Convert ANSI to Unicode PST
upgrade pst upgrade outlook pst files convert ansi to unicode
  • Please log in to reply
3 replies to this topic
#1 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 98 posts
Posted 29 June 2017 - 05:42 AM
PST Upgrade utility quickly performs ANSI PST to UNICODE PST. The Software is enhanced with an advanced conversion algorithm that support batch operations to convert PST files. It can safely convert PST files without causing any alteration to the original files and folders. The software supports all higher or lower versions of Microsoft Outlook email client application.
Check the free trial version of this tool, here:- Convert ANSI to Unicode PST
  • AnthonyPoelf, AndrewSeink, LarryHoirm and 3 others like this
#2 Abrienne
Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 99 posts
Posted 03 July 2017 - 10:31 AM
Outlook files created with MS Outlook 97-2002 versions are ANSI PST files. MS Outlook 2003 & above versions offer greater storage capacity for Outlook items and folders. As there is no automatic way of converting a Microsoft Outlook 97-2002 ANSI PST to UNICODE PST. The easiest way to convert an ANSI PST file is to create a new data file in the Microsoft Outlook Personal Folders file PST format that supports Unicode and then import items from the old data file to the new Microsoft Outlook Personal Folders file PST.
Check more info at-
Upgrade Outlook PST Files.
#3 shelly10
shelly10
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 06 April 2018 - 05:46 AM
You can easily Convert ANSI PST Files to Unicode PST Files format as well as your contacts and Calendar info with advanced Upgrade PST Software. By using this Software you can also Convert Unicode PST to ANSI format as per your requirement. The software enhanced with advanced conversion algorithm that supports batch operations to convert PST files.
#4 mackjohn
mackjohn
    Member
  • Members
  • PipPip
  • 23 posts
Posted 16 May 2018 - 10:45 AM
The older versions of Microsoft Outlook store entire data into ANSI pst file and The Outlook 2007 and later versions store data into Unicode pst format. So if a user has older pst files and wants to upgrade. Then he/she can do by the manual method. Read the complete article which explains the difference between these files and methods to convert.
Visit blog: - https://queries365.w...icode-pst-file/
Also tagged with one or more of these keywords: upgrade pst, upgrade outlook, pst files, convert ansi to unicode
