How to repair OST file And Convert OST to PST?
  • Please log in to reply
4 replies to this topic
#1 jackpauls
jackpauls
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 August 2017 - 06:20 AM
Download & Use OST to PST Converter Software that is great software that simply fixes OST file errors and recovers OST data into outlook file with original messages formats- TXT, HTML and RTF. This software is remarkable tool which provides you selective emails conversion process in which you can select emails from OST File one by one and can export into three formats – EML, MSG or HTML.You can test the software on any version of Windows operating system for any version of MS Outlook and MS Exchange server.
This software has awesome support with Microsoft Outlook all version such as 97,2000,2002,2003,2007,2010,2013,2016 as well as Windows upto Win 10 (32 & 64 bit ).
For download visit on :- https://click4download.wordpress.com/ost-to-pst-software/
  • ronnykingTib likes this
#2 I'm batman
I'm batman
    Member
  • Members
  • PipPip
  • 18 posts
Posted 04 August 2017 - 10:56 AM
If you are Looking for  OST to PST Converter and OST the recovery Software then you should try the OST to PST Converter It will provide you some excellent features which make the  Conversion process of OST to PST files quick and easy , it can also recover the  OST file from corrupt state to normal and make it in readable form. OST to PST Converter software provides the user-friendly platform is very easy to use interface. The software also available as a free version you can try that.
#3 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 86 posts
Posted 08 August 2017 - 05:10 AM
OST to PST Converter software is best solution for converting and recovering database from Exchange Server OST file format to PST file format. Conversion will help you to transfer all items like emails, contacts, to do list, journals, tasks, attachments and calendars etc. Today I am suggesting you a tool that will not only convert OST to PST but also helps you to transfer your database from OST file to PST, EML, DBX, MSG and MBOX file format.
See more info at:-  OST to PST Converter Software.
#4 Alisa Smith
Alisa Smith
    Member
  • Members
  • PipPip
  • 15 posts
Posted 30 August 2017 - 09:53 AM
The OST to PST converter software enables data recovery from the corrupted OST files into outlook personal files. This recovery software is helpful in recovery and you have lost all hopes to recover information. It converts all types of corrupt files of MS office email clients. It can thoroughly scans the offline contents of OST file and converts the same into the PST file. This has interactive GUI feature which repairs the OST files and helps you to select the one you need to convert into PST file.The trial version is free of cost which enables you to know the features of the tool which helps you in perfect OST to PST Converter.
For more information visit: https://www.edbmails.com/
#5 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 57 posts
Posted 13 February 2018 - 12:10 PM
Look here OST to PST Converter software is easy and faster process. It OST to PST converter software is an email recovery software that ability to recover and restore email messages, folders, appointments, contacts, meeting requests, tasks, distribution lists, journals and notes efficiently. This software help you to 100% guaranteed recover and it software supports MS Exchange Server 2016, 2013, 2010, 2007, 2003, 2000.
