Split Large PST Files
split pst break pst divide pst
  • Please log in to reply
4 replies to this topic
#1 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 85 posts
Posted 08 November 2017 - 04:11 AM
With the increasing size of the PST file that may result in file corruption, and subsequently decreasing the performance of the email application as well. So the users might have to resort to some ways to cut down the size of PST files. The entire operation is performed in a very safe mode without causing any changes or damage with the help of PST Splitter Tool. Software has smart features built in with the smart algorithm. PST Splitter is innovative software tool gives you the best results as the entire operation of PST splitting is completed in a some click of a mouse.
To know more info at:- http://migrateemails...-file-manually/
#2 Abrienne
Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 08 November 2017 - 09:38 AM
One highly recommended third-party tools to split PST file; PST file splitter software. Software not only works amazingly in fact provides me various other options to manage my PST file. I would recommend this tool to every user searching for PST splitter tool. The user can try software’s free demo.
#3 Eva Suzan Adom
Eva Suzan Adom
    Member
  • Members
  • PipPip
  • 13 posts
Posted 21 December 2017 - 07:20 AM
Hi,
To split large PST files in Outlook you can choose either manual or automated solution. Both provides best solution in different way. You can refer this blog as it explains both the approaches to break PST files in a step by step procedure:
How to Create Separate PST Files in Outlook 2013
Thanks & Regards
Eva Suzan Adom
#4 amazsilong
amazsilong
    Member
  • Members
  • PipPip
  • 15 posts
Posted 28 December 2017 - 12:02 PM
PST files comprises of large sized and there may be chance of data loss for that reason splitting of PST is used. Splitting of PST is a way of divided large PST data file into smaller parts, here I suggest manual solution for splitting PST file by using Move to Folder option.
Manual Steps to split PST file are-
Step 1: Open MS Outlook application and click on File menu.
Step 2: In the File menu click New.
Step 3: In the new option select Outlook Data File.
Step 4: Select Outlook Personal Folder File (.pst) on New Outlook Data File and click on OK.
Step 5: Create Microsoft Personal Folder dialog box will open and give a new name to PST file.
Step 6: Click Edit menu and Move to Folder and Move items .
Step 7: click on new button.
Step 8: In the Create New Folder dialog box write a name to new PST file and
           Choose new PST file under Select where to place the folder and click OK.
Step 9: Select new folder to new PST file within Move items and click on OK button.
#5 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 13 January 2018 - 12:14 PM
Split PST Tool is a result oriented utility which can efficiently split the oversized pst file into two small pst files.By using Split PST tool, you can easily resolve this problem and manage the data in MS Outlook .It is embedded with a strong algorithm which can easily and efficiently split the large pst file into small pst files with the hundred percent accuracy of data.No special skills required to access this software. Split PST File Tool supports all versions of MS Outlook and is capable of splitting of PST files creates using MS Outlook 2000, 2002 (XP), 2003, 2007, 2010, 2013, 2016 versions.
Also tagged with one or more of these keywords: split pst, break pst, divide pst
