NSF to MBOX Converter
nsf to mbox nsf converter mbox files convert nsf to mbox nsf files lotus notes
  • Please log in to reply
7 replies to this topic
#1 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 84 posts
Posted 06 July 2017 - 08:53 AM
Lotus Notes NSF to Apple Mail MBOX Conversion would be easy if you are using professionals NSF to MBOX Converter Tool. It successfully exports emails, messages, calendars, contacts, to-do lists, tasks, notes, etc. to a new MBOX files at user-defined location. If you have multiple NSF database files, you can select all of them and perform their batch conversion in just a single cycle. You can save you time by using this Software.
Download the free version of this software, here:- http://www.nsfsecuri...sf-to-mbox.html
  • Clintonlog, Steveavaic and XTHighamjak like this
#2 Phillcalls
Phillcalls
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 10 July 2017 - 04:32 AM
You can download any NSF to PST converter software if want to export email data items saved by IBM Lotus Note email client application to an Outlook PST format. I would like to request download SysInfoTools Software NSF to PST Converter Tool
But If you’re looking to convert NSF to PST without any expense then try to use freeware solution that also can be used to export NSF emails, messages, contacts, calendars, appointments and other items to Outlook PST format. To view more detail visit: NSF to PST Converter Tool
#3 Abrienne
Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 13 July 2017 - 11:04 AM
To convert Lotus Notes to Outlook, there are two ways either Manually or Using any Lotus Notes to Outlook Converter.
Going by a manual way there are two easy step
  1. Export Lotus Notes data Files.
  2. Then Import Lotus Notes NSF files to Outlook
Visit for the complete manual process here: http://easytechtools...utlook-manually
You can also go for Lotus Notes to Outlook Converter, which is nowadays a very common Software in use to convert NSF file to Outlook PST files. This NSF to PST converter does the conversion in time saving and easy way.
#4 bradhaddin
bradhaddin
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 26 October 2017 - 06:42 AM
There are multiple solution available for converting NSF to MBOX file format. You can google this solution. Last time used a solution for same issue and got great result with this NSF to MBOX tool. I will recommend you to downoad this NSF to MBOX software from here
http://www.osttopsta...nsf-to-pst.html
#5 chen24
chen24
    Member
  • Members
  • PipPip
  • 14 posts
Posted 29 November 2017 - 11:20 AM
Lotus Notes NSF to MBOX Converter is an efficiently used software when coming to change the working email client environment from Lotus Notes to Numerous MBOX supported clients such as Thunderbird, Apple Mail, Windows Live Mail etc. Download NSF to MBOX Converter and safely convert Lotus Notes NSF database without causing any alteration or modification to the original mailbox content.
Download free trial version of this tool, here:-  https://www.sysessen...mbox-converter/
#6 ardentaylor65165
ardentaylor65165
    Member
  • Members
  • PipPip
  • 13 posts
Posted 16 December 2017 - 09:07 AM
Export NSF files to PST is simple & secure software which can fluently convert NSF files to Outlook PST format without any extra efforts. The NSF to PST Convertersoftware is designed in such a process which easily convert NSF file data such as calendar, address book, draft, notes, meeting, task and Outbox into PST Outlook like MSG, EML, MBOX, CSV, HTML, EMLX and EMLX save it in need segment without data losing. It is possible to export various large NSF files to PST. It is fluently convert Address book into various formats that is PST, MSG, and CSV file without data damage. It has also available as a free version. Try to use free demo version:
#7 annietaylor
annietaylor
    Member
  • Members
  • PipPip
  • 16 posts
Posted 30 December 2017 - 06:55 AM
If you are a Lotus Notes user and you want to Convert NSF to MBOX in simple way then no problem, we designed a new and latest NSF to MBOX Converter Software which make your conversion procedure easily and fast. It has features to Converts all calendar items, NSF mails, contacts, to-do list, journal etc. This software saves converted mail items folders as MBOX, MSG, or EML files format. It supports Lotus Notes 6.0, 6.5, 7.0, 8.0.2 and 8.5 and try its Free Trail Demo Version and evaluate the software completely.
#8 ardentaylor65165
ardentaylor65165
    Member
  • Members
  • PipPip
  • 13 posts
Posted 10 January 2018 - 06:30 AM
NSF to PST Converter is an efficient tool for converting Lotus Notes NSF file to importable MS Outlook PST files. The tool has instructive user interface that guides you throughout the conversion process. In this way, you can easily migrate from Lotus Notes to MS Outlook by exporting all your emails, contacts, attachments, journals, etc to Outlook PST file.For more information follow this link: https://www.paidsoftware.download/nsf/
Also tagged with one or more of these keywords: nsf to mbox, nsf converter, mbox files, convert nsf to mbox, nsf files, lotus notes
