Alisa Smith
EDB to PST Converter
EDB to PST Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application. It supports MS Exchange Server Recovery for 2003, 2007, 2010 and 2013 corrupt and unmounted database.
Recovers Calendar, Attachments, Drafts etc., from the damaged EDB files
EDB to PST Exchange server Recovery tool helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc. from the damaged EDB files. Its ease of use GUI enables you to preview recovered mail items.
- Recover / Restore only required Mailboxes
- EdbMails capability of granular / brick-level mailbox EDB to PST conversion support, will help you to recovery any desired Mailboxes data.
- Automatic handling of PST file size limit
- If the Outlook PST file reaches size limit then, EDB to PST Converter will automatically split the PST file into multiple files based on the size limitation of the Outlook PST.
- Recover Deleted Mailboxes
- Edb to PST converter can easily recover mailboxes, which have been deleted knowingly or unknowingly.
- Recover and Save as EML, MSG format
- In addition to saving the recovered data as PST file, it also allows you to save the recovered data as MSG, EML formats.
Really a nice EDB to PST Converter tool and I like its features. It is really very user-friendly and has lot of advantages for my email management.With the help of this conversion tool, you can extract all the important contacts, emails, sent items and attachments.The software runs on online conversion mode and allows users to convert all the EDB files to different formats like MSG (text), EML (Email), PDF, RTF and HTML format. It makes emails really very easy and quicker to access. You can also see the MSG file contents with Outlook and EML can be viewed in Outlook Express.
Use Free Trial Version & See the Preview of Convertible Mailboxes : Exchange Server mailboxes (EDB) into accessible and usable Outlook Personal Storage files (PST)
vMail EDB to PST converter is perfect to convert Exchange EDB files to separate PST files and recover mailboxes from Exchange Server. This tool is very easy-to-use email converter software which helps you recover emails, contacts, drafts, attachments, etc. of your Exchange Private(Priv1.edb), Public Database(*pub1.edb) file. Its perform a smoothly convert Exchange MailBox into Outlook PST file.
Read More- http://www.vsoftware.org/edb-to-pst-converter.html
SysInspire EDB to PST Converter Software is 100% safe and secure application that recovery of damaged and inaccessible exchange EDB file and also convert EDB file with emails, contacts, calendars, task, notes, inbox items and appointments without creating any problem and supports all MS Outlook versions included – 97, 2000, 2002, 2003, 2007, 2010, 2013 and 2016.
EDB to PST Recovery Software helps users for recover and convert exchange mailboxes to PST, MSG, EML, EMLX and MBOX format with preserve emails properties and attachments. It shows preview of EDB file and gives you demo facility under which demo you can save 25 emails per folders.
Free EDB to PST Converter Software
Quickly know about this :-  https://freeedbtopstconverter.page.tl/EDB-to-PST-Converter-Software.htm
Use Vartika EDB to PST Converter and convert single or multiple emails of EDB file into PST along with all email properties- to, cc, bcc, from, date, time and subject. It gives you multiple conversion formats as like- MSG/ EML/ HTML and MBOX. EDB Converter Software Import EDB into Office 365 and Live Exchange Server.
Shoviv for EDB to PST Converter is providing a slightly simple and reliable solution to convert EDB to PST files. This tool also allows users to migrate Exchange EDB files into Office 365 and Live Exchange server. It has another option too to saves EDB data into EML, MSG, HTML, RTF, Cal, vCal, and vCard format. EDB to PST converter tool has a free trial version and a good technical support team as well.
Read More: https://www.shoviv.com/convert-edb-to-pst.html
EDB Converter Software gives smart way to convert EDB file into PST, EML, MSG and HTML Format. Using of Enstella EDB to PST Converter Tool, you can perfectly scan all corrupted EDB file then also convert Exchange Database to Outlook PST with all attachments, inbox items, deleted folder items, scheduled task, embedded images, journal, calendars, videos and zip attachments. It supported with all MS Exchange EDB File Versions including: 5.0 to 2016.
Exchange Server Recovery is the best and powerful solution to fix all EDB file corruption issues effectively. The software performs accurate recovery of all emails, attachments, contacts, and other mailbox items from corrupt EDB files in a very short span of time. Read more information and free download click here http://exchangeserverdatabaserecovery.blogspot.com
