Outlook PST to NSF Conversion
pst to nsf pst converter lotus notes nsf files convert pst to nsf
  • Please log in to reply
7 replies to this topic
#1 JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 167 posts
Posted 11 July 2017 - 04:44 AM
PST to NSF Converter is most reliable and appropriate email migration tool, that can securely convert Outlook databases file to Lotus Notes NSF format. You can easily and safely move all your messages and other information MS Outlook PST to Lotus Notes NSF documents. The tool convert all Outlook items like emails, contacts, calendars, tasks, journals, etc to NSF file format.
Download free demo version of this tool, here:- PST to NSF Converter
  • ronnykingTib, KeithHeelf, Michaelreush and 2 others like this
#2 Estaltboobe
  • Members
  • Pip
  • 4 posts
Posted 19 July 2017 - 09:09 PM
Google Apps for Business or Google Mail?
GAPPS and Outlook should use the Google Apps Outlook Sync tool to sync all your contacts, calendars, tasks etc.
Free Gmail accounts obviously cant do this.
Also If you need not expensive Carfax alternative with photos – try this website http://wellvin.com . Glad that I found it.
#3 Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 93 posts
Posted 20 July 2017 - 12:20 PM
For Advance PST to NSF converter, you can try an another software that will seamlessly convert the PST to NSF Lotus notes. I know there much other software available but this PST to NSF converter work very fast. I found out a very incredible, that if your PST files are filled with unused data and you want to convert some selective emails from that PST files and convert them from PST to NSF files.
#4 JackyBoo
  • Members
  • Pip
  • 8 posts
Posted 26 July 2017 - 12:09 PM
If you want to convert PST to NSF format, you should try nUpgrade.exe utility. It's a part of Lotus Notes Migration Tools which you can find in the directory of Notes clients program. By using nUpgrade.exe utility, you can successfully migrate your personal email data, contacts and other information from Microsoft Outlook to Lotus Notes without any external support. To know more about nUpgrade.exe utility and how to use it, refer to article - Import Outlook to Lotus Notes - Convert PST to NSF
For quick, effective and safe results, you can also try a professional solution. Download PST to NSF Converter software that can convert PST to NSF format without causing any alteration to the original mailbox content. It can successfully export email messages, contacts, calendars, and other mailbox content from PST file into a new NSF database file. You must download its demo version for free evaluation. By using demo version, you can save first 50 mailbox items of each mailbox folder of selected PST file.
#5 Wolf_gang
    Advanced Member
  • Members
  • PipPipPip
  • 42 posts
Posted 03 August 2017 - 09:20 AM
Why not you check out this article where they have mentioned manual procedures to convert Lotus Notes files to MS Outlook.
"So why pay for third party tools when you can do it for free"
Article name: Easy Manual Tricks To Export NSF To PST
#6 bretliwalker
  • Members
  • PipPip
  • 27 posts
Posted 13 October 2017 - 10:57 AM
I would like to suggest you to use PST to NSF converter software which is designed to migrate Outlook PST file to Lotus Notes NSF format. Download from http://download.cnet...4-77453614.html
#7 SIMON11
  • Members
  • Pip
  • 6 posts
Posted 28 October 2017 - 07:14 AM
New PST to NSF Conversion Software is a proficient conversion utility that can efficiently migrate all Outlook tasks, emails, contacts, notes, calendars, and even more into Lotus Notes NSF platform.You can choose particular date range to export calendars and filter them in desired time frame. It adds more convenience by including this functionality.  With PST to NSF Converter, you can migrate easily from Microsoft Outlook to NSF Lotus Notes.
#8 Wayne Hogue
Wayne Hogue
  • Members
  • PipPip
  • 10 posts
Posted 20 February 2018 - 06:53 AM
Try this free PST to NSF Converter to export MS Outlook PST files into Lotus Notes NSF format with attachments. The software provides user friendly interface so that any user can easily and quickly import PST files from MS Outlook to IBM Notes NSF without altering the original formatting and folder structure. Download this Free PST to NSF Converter software so that users can evaluate and analyze the complete working environment and functionality of the software.
Download, here:- https://gallery.tech...verter-87a40fc2
Also tagged with one or more of these keywords: pst to nsf, pst converter, lotus notes, nsf files, convert pst to nsf
