DBX to PST converter tool helps to recover and repair corrupted Outlook Express files and smoothly convert to Outlook PST format. This tool allows users to perform batch conversion at a time. This is easy to use application which is smartly design both technical and non technical users. Download the free trial version of this tool and check the preview of recovered data here:- Convert DBX to PST Format.
Check out the link:  https://goo.gl/dhBoUH  to learn the popular manual methods- Import Emails to Windows Live Mail and Export Emails to Outlook which gives the outstanding result in conversion of DBX to PST.  These manual methods are for the users who are searching for the free solution of DBX to PST they can use these manual methods and without any worries import all the DBX file data into PST format.
If you're switching from Outlook Express to Outlook, you must convert DBX to PST format in order to access your old email messages. Instead of using a paid solution to convert DBX to PST format, first you should try a couple of easy manual tricks to import email messages from Outlook Express to Outlook.
  • You need to use Windows Live Mail here. It has both import and export features. By using Import feature, you can import email messages from Outlook Express to Windows Live Mail. And by using its Export feature, you can export them to MS Outlook client.
  • MS Outlook client has an Import feature which you can use here. By using that feature, you can successfully import email messages from Outlook Express.
Refer to this blog post for complete information - DBX to PST Conversion – Migrate Outlook Express to Outlook
You can also use a professional converter tool for DBX to PST conversion if you're looking for easy and quick solution. Try smart DBX to PST Converter software. It can safely convert DBX to PST format without causing any alteration to the original mailbox content. You must download its free demo version first to 25 email messages of each selected DBX files into new PST files.
Thanks and best regards.
Yes, that's true if the manual way is available then one must go for the same for DBX to PST conversion. Manual way cost no penny and conversion is complete in just a few steps.
1. Export Outlook Express files and download and configure Windows Live Mail
2. Import files in Windows Live Mail
3. Export Windows Live Mail files to MS Outlook.
For more follow: Manual Trick for DBX to PST Conversion.
You can use this free DBX To PST software , this software will help you to convert emails from DBX to PST file format. This is a free to convert your all emails from DBX to PST.This alter DBX to PST means displays advertizement of all your semiprecious mail items, thereby providing you a look of the literal rebirth results early. You can verify the table of these mails antecedent to saving the converted mails. More information visit here http://www.osttopstapp.com/dbx-to-pst.html
The DBX to PST converter tool provides effective features to convert Outlook Express file to Outlook PST format. The tool also support corrupted and invalid DBX file and recover data from it. The tool also support single or multiple file at a time and it's designed for both technical and non technical users. Read more and Download free demo version of this tool here:- https://www.softknoll.com/dbx-to-pst-converter/
