Outlook PST to NSF Conversion
pst to nsf pst converter outlook pst lotus notes nsf files
  • Please log in to reply
3 replies to this topic
#1 JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 167 posts
Posted 01 November 2017 - 05:19 AM
PST to NSF Converter is most reliable and appropriate email migration tool, that can securely convert Outlook databases file to Lotus Notes NSF format. You can easily and safely move all your messages and other information MS Outlook PST to Lotus Notes NSF documents. The tool convert all Outlook items like emails. contacts, calendars, tasks, journals, etc to NSF file format.
If you are searching a cost free solution for PST to NSF conversion, then visit here:- http://migrateemails...-database-file/
#2 SteFun
    Advanced Member
  • Members
  • PipPipPip
  • 64 posts
Posted 03 November 2017 - 09:28 AM
Instead of converting NSF to PST, you can import the mailbox content from Lotus Notes to Outlook client. How? Since there's way to import NSF to PST format, you should save the NSF files' into any such format which is supported by Outlook client. Luckily, IBM Lotus Notes provides you two file formats into which you can save your NSF files: Comma separated value and structured text. After saving the NSF files into any of these formats, you can import them to Outlook client by using its Import feature. Refer to this blog post for complete information - Export Lotus Notes Email and Other Data to MS Outlook
Before you can purchase any paid software for NSF to PST conversion, you must try the manual trick shared in the above blog post. I hope the shared information would be helpful here.
Thanks and best regards.
#3 jamon99
  • Members
  • PipPip
  • 22 posts
Posted 04 December 2017 - 07:52 AM
PST to NSF Converter is an advanced and awesome utility for Outlook PST to Lotus Notes NSF conversion. This tool is an efficient conversion program to migrate MS Outlook emails, contacts, tasks, calendars, journals to Lotus Notes database files. With the help of this tool, you can migrate your multiple PST files into Lotus Notes NSF database. Visit : http://www.datavare....ter-expert.html
#4 walterrobin57
  • Members
  • Pip
  • 3 posts
Posted 07 March 2018 - 11:20 AM
An efficient tool to migrate the database from MS Outlook to Lotus Notes is the PST to NSF Converter as it moves all Outlook items such as emails, contacts, calendars, journals to the Notes NSF file. The conversion will take place by maintaining data integrity and with all meta properties. The tool supports the Outlook versions 2016, 2013, 2010, 2007, 2003 etc and Lotus Notes 9, 8, 7 and all older versions. Visit for more info : http://www.softakens...-converter.html
Also tagged with one or more of these keywords: pst to nsf, pst converter, outlook pst, lotus notes, nsf files
