wisecleaner_admin Posted June 15, 2017 Report Share Posted June 15, 2017 New released beta version - Wise Driver Care We are very excited to announce the release of Wise Driver Care beta! Download and update outdated Windows devices drivers! Wise Driver Care can automatically scan, download and update drivers. Easily fix missing, outdated or faulty driver errors. Keep your computer in top condition! 1, Supports more than 600,000 devices and drivers Such as AMD APU/Graphics/Chipset/AHCI/USB 3.0/RAID Drivers, NVIDIA drivers, Realtek ethernet controller/wireless lan/network/HD Audio Drivers, Intel Audio/HD Graphics/WLAN/LAN/chipset/rapid storage technology/USB 3.0 Drivers, ASUS Drivers, Dell Drivers, HP Drivers, Intel PC Drivers & Microsoft Windows Drivers 2, Reduce system freezing and crashing. 3, Wise Driver Care only recommend WHQL drivers. 4, One-stop Windows driver management. 5, Easily fix sound & network issues Click here for direct download Wise Driver Care beta. However, there is still space for improvement for this beta version, please leave a comment or write down the bugs you found below. We would really appreciate that. Thank you! Release Notes:******************* v1.0.621 (June 22, 2017) 1, Optimized network connection2, Minor GUI improvements3, Added 4 language files 4, Minor bug fixes View antivirus scan report ******************** v1.0.713 (July 14, 2017) 1, Fixed minor bugs 2, Added some new language files 3, Minor GUI improvements view antivirus scan report ******************** v2.1.720 (July 20, 2017) The official version is released. ******************** Richardavany, JerrymOr, Garthesone and 45 others 47 1 Link to comment Share on other sites More sharing options...
Lurky McLurkson Posted June 16, 2017 Report Share Posted June 16, 2017 Excellent. Easy to understand, fast and clear, clean layout. Link to comment Share on other sites More sharing options...
roger_m Posted June 17, 2017 Report Share Posted June 17, 2017 I've found a spelling mistake. A driver update was found for "HP Computer TohchPad Driver." Of course, that should be "TouchPad" Link to comment Share on other sites More sharing options...
roger_m Posted June 17, 2017 Report Share Posted June 17, 2017 Another issue that I've found, is that after installing driver updates, the status is not updated to show that the drivers have been been installed - it still shows there are driver issues. Link to comment Share on other sites More sharing options...
beta1 Posted June 18, 2017 Report Share Posted June 18, 2017 I used the cleaning function for drivers and afterwards my touchpad stopped working. Will it be free in the future? Link to comment Share on other sites More sharing options...
xilolee Posted June 18, 2017 Report Share Posted June 18, 2017 Hi wisecleaner_admin and everybody. :-)I'll put in green color my concerns and the concerns of other possible users I saw in the past.When the program is scanning the system (Detecting the driver information), I can see:Driver management- Abnormal Drivers What's this?- Updatable Drivers- Special Software What's this?- Unsupported DevicesDriver residueAfter the scan it shows:Driver management- All device drivers have been installed! What do you have installed without my consent?- Updatable Drivers (2)- Special software has been installed! What's this? What do you have installed without my consent?- All devices are enabled! I'd suggest instead: "All devices are enabled and supported by the right drivers!"Driver residue:Found 34 driver residual files for a total of 520.8...Here the text is cut, maybe because I'm using 150% custom scale.The tooltip/hint doesn't appear, showing me what's there after the dots.Unwanted files left by driver updates.Then there's a clean button. I still don't know if those 520.8 are bytes, kilobytes, megabytes or gigabytes, and I won't click that button until I know what I'm deleting.Therefore the suggestion here is to provide a "see the files" or "details" button.As always, I don't like:- I can't resize the program main window- It isn't portable.The support center is present in two places (at top and in toolkit): isn't it redundant?I'd change the default driver backup folder to something like %UserProfile%\documents\WiseDriverCare Backups. The storage location in the rescue center under the backup button isn't visible (the tooltip/hint works, at least): consider to increase its width. The WiseDriverCareHdReport.txt (hardware detection - export hardware info) should be put in the desktop. It could have been generated inside WiseDriverCare folder, if it were a portable application.Somewhere in the program (and in the website) a sentence should state where the drivers will be collected from.After using the "network failure" function (in toolkit, fix device issues), I tried the "no sound failure" and it gave a window with these strings:@sounttool_title@soundtool_repair_text@soundtool_repair_button Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2017 Author Report Share Posted June 19, 2017 I've found a spelling mistake. A driver update was found for "HP Computer TohchPad Driver." Of course, that should be "TouchPad" Can you give me a screenshot of it? I didn' find it in language file. Thanks. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2017 Author Report Share Posted June 19, 2017 I used the cleaning function for drivers and afterwards my touchpad stopped working. Will it be free in the future? Thanks for your feedback. Did you try to restart system? When we release the official version, some features wil be locked. But, you can download driver update for free. Link to comment Share on other sites More sharing options...
roger_m Posted June 19, 2017 Report Share Posted June 19, 2017 Can you give me a screenshot of it? I didn' find it in language file. Thanks. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2017 Author Report Share Posted June 19, 2017 Hey xilolee, Thanks for your feedback. 1, Abnormal Drivers What's this? It refers a driver issue which can be solved by reinstall / update driver. 2, Special Software What's this? Special software, it refers a driver/software for some special function which Windows system does not offered, you need to install it manually. E.g., touchpad, fingerprint. 3, All device drivers have been installed! What do you have installed without my consent? Wise Driver Care only check up whether all devices have installed drivers. 4, Special software has been installed! What's this? What do you have installed without my consent? Like 3, wise driver care only check up, won't install anything without your action. 5, All devices are enabled! I'd suggest instead: "All devices are enabled and supported by the right drivers. No, it only checks up the device is enabled or disabled. 6, Found 34 driver residual files for a total of 520.8...Here the text is cut, maybe because I'm using 150% custom scale.The tooltip/hint doesn't appear, showing me what's there after the dots. We will fix it sooner. 7, The storage location in the rescue center under the backup button isn't visible. Did you click the greed words "Modify"? 8, The WiseDriverCareHdReport.txt (hardware detection - export hardware info) should be put in the desktop. Good idea, we will fix it soon. 9, All drivers are collected from device providers, and certified by WHQL 10, Language issue, we will fix it soon. Link to comment Share on other sites More sharing options...
beta1 Posted June 19, 2017 Report Share Posted June 19, 2017 Thanks for your feedback. Did you try to restart system? When we release the official version, some features wil be locked. But, you can download driver update for free. Several times with no change, had to reinstall the T-P. Are you interested in a translation to Swedish for a free license of the paid version? VictorRex 1 Link to comment Share on other sites More sharing options...
xilolee Posted June 19, 2017 Report Share Posted June 19, 2017 Hi beta1. WiseCleaner team usually offers a (one year?) license key to the official translator of one of their programs. Read Help Us Translate and Get A License Key (click). Nonetheless, wait for an official answer by WiseCleaner_admin. @WiseCleaner_Admin: thanks. The underlying suggestion about those sentences is to find more user-friendly words. ;-) Link to comment Share on other sites More sharing options...
beta1 Posted June 19, 2017 Report Share Posted June 19, 2017 Hi beta1. WiseCleaner team usually offers a (one year?) license key to the official translator of one of their programs. Read Help Us Translate and Get A License Key (click). Nonetheless, wait for an official answer by WiseCleaner_admin. @WiseCleaner_Admin: thanks. The underlying suggestion about those sentences is to find more user-friendly words. ;-) Ok. VictorRex 1 Link to comment Share on other sites More sharing options...
Lurky McLurkson Posted June 19, 2017 Report Share Posted June 19, 2017 Excellent. Easy to understand, fast and clear, clean layout. I'm sure people think I'm a plant, as I posted first, but I really didn't have any problems with it. Interesting to see what others have experienced. Link to comment Share on other sites More sharing options...
badtoad Posted June 20, 2017 Report Share Posted June 20, 2017 Trying to add a Intel custom graphics driver to ignore list but seems not to work.Windows 10 64bit version 1607 on Toshiba Satelite P55W is my setup. Link to comment Share on other sites More sharing options...
badtoad Posted June 22, 2017 Report Share Posted June 22, 2017 Upgraded to newer version .620 over .613 and seems to have fixed ignore problem,although still showing older version.I also have been using support through program.They keep telling me there is a message but there is none. Link to comment Share on other sites More sharing options...
badtoad Posted June 24, 2017 Report Share Posted June 24, 2017 Latest version 621 seems have corrected the incorrect version shown problem.Don't know if message problem has also been fixed. VictorRex 1 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 25, 2017 Author Report Share Posted June 25, 2017 Hey badtoad, I'm not sure, please help us to check it. Thanks. VictorRex 1 Link to comment Share on other sites More sharing options...
Lidgeu Posted June 25, 2017 Report Share Posted June 25, 2017 Hello everyone, I'm localizing in French Driver Care (as all the other Wise products ) beta version 1.0.621. Such job generates many restarts of the program "under translation" (to validate step by step the "well fit" of the French into the program GUI). I noticed that suddenly that, if Driver Care processes are starting on the launch icon click, the Driver Care main windows did no appears on the PC screen. I mean that wisedrivercare.exe and wdcservice.exe are active in the Windows Tasks Manager processes list but looks like being in background only (so useless because not accessible ). This occurs randomly after a couple of close/restart !! OS : Windows 7 64bits By definition, a beta version is unstable , but I think this issue should be solved before official releas Isn't ? Pierre le Lidgeu Link to comment Share on other sites More sharing options...
badtoad Posted June 25, 2017 Report Share Posted June 25, 2017 Not sure how to help explain? Also reliability monitor is triggering every time I open program.Stability problem maybe? VictorRex 1 Link to comment Share on other sites More sharing options...
roger_m Posted June 26, 2017 Report Share Posted June 26, 2017 Another bug I've found is that the driver "Intel Graphics Driver" 8.15.10.1930 (display is shown as Mobile 945 Express Chipset Family in Device Manager) fails to download. Andrewwak, KeithHeelf, Shauntest and 20 others 22 1 Link to comment Share on other sites More sharing options...
badtoad Posted June 26, 2017 Report Share Posted June 26, 2017 roger_m if your computer uses a custom graphics driver installed by the manufacturer driver update software will not install a generic driver because it will cause issues. Link to comment Share on other sites More sharing options...
roger_m Posted June 26, 2017 Report Share Posted June 26, 2017 roger_m if your computer uses a custom graphics driver installed by the manufacturer driver update software will not install a generic driver because it will cause issues. My computer does not use custom drivers. In any case the issue with Wise Driver Care is unable to download the driver update it finds. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 26, 2017 Author Report Share Posted June 26, 2017 Another bug I've found is that the driver "Intel Graphics Driver" 8.15.10.1930 (display is shown as Mobile 945 Express Chipset Family in Device Manager) fails to download. Can you tell me your location or your IP address? Thanks Link to comment Share on other sites More sharing options...
roger_m Posted June 26, 2017 Report Share Posted June 26, 2017 Can you tell me your location or your IP address? Thanks Australia. It is the only driver which fails to download. I've had no issues downloading any other drivers on a number of computers. Link to comment Share on other sites More sharing options...
