Windows Live Mail stores email messages in EML format and Windows Outlook stores emails data in PST format. Both are different file format, and conversion of EML file to PST format is not a easy task. In that situation user use the technique which gives the output according to your requirement, I suggest you can read this blog post for EML to PST conversion which can provides easy freeway solution for conversion.
I hope the recommended post will helps you, get more details visit here:- Import EML file into PST.
If you are looking for the manual solution of EML to PST then try the below manual steps.
1) Open MS Outlook and Windows Live mail.
2) Now click File > Export email > Email messages.
3) Select Microsoft Exchange and click Next.
4) The message will be appeared from Windows Live Mail to Microsoft Outlook or Microsoft Exchange then click OK.
5) Choose any option under the “Select the mail folders which you want to export from Windows Live Mail and click OK.
6) After the process completed, click on the Finish and now, check the exported emails data in the Microsoft Outlook email client.
For other manual tricks you can visit:  Manual tricks of EML to PST
If you are looking for the best EML to PST conversion solution then you have one perfect option to use any software. EML to PST Converter offers the safest way to import mailbox data of EML files to a new file format that is  PST file. During the entire EML to PST conversion process this software that the ability to preserves all the Meta data and original file structure of the selected files. Mail and more to Outlook PST format.
Get Windows Live Mail to PST tool which can also convert your all EML file of different email clients like windows live mail, apple mail, mozilla thunderbird, outlook express to Outlook PST file format.It extracts all the essential email components like To, Bcc, Cc, Sent, From, Received, Attachments, etc.Also support all Windows 98, NT, 2000, 2003, 2008, Xp, Vista, Windows 7, Windows 8.1, Windows 10.
Free demo available at :
https://gallery.technet.microsoft.com/convert-emlx-to-pst-f45d2687
Get the latest software to convert EML to PST format instantly by using the best third party tool EML to PST converter. It can safely migrate the entire email data saved in EML files to PST format. Use the precise solution which offers multiple advance features. These features are so helpful to export all the EML data in PST format. You can download this software from here - https://www.sysessential.com/eml-pst-converter/
Try VOOK EML to PST Converter
It is a three step method by using which user can extract the EML documents into PST layout. Three steps to convert the EML documents into PST format are: –
1.       Select the single EML file or multiple EML files containing folder.
2.       Pick the destination folder within the device where the transformed files are saved.
3.       Click on convert for the migration of EML to PST format.
You can import multiple EML/EMLX in Outlook PST. If you want to Convert your EML file to PST or EMLX to Outlook PST then you can download softaken EML to PST converter software. This is a very good solution provided for converting and import multiple EML and EMLX files in Windows Outlook PST file format. To download this software or know more about this visit here:- http://www.softakensoftware.com/eml-to-outlook-converter.html
Hi,
In order to convert EML to PST format, users need to choose the best tool i.e. ZOOK EML to PST Converter. It is one of the finest solution for users to convert multiple EML files into PST format. The tool can efficiently export EML files to PST along with attachments.
It is the best tool which enables user to convert EML files of any version of Windows Mail to Outlook.
For More Info: - https://gallery.technet.microsoft.com/Batch-Convert-EML-to-PST-570ecdb5
You can also try EML Converter that can convert EML files to PST format without any issue. This converter is the best utility for users that safely and securely convert complete data from EML to PST format with attachments and formatting. EML Converter contains lots of extra-benefits like- preview facility, batch facility and free demo version facility. To understand the software nicely and deeply you can use the free demo facility.
I got fed up with the old software and wanted to use some new and interesting software, then I came to know about EML to PST Converter and it gives me the amazing output. All get set in very less time. Good software and I think its a good decision to switching from other software. You can also try it:- http://www.eml.pstfile.org/
EML Converter provides the best solution to convert EML file to PST other file formats without corrupting any of data. The tool export EML emails to along with attachments. It allows bulk conversion to save the time and energy. It gives multiple file naming options to save PST file as per the requirement. It has the search option to search particular EML files easily. The tool compatible with all the versions of Windows OS. With this converter, you can store resultant file to the desired path. Visit here for info:-  https://www.softknoll.com/eml-to-pst-converter/
Is your EML file inaccessible, Need to transfer EML file from one computer to another? Want to convert EML file to PST? If the answer to any of the above question is yes, then look no further. With the help of EML to PST Converter, you can easily convert an EML file to PST format and seamlessly transfer the EML file data to whichever computer you wish to. EML to PST Converter quickly converts all the EML data including emails, contacts, calendars, notes & Journals without damaging the structure of the EML file. For more details please visit:- http://www.osttopstapp.com/eml-to-pst.html
