burn Posted June 27, 2017 Report Share Posted June 27, 2017 BUG !!! Link to comment Share on other sites More sharing options...
xilolee Posted June 29, 2017 Report Share Posted June 29, 2017 I updated IMEI driver, but the restore center still show I'm using the previous version (I still didn't close the program, nor reboot the machine). After I restarted the program, I can't see its previous version (old and actual versions have the same number). The driver residue still won't show completely in English, but it shows completely in Italian (maybe I translated it shorter than in English). And I still can't see the files: it shows it can remove 879.9MB. Other glitches due to the longer translation: Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 5, 2017 Author Report Share Posted July 5, 2017 BUG !!! Thanks for your feedback. As you know wise driver care is a brand new product, Sometimes, the nearest server of you may not contain the driver you want, so you will receive failure message, but the server will auto download the driver from main server, people around you more and more to use wise, the server will contain more drivers. Please try it after 24 hours. Link to comment Share on other sites More sharing options...
roger_m Posted July 5, 2017 Report Share Posted July 5, 2017 I had already tried again with no success. However, I just tried again. The driver was downloaded, but installation failed with the following error: Wise Driver Care launched the actual setup file from Intel, rather than trying to automatically install it. Also, I found that for some reason Driver Genius does not find the same driver update. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 5, 2017 Author Report Share Posted July 5, 2017 I updated IMEI driver, but the restore center still show I'm using the previous version (I still didn't close the program, nor reboot the machine). After I restarted the program, I can't see its previous version (old and actual versions have the same number). The driver residue still won't show completely in English, but it shows completely in Italian (maybe I translated it shorter than in English). And I still can't see the files: it shows it can remove 879.9MB. Other glitches due to the longer translation: Thanks xilolee. 1, Incorrect version ID, we knew it and will fix it soon. 2, You said there were 3 text area too short to display words. I checked them, 2 have added tips feature, left only 1. We will fix it soon. Link to comment Share on other sites More sharing options...
xilolee Posted July 16, 2017 Report Share Posted July 16, 2017 Pc checkup: it says I have 5 residual files, but I still can't check what they are.Rescue center: storage still doesn't show itself completely (but the tooltip works).Hardware detection:- scroe is written instead of score.- first string says imedia s2870DESKTOP: true, but a space is missing before desktop.- in the monitor entry, Resolution isn't translated in my language. After half hour past the new installation, I received this error: ---------------------------Microsoft Visual C++ Runtime Library---------------------------Runtime Error!Program: D:\Program Files (x86)\Wise\Wise Driver Care\wdcpnp.exeR6034An application has made an attempt to load the C runtime library incorrectly.Please contact the application's support team for more information.---------------------------OK--------------------------- Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 17, 2017 Author Report Share Posted July 17, 2017 Thanks xilolee, we will fix it soon. Link to comment Share on other sites More sharing options...
geogeo.gr Posted July 18, 2017 Report Share Posted July 18, 2017 1. Can you give more space to the menus, because the Greek language has long words? 2. In phrases that are cut in various dialog boxes, when the mouse passes over it doesn't show the whole phrase. 3. In the phrase "Install the OS with Ghost or over-clean the system will make the driver fail to install..." what exactly means the "over-clean"? 4. Hardwares report does not write correctly the Greek. In picture seems to be and how it should be. Link to comment Share on other sites More sharing options...
badtoad Posted July 20, 2017 Report Share Posted July 20, 2017 Downloaded latest version today and after check up it says fix one item but there is nothing to fix displayed and fix does not work. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 21, 2017 Author Report Share Posted July 21, 2017 Hey badtoad, Thanks for your feedback. Can you give me a screenshot? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 21, 2017 Author Report Share Posted July 21, 2017 Hey geogeo.gr, Thanks for your feedback. I will send your suggestion to the developer team, I think it will be fixed in next update. Over-clean, it refers to a Windows system lost many components, only keep the basic components. For example, some customization system doesn't have sample video/pictures/music, finally this customization system only is 8 GB or less, very small than a normal system. Link to comment Share on other sites More sharing options...
roger_m Posted July 21, 2017 Report Share Posted July 21, 2017 Have you read this post? http://forum.wisecleaner.com/index.php?/topic/13105-new-product-wise-driver-care/page-2&do=findComment&comment=29464 Link to comment Share on other sites More sharing options...
badtoad Posted July 21, 2017 Report Share Posted July 21, 2017 Heres the screen shot. Link to comment Share on other sites More sharing options...
xilolee Posted July 22, 2017 Report Share Posted July 22, 2017 Hi badtoad. :-) Click on the arrow near "all device drivers have been updated": you'll probably see it finds "driver residues" and want to delete them. Link to comment Share on other sites More sharing options...
xilolee Posted July 22, 2017 Report Share Posted July 22, 2017 New released version 2.1.720.1002: - Pc checkup: it says I have 5 residual files, but I still can't check what they are. - Rescue center: storage still doesn't show itself completely (but the tooltip works). - I'd like to have expandable windows (i.e., possibility to maximize the main window) and to have a portable version (if this is feasible). Link to comment Share on other sites More sharing options...
badtoad Posted July 22, 2017 Report Share Posted July 22, 2017 Xilolee thanks.I am going to keep the residue just in case I have a driver issue. Thomasemard, VictorRex, BrianDob and 3 others 6 Link to comment Share on other sites More sharing options...
badtoad Posted July 22, 2017 Report Share Posted July 22, 2017 Badtoad cleaned up the residue but first checked using driver store explorer. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 24, 2017 Author Report Share Posted July 24, 2017 I had already tried again with no success. However, I just tried again. The driver was downloaded, but installation failed with the following error: DG Intel.png Wise Driver Care launched the actual setup file from Intel, rather than trying to automatically install it. Also, I found that for some reason Driver Genius does not find the same driver update. Sorry, I missed it. Can you export your hardware information and send it to me? You can do it from Hardware Detection. Thanks Link to comment Share on other sites More sharing options...
geogeo.gr Posted July 24, 2017 Report Share Posted July 24, 2017 Update Greek translation to WDC 2.1.720 WDC_greek.zip Link to comment Share on other sites More sharing options...
ArrowDown Posted July 25, 2017 Report Share Posted July 25, 2017 Hello everybody, I am the creator of the program directory site. We make various reviews on the programs Recently stumbled upon Wise Driver Care A very good program, we recommend it to users of our site. Strictly speaking, and the review itself http://wise.driver-care.ideaprog.download/ Pretty cute interface I see progress in design Link to comment Share on other sites More sharing options...
roger_m Posted July 26, 2017 Report Share Posted July 26, 2017 Can you export your hardware information and send it to me? WiseDriverCareHdReport.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 8, 2017 Author Report Share Posted August 8, 2017 WiseDriverCareHdReport.txt Hey roger_m, Sorr for the delay. We added a new driver for your graphic card, please try to check up again. If you don't know to select which one, please give a screenshot of the driver list. Thanks. Link to comment Share on other sites More sharing options...
roger_m Posted August 8, 2017 Report Share Posted August 8, 2017 Hey roger_m, Sorr for the delay. We added a new driver for your graphic card, please try to check up again. If you don't know to select which one, please give a screenshot of the driver list. Thanks. Now, Wise Driver Care does not find any driver updates. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 14, 2017 Author Report Share Posted August 14, 2017 Now, Wise Driver Care does not find any driver updates. Cannot connect the server? or every device is updated to the latest? Link to comment Share on other sites More sharing options...
roger_m Posted August 14, 2017 Report Share Posted August 14, 2017 Cannot connect the server? or every device is updated to the latest? Every device is the latest, so it no longer finds an update for my video card. Link to comment Share on other sites More sharing options...
