Alisa Smith
Converter EDB to PST
EDB to PST Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application. It supports MS Exchange Server Recovery for 2003, 2007, 2010 and 2013 corrupt and unmounted database.
Recovers Calendar, Attachments, Drafts etc., from the damaged EDB files
EDB to PST Exchange server Recovery tool helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc. from the damaged EDB files. Its ease of use GUI enables you to preview recovered mail items.
- Recover / Restore only required Mailboxes
- EdbMails capability of granular / brick-level mailbox EDB to PST conversion support, will help you to recovery any desired Mailboxes data.
- Automatic handling of PST file size limit
- If the Outlook PST file reaches size limit then, EDB to PST Converter will automatically split the PST file into multiple files based on the size limitation of the Outlook PST.
- Recover Deleted Mailboxes
- Edb to PST converter can easily recover mailboxes, which have been deleted knowingly or unknowingly.
- Recover and Save as EML, MSG format
- In addition to saving the recovered data as PST file, it also allows you to save the recovered data as MSG, EML formats.
For more information please click the link: https://www.edbmails.com
Download EDB to PST converter for repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You should try to use this software before purchasing any paid software. It gives 100% positive result in all situations. It is smoothly compatible with all versions5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
Try to use free software click here: http://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
Enstella EDB Converter Tool is the best solutions to convert EDB to PST/ EML/MSG and HTML format with whole email properties- to, cc, bcc, date, time, from and subject. It marvelously scans all corrupted EDB file and also convert EDB File into PST. This Software fastly convert selective & multiple EDB emails into PST with all emails attachments, inbox items, deleted folder items, task, embedded images, journal, calendars, zip attachments etc. This Software works on all MS Exchange EDB file versions including: 5.0 to 2016.
Click Here: EDB to PST
Shoviv for EDB to PST Converter is providing a complete solution for Exchange EDB files users to recover corrupted EDB files and convert EDB to PST, EML, and MSG format. It also gives permission users to migrate EDB to Office 365 and Live Exchange mailboxes.
Read More: https://www.shoviv.com/convert-edb-to-pst.html
Exchange Server Recovery is the best and powerful solution to fix all EDB file corruption issues effectively. The software performs accurate recovery of all emails, attachments, contacts, and other mailbox items from corrupt EDB files in a very short span of time. Read more information and free download click here http://exchangeserverdatabaserecovery.blogspot.com
