DBX to PST Conversion
dbx converter dbx to pst dbx to pst converter outlook express
  • Please log in to reply
2 replies to this topic
#1 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 85 posts
Posted 06 September 2017 - 05:34 AM
DBX to PST Converter is a highly-advanced mailbox conversion tool that lets you access Outlook Express emails with MS Outlook. It lets you perform multiple conversions at the same time, which means you can select many DBX files to be converted into PST files. You can save the converted PST file at a user-defined location, which is easier to access. Also the software helps you to locate the DBX file in your system hard disk, making it easier for those who do not know where Outlook Express creates a DBX file.
Learn more info at:- DBX to PST Converter.
#2 SteFun
SteFun
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 18 September 2017 - 10:50 AM
If you're looking for a free solution, you can try two easy manual tricks which require no 3rd party tool.
  1. First, you can use Outlook client. It has a built-in Import feature which you can use here. By using the import feature, you can import email messages and address books from Outlook Express to Outlook client with ease.
  2. Also, you can use Windows Live Mail application that has both import and export features. By using its Import feature, you can import the email messages from Outlook Express to Windows Live Mail. And after that, you can export them to Outlook client by using its Export feature.
For complete information on DBX to PST conversion, you can refer to this blog post - DBX to PST Conversion – Migrate Outlook Express to Outlook | N. Sem's Blog
Or if you're looking for an easy, safe and swift way for DBX to PST conversion, you should try a professional converter tool. Download free demo version of DBX to PST Converter software to convert DBX files into PST format without causing any alteration or modification to the original email messages. You can select single as well as multiple DBX files at the same time to perform batch conversion. By using its free demo version, you can save first 25 email messages of each selected DBX files into new PST files. I hope the shared information would be helpful here.
Thanks and best regards.
#3 Marytayllors
Marytayllors
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 13 January 2018 - 12:20 PM
Another DBX to PST Converter is a professional utility for the migration of Outlook Express DBX Files into usable and importable Outlook PST files.It also comes with “Technical Version” to convert several DBX files. It also saves the converted DBX files into various formats like MSG, RTF, EML, PDF, HTML and Office 365.With this software, you can choose the single identity or DBX file which contains several emails for conversion.
Also tagged with one or more of these keywords: dbx converter, dbx to pst, dbx to pst converter, outlook express
