deved2112
OST to PST tools
ATS OST to PST Converter successfully recovers the damaged OST files and converts it into MS Outlook PST format for further use. This OST recovery tool converts all the OST mailbox items including inbox, outbox, sent items, deleted items, drafts, contacts, calendars, notes. It doesn’t matter whether OST files are encrypted or password protected, even the installation of MS Outlook is not required, it can work in the absence of MS Outlook also. It support window server 2003, 2003 R2, 2008, 2008 R2 2016, supporting of Office 365 & Live Exchange Server.
Read more details:   http://www.bulkecommerce.com/page/ost_to_pst_converter-12.html
If your OST file data got corrupted you can’t access them so don’t worry you can easily re-access OST file and also recover damage OST file data with the help of Stella OST to PST Recovery software that has feature to throw out any types of OST file errors and fix them as well as it also support all version of OST file i.e 5.0/5.5/2000/2003/2007/2010/2013 and 2016 after that allows to open OST file data into working MS outlook PST file with some other format like as:- EML/MSG/EMLX/HTML/MHTML/DOC and outlook profile.
For Further Detail Please visit here:-  http://stellaosttopstrecovery.blogspot.in/
Microsoft Outlook uses OST file to save and access data in offline mode. This Outlook offline data file (ost file) allows users to work in offline mode and save work data. Next time when the connection is available, MS outlook automatically synchronize all work and changes with Exchange Server. Here some time while working offline OST file damaged due to Outlook unusual shutdown or synchronization error and many others reasons. To fix OST file and recover all data, OST to PST Converter tool is the best option.  This Software not only recovers Outlook emails and other data from OST file but also convert to PST and many other formats. Here if you have an Office 365 subscription, then you can also export recovered data from Outlook OST file to your Office 365 account.
Download- https://vmail-ost-to-pst-converter.en.softonic.com/
Hi,
I am suggesting to you manual method by using Archive Feature. It converts all the items of OST mailbox to PST format.
Follow the steps are mention below:-
1. Open MS Outlook application and then open the OST file from which the data needs to be exported.
2. Click on the File tab >> Click on Info >> then go to Cleanup Tools.
3. Now, select Archive from the options.
4. In the Archive dialog box that shows, ensure that Archive this folder and all subfolders option is selected(it is selected by default ).
5. Choose the folder file that you need to export to PST.
6. Mention an appropriate date in the 'Archive items' box. All the items and files which has been received earlier until the mentioned date will be archived.
7. In the Archive File,  click on the option and then provide the destination path to store the new PST.
8. Click on OK Button to complete the export process.
Hope this helps!
vMail OST to PST Converter is a powerful tool to quickly recover corrupt offline Outlook data from OST file and convert to Outlook PST file with ease. Users can also convert OST to MBOX, MSG, EML, EMLX, vCard & vCal file formats and export recovered OST mailboxes (Emails, contacts, calendars, tasks, journals, deleted items, notes & attachments) to Office 365 account or Exchange Server. This tool easily supports all different versions of MS Outlook (2016, 2013, 2010, 2007) OST file of any size. Download available Demo of the OST to PST converter for free of cost to convert limited 30 emails per folder
Read More & Download - OST to PST Converter
If you are not accessing your offline data files and your OST data files got corrupted or lost. In that situation, you have one solution to restore corrupted files which is converter tool.
If you have lost all hopes to recover OST data files, you can search OST to PST converter tool on google and watch the video tutorial on youtube.
Thanks
Regards
Rihana smith
Lots of software exists in online market to convert OST files into PST format but I suggest you to download PDS OST to PST Converter. You may also convert OST files into MSG, EML, MBOX, HTML and PDF. With the help of this software you can save data according to “date+ subject, from+ date, subject, date+ from+ subject”. It splits oversize PST file into small size PST file upto 5GB.
Get Software- OST to PST Converter
I recommend you appropriate PDS OST to PST Converter that safely & easily repair damaged OST file after that convert into six different formats like PST, EML, MSG, HTML, PDF and MBOX. This application is recently updated and contains new features. During conversion time you can split oversize PST file from 1GB to 5GB as well as compatible with all edition of MS Outlook (2016).
If you want to migrate your OST file to PST format, then you can take help of third party OST to PST converter tool to instantly convert all OST mailbox data like emails, calendars, task, journal, etc. into PST file format. It save OST mailbox data to different file format like PST, MBOX, EML, DBX, MSG and etc. User can get more information, visit from: http://www.free.osttopst.org
Get the effective tool to convert OST file data into an Outlook PST format. It's easily recover your corrupted or inaccessible OST files, data and gives the reliable or accurate result to the user. This tool provides user friendly interface, without any technical knowledge you can use this tool very simple and it gives result as your requirement. The tool support all versions of Windows Operating system and MS Outlook.
Get more details about this tool visit:- https://www.sysinfotools.com/ost-to-pst-converter.php
Try a professional OST to PST Converter software to recover your severely corrupt/damaged OST file along with its entire email properties. It also helps users to convert recovered OST file to Outlook PST, EML, DBX, MSG, MBOX, etc. file format. The software offers hassle-free conversion of OST file and its data items including emails, attachments, contacts, drafts, notes, calendars, etc. into PST format. For more information, visit from: http://www.free.osttopst.org
Advance OST to PST Converter software with which you can choose both multiple and single OST files to perform conversion. The tool is easy to use and convert OST to PST in very less time. Because of its easy user interface the tool is much preferred among users and its time saving part is also favorite among users. See full details at: https://www.datavare.com/software/ost-to-pst-converter-expert.html
OST to PST Conversion is not an easy task but with OST to PST Converter, it is very easy to convert Offline OST files to PST format along with attachments. This software is completely free from all types of risks. It provides 100# error free conversion without losing a single bit of data information. Migrate OST to PST without any file size limitations.
Know more visit: https://gallery.technet.microsoft.com/ost-to-pst-software-b0b40cc1
OST to PST Software is the best way to convert OST files to PST format with easy manner. The software supports with all the editions of Microsoft Outlook. The best part of this tool that it comes up with simple graphical user interface that helps users to convert OST files without any technical support.
For more info visit: https://gallery.technet.microsoft.com/ost-to-pst-software-b0b40cc1
Whenever you are in need to convert your corrupted OST mailbox including inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). You will be suggested to use ATS OST to PST Converter which has numerous features; it allows you to export the OST data into Live Exchange Server and Office 365.
Visit more details:   http://www.bulkecommerce.com/page/ost_to_pst_converter-12.html
Best OST to PST Converter software allows you to easily recover Microsoft Outlook mailboxes from corrupted Offline OST file. This tool has very easy to use interface and provides fast data recovery and OST to PST conversion. You can convert any size of OST file from different versions of MS Outlook (2016, 2013, 2010, 2007 & more older versions ). This software can convert OST to PST, MBOX, MSG, EML, EMLX, vCard & vCal file formats. This tool can make inaccessible OST file accessible with all Outlook data like emails, contacts, calendars, tasks, journals, attachments, deleted items etc without any data loss.
Download - http://download.cnet.com/vMail-OST-to-PST-Converter-Software/3000-2369_4-77746438.html
Just grab OST to PST converter software for extract single and multiple file from inaccessible OST database and convert them into healthy MS outlook with all version of PST file like as:- 97/98/2000/2003/2007/2010/2013 and 2016. Stella 2013 OST to PST Recovery software is reliable 3th party tool for recovering corrupt OST file data after that it will allows to save/restore OST emails into new healthy PST file with its items as inbox/outbox/sent mails/junk mails/deleted mails/journal/task/notes/contact and calendar as well as it also divide large size of recovered PST file into small PST file upto 5GB.
For Further Detail Please visit here:- https://gust.com/companies/sdr-ost-to-pst-converter
OST to PST converter freeware Software recover all corrupted file database very easily. This is the best & convenient software to bulk export offline OST files to PST file format. MS Outlook installation is not need to use this OST to PST Converter Software to convert OST to PST Outlook file.
