RICK-PC Posted September 13, 2017 Report Share Posted September 13, 2017 The item WiseCare 365.exe that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly. do you want to delete this shortcut- no Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:windows Available physical memory: 3559 MB CPU: AMD A6-3400M APU with Radeon HD Graphics Drive Info: C: 581.23 GB Internet Explorer: 11.0 AnthonyPoelf, VictorRex and JamesSeaft 3 Link to comment Share on other sites More sharing options...
xilolee Posted September 16, 2017 Report Share Posted September 16, 2017 Hi RICK-pc. Open wise care 365 shortcut properties (right-click on it, properties) and change the paths in it with your new paths. If you removed wise care 365, then you can delete wise care 365 link. If you still can't solve the problem, reinstall wise care 365, or use its portable version (in this case, you will have to create a new shortcut on your desktop, if you want it on your desktop). Hope this helps. Link to comment Share on other sites More sharing options...
