jackdashack Posted July 3, 2017 Report Share Posted July 3, 2017 [ UPDATE: unfortunately this query has been spammed as you see if you scroll down. It's loading my Gmail Inbox and SPAM folder so I came back here and made my default as no email notification. However this has been solved if you look over the first 4 or 5 messages. With a complete un/re install. ":-Dx jackI once scheduled the Cleaner to run Auto. I have went back into settings and un-ticked the Schedule part and anything else I can see that makes it auto run but it will not stop? It runs when the pc is idle. Do I need to remove a services or what? Task manager does not show it as starting at startup? Thanks! ArtiomGenic, Steveavaic, Garthesone and 17 others 20 Link to comment Share on other sites More sharing options...
xilolee Posted July 4, 2017 Report Share Posted July 4, 2017 Hi jackdashack. :-) Are you using wise disk cleaner 9.49.669 (i.e., the latest version)? Installed or portable? Did you download it from wisecleaner.com? Or what website from? What OS are you using? jackdashack 1 Link to comment Share on other sites More sharing options...
jackdashack Posted July 5, 2017 Author Report Share Posted July 5, 2017 Hi jackdashack. :-) Are you using wise disk cleaner 9.49.669 (i.e., the latest version)? Installed or portable? Did ou download it from wisecleaner.com? Or what website from? What OS are you using? Thanks so much! I will put this to bed. I'm sure your questions are relevant but here's what I did. I contacted the staff of Wisecleaner and they suggested that I uninstall and reinstall. While radical I think this got the problem to go away. However what caused it wasn't discovered. Again, I do appreciate your time and patience. Jack ":-Dx Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 5, 2017 Report Share Posted July 5, 2017 Hey, Good to know that your problem has been solved. Any question, please feel free to contact us. Thanks, xilolee jackdashack 1 Link to comment Share on other sites More sharing options...
xilolee Posted July 5, 2017 Report Share Posted July 5, 2017 jackdashack 1 Link to comment Share on other sites More sharing options...
jackdashack Posted July 7, 2017 Author Report Share Posted July 7, 2017 yeah, I know xilolee, it was the quick fix not the root problem. Sometimes you just want to get it working and move on. Thanks for your probe into the real problem. ( do you know why I can't seem to upload a profile photo? It shows the name but the image doesn't appear? ) Link to comment Share on other sites More sharing options...
