PST to NSF Conversion
pst to nsf pst converter nsf files pst files pst to nsf converter
  • Please log in to reply
3 replies to this topic
#1 JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 167 posts
Posted 16 August 2017 - 05:17 AM
To convert Outlook PST to Lotus Notes NSF, use a third party conversion tool, SysInfo PST to NSF Converter gives data accuracy and security. At the time of conversion, entire data should be migrated containing original properties. Various tools are available for conversion task but preservation of all original properties, attachments, read / unread status etc is supported by only reliable PST to NSF converter product.
Source link:- Convert Outlook PST to IBM Notes NSF.
  • AnthonyPoelf and ronnykingTib like this
#2 Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 93 posts
Posted 16 August 2017 - 01:21 PM
For Advance PST to NSF converter, you can try an another software that will seamlessly convert the PST to NSF Lotus notes. I know there many other software available but this PST to NSF converter work very fast. I found out a very incredible, that if your PST files are filled with unused data and you want to convert some selective emails from that PST files and convert them from PST to NSF files.
Visit: http://www.nsfsecuri...pst-to-nsf.html
#3 chen24
  • Members
  • PipPip
  • 27 posts
Posted 28 October 2017 - 04:47 AM
If  you are looking for PST to NSF converter then download this software , this software will help you to convert your PST file to NSF file format. You can download here - http://www.pst.nsffile.org/
#4 amazsilong
  • Members
  • PipPip
  • 15 posts
Posted 21 November 2017 - 07:58 AM
New Outlook PST to NSF Converter is a proficient conversion utility that can efficiently convert all Outlook tasks, emails, contacts, notes, calendars, and even more into Lotus Notes NSF platform.You can choose particular date range to export calendars and filter them in desired time frame. It adds more convenience by including this functionality.  With PST to NSF Converter, you can migrate easily from Microsoft Outlook to NSF Lotus Notes.
Also tagged with one or more of these keywords: pst to nsf, pst converter, nsf files, pst files, pst to nsf converter
