have lost all hopes to recover information. It converts all types of corrupt files of MS office email clients. It can thoroughly scans the offline contents of OST file and converts the same into the PST file. This has interactive GUI feature which repairs the OST files and helps you to select the one you need to convert into PST file.The trial version is free of cost which enables you to know the features of the tool which helps you in perfect OST to PST Converter.
Also, Try free tool : EDB to PST Converter | OST to PST Converter
#3 romantrump
romantrump
    Member
  • Members
  • PipPip
  • 13 posts
Posted 21 November 2017 - 11:56 AM
Greatly convert ost file to pst format by the help of Atom TechSoft ost to pst converter software tool
Click below to download software and read more about :-
Atom TechSoft outlook ost to pst 2016 recovery tool
#4 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 23 November 2017 - 12:02 PM
Smart  OST to PST repair software quickly repair and convert Outlook OST file to PST, EML, MBOX, DOC, TXT, PDF, MHTML, MSG and HTML formats with all attachments. Use OST to PST recovery software to easily recover emails from Outlook OST file in just few seconds. It also works on ms Outlook versions Up to 2016.
#5 Phillcalls
Phillcalls
    Advanced Member
  • Members
  • PipPipPip
  • 72 posts
Posted 24 November 2017 - 05:11 AM
Use advanced featured OST Converter Tool to save damaged as well as repaired OST file in various other file formats such as in PST, MSG, DBX, EML, MBOX and Archive. Here's introduction of OST to PST Converter Software that repairs as well as converts OST file in all mentioned PST formats with all OST saved emails, messages, contacts, calendars, appointments and other data items. This software can be used in all Windows based operating system and in all version of Outlook.
Check more detail: OST to PST Converter
#6 toresjessica
toresjessica
    Advanced Member
  • Members
  • PipPipPip
  • 75 posts
Posted 25 November 2017 - 09:58 AM
OST to PST Converter Software is an outstanding solution which has easy steps and allows user to convert OST files into multiple formats as PST, EML, MSG, HTML, MBOX and PDF with different features like as:-
·         Convert any size of OST file.
·         Message filters option to find emails between two selective dates as “start date” to “end date”.
·         Split large PST files into small size PST file upto 5GB.
Note- Demo version of this application only recovers 20 emails per folder into each format at free of cost.
Download Free Software:- OST to PST Recovery
#7 virat8586
virat8586
    Member
  • Members
  • PipPip
  • 10 posts
Posted 30 November 2017 - 10:22 AM
I would suggest you to have a look at these free software, These tools are good and very effective.
"As I always say...Why Pay When You Can Do It For Free"
For more details, you may also check out this article once....in which they have reviewed some of these free tools. Their Pros, cons and everything.
Do Give it a read:
Which Are The Best Free OST To PST Converter (A Review Guide)
#8 sandersdavid
sandersdavid
    Member
  • Members
  • PipPip
  • 13 posts
Posted 30 November 2017 - 12:13 PM
Thanks
Atom TechSoft​ Group
Atom TechSoft​ OST Converter to PST Software is good way to recover selective OST emails and move all the selected OST emails into Outlook file with complete emails properties- to, bcc, cc, time, subjects and from, email header information, email body content and email items etc.By taking help of export OST to PST Tool you can make selection of emails according to dates “from date” to “to date” and perfectly convert all date wise selected OST emails into existing outlook file and safely convert them into PST File.
More Info-: OST to PST Converter
#9 shirasmith
shirasmith
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 01 December 2017 - 06:25 AM
Excellent OST to PST converter is very useful which converts OST file into new readable PST files. OST to PST converter successfully recover corrupted OST file from Outlook OST file and allow its user to convert into PST file successfully.
Read more information:   http://www.bulkecomm...ftware-159.html
#10 selvi
selvi
    Advanced Member
  • Members
  • PipPipPip
  • 34 posts
Posted 01 December 2017 - 12:14 PM
To Convert the OST files into PST format you don't need to require any technical knowledge. You can easily convert your files by using free tools which are available in the market. I can recommend you the best tool and that is OST to PST Converter tool.
#11 andrewdim
andrewdim
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 13 December 2017 - 11:50 AM
If you are looking for a reliable and result-oriented OST converter tool, you can opt for astounding third party OST to PST Recovery tool. It help users to recover OST file and move them to Outlook PST. Furthermore, it also let users to move OST file to MSG, EML, HTML, MHTML, PDF, TXT and RTF. The best part of the tool is it simple user interface.
More information can be obtained from: http://www.osttopst.us
#12 santiano
santiano
    Member
  • Members
  • PipPip
  • 27 posts
Posted 13 December 2017 - 12:30 PM
Magnificently process to recover offline damage OST files and straightforward to remove OST files errors in the safe and smooth manner with OST to PST migration software.
#13 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 44 posts
Posted 14 December 2017 - 07:55 AM
Remove OST File errors and satisfactorily recover OST File data by helping OST to PST Converter Tool. It has fast process to convert OST File into PST, EML, HTML, MSG, MBOX, and PDF Formats with all emails properties such as properties like as ( To,Cc, Bcc, subject and Date & Time Date & Time ) Contacts , Calendar items , Notes, scheduled tasks appointments , journals , drafts. It gives you naming convention option to safe your data as Date+ Subject, From +Date +Subject, Subject, Subject Date, Subject +Date +from. It split large recovered Split Large recovered PST File into Small PST File (1 GB up to 5 GB).
Read More Information about this software :-  OST to PST Recovery
#14 Prinamwill
Prinamwill
    Member
  • Members
  • PipPip
  • 27 posts
Posted 14 December 2017 - 11:58 AM
Suddenly working Outlook OST file is stop due to occur corruption in MS Outlook application then doesn’t waste time? Just make use of the best OST to PST Converter Software which smoothly repair corrupted, damaged or encrypted OST file to convert OST files to PST Outlook file, EML, MSG, HTML and many more format. Software works on all OST File versions upto 2016 and windows versions upto 10 (32 and 64).
Get More info: http://www.esofttool...-converter.html
#15 shirasmith
shirasmith
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 16 December 2017 - 11:20 AM
Try to Best exchange OST to PST Converter Software. I would like to suggest download ATS OST to PST Converter Software. this software easily repair and recover OST file data from Corrupt OST file and Convert Into OST file to Outlook PST and other file format like MSG, EML, EMLX, MBOX, vCard, vCal and HTML file format.
More information visit: http://www.bulkecomm...ery_tool-9.html
#16 Prinamwill
Prinamwill
    Member
  • Members
  • PipPip
  • 27 posts
Posted 16 December 2017 - 12:16 PM
Successfully recover emails from damaged OST file and makes them useable or readable in PST file by importing all data using well designed OST to PST Converter Software that permits convert the OST file data into PST Outlook file, EML, MSG, HTML and many more format. Software works on all OST File versions upto 2016 and windows versions upto 10.
#17 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 19 December 2017 - 07:32 AM
You can go on google and saerch OST to PST Software which will be helps you to repair your damaged OST file and convert all OST data into PST file format. When i lost my OST data then is also used this software to recover my OST emails and convert OST to PST file..
#18 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 44 posts
Posted 19 December 2017 - 08:45 AM
PDS OST to PST Converter Tool successfully repair damage OST File & Recover OST email with attachment, contacts, calendar, notes, tasks, journals, appointments with convert OST File into new outlook PST File. It quickly provides Message Filter; with it users can filter their messages on their own choice, if they need filter their message upto 1 month so they have to select "Start Date" and "End date" with attachments. It safely works to re-open OST File in readable mode. Software supports 32-bit and 64-bit OS.
Note :- Huge Discount upto 50% on OST to PST Recovery Software till 15 January 2018
#19 JamesStewart250
JamesStewart250
    Member
  • Members
  • PipPip
  • 23 posts
Posted 29 December 2017 - 09:40 AM
Convert OST to PST, a secure and reliable third party software, capable to recover data from corrupt OST files and also able to restore them into PST file with ease. Apart from that, users can also convert OST mailbox data into EML, MSG, MBOX, DBX, HTML, MHTML, PDF, TXT and RTF file formats. To get the more information about the software and to download its free trial version, visit- http://www.convertosttopstfree.org
#20 steve_trump
steve_trump
    Member
  • Members
  • PipPip
  • 14 posts
Posted 02 January 2018 - 02:11 PM
Try OstPstMails Free OST to PST Converter tool to convert ost file to pst. You can export any corrupted .ost file to .pst file format using this software. you can recover all data like mails, contacts, calendar, tasks etc.
Main Features of OST to PST Converter:
Outlook OST file data recovery:
Recovers email data with all its attributes like Date & time, To, BCC, Subject, From, CC from corrupted OST file and also recovers Email body images, mails with all attachments,  embed attachments etc.
Filters Options to Export:
Exclude / Include, Set after Date / Before Date and email Subject wise are filter options that can be used while exporting your OST to PST file.
OST to PST, MSG, EML:
You can export OST files data to PST, EML, MSG formats. This exported file format can be opened in many mail clients application including Outlook, Outlook Express, Mozilla Thunderbird or any other viewers.
for more information and to download visit OST to PST Converter
Also tagged with one or more of these keywords: ost to pst converter, convert ost to pst, ost recovery, ost to pst conversion
