How to Deal and Fix EDB File Error Code â 528 Successfully
  • Please log in to reply
6 replies to this topic
#1 billyhasty
billyhasty
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 14 June 2017 - 05:00 PM
EDB to PST Converter software is great program that effectively recover exchange EDB File and Convert exchange EDB file to PST File without problem. it can easily recover exchange mailbox and convert exchange mailbox to PST file with journals, calendars, task, inbox items, outbox items, draft, notes, zip attachments, embedded image and other attachments of EDB file in few seconds without wasting their precious time. it can simply convert Exchnage mailbox (.edb) into PST , MSG, EML file format. This software can convert both online and offline EDB mailboxes to PST in a quick and proficient manner.
Click Here and Download Free Demo Version
This application use to recover and migrate the corrupt EDB mailboxes from Exchange server to Microsoft Outlook’s PST format effectively. With the help of this tool you can smoothly export exchange EDB to PST without breaking any internal coding- TXT, RTF, HTML.This Software helps you to Import Exchange EDB to PST and gives you authority to access on Exchange EDB file.This Software successfully repairs damaged OR corrupted Exchange (priv1.) EDB file in order to convert EDB to PST outlook without facing any issues. it can Easily recover exchange server data from EDB to PST Converter Tool user can easily store unlimited emails in priv1.EDB or STM files.this Application very helpful recovering all types mailbox database from Exchange EDB file and convert them into Outlook (personal storage table) with restoring all emails from EDB to Outlook.
It also allows you save the converted data in several other formats like RTF, HTML and PDF. This tool helps to pick up all EDB emails between 2 dates “to date” to “from date” without any difficulty. It allows you recover the deleted or lost mailboxes with EDB to PST converter in offline conversion mode.Best option to convert Exchange server (.edb) data into Outlook (.pst) file format,This application is genuinely program which instantly scans all the corrupted exchange email items in order to move them into outlook file. This software maintains the data truthfulness of exchange EDB file during exchange data recovery.
I, hope this information is more helpful to all frustrated users who want best result in recovery of lost EDB file emails and also makes EDB file in readable mode.
This tool help to successfully removes all fix error and convert EDB data into PST, EML, MSG and HTML in just a few second. This software easy to recover emails, attachments, contacts, calendars, tasks, etc. from corrupt EDB files.
Download Now :- https://exchangeedb2....wordpress.com/
  • kamnimishra likes this
#2 kamnimishra
kamnimishra
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 25 July 2017 - 03:36 PM
Wow great post i like it because it's help for me
Thanks !!!
#3 Alisa Smith
Alisa Smith
    Member
  • Members
  • PipPip
  • 16 posts
Posted 27 July 2017 - 11:52 AM
EDB to PST Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application. It supports MS Exchange Server Recovery for 2003, 2007, 2010, 2013 and 2016 corrupt and unmounted database.
Recovers Calendar, Attachments, Drafts etc., from the damaged EDB files
EDB to PST Exchange server Recovery tool helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc. from the damaged EDB files. Its ease of use GUI enables you to preview recovered mail items.
- Recover / Restore only required Mailboxes
- EdbMails capability of granular / brick-level mailbox EDB to PST conversion support, will help you to recovery any desired Mailboxes data.
- Automatic handling of PST file size limit
- If the Outlook PST file reaches size limit then, EDB to PST Converter will automatically split the PST file into multiple files based on the size limitation of the Outlook PST.
- Recover Deleted Mailboxes
- Edb to PST converter can easily recover mailboxes, which have been deleted knowingly or unknowingly.
- Recover and Save as EML, MSG format
- In addition to saving the recovered data as PST file, it also allows you to save the recovered data as MSG, EML formats.
Find quick answers to your queries
To Download application Click here
To know more about the EdbMails Visit here:
#4 John11
John11
    Advanced Member
  • Members
  • PipPipPip
  • 76 posts
Posted 28 July 2017 - 06:41 AM
Great post.  But if you want to fix all the EDB file errors using manual tricks then read this article: Manual conversion of EDB to PST. Here you will know the manual method that makes the users to easy convert normal or corrupt EDB file into PST file format.
You can also visit here: Manual conversion of Data Recovery and Email Conversion to learn the best methods to solve all the errors from various computer related files and the simple email conversion techniques to convert various email files to other email files format.
Hope this information will help you.
#5 ThomasShubert
ThomasShubert
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 03 August 2017 - 06:35 AM
Download EDB to PST Converter Software is the world best solution to recover damage EDB File issues and Convert into PST/EML/MSG and HTML with internal coding like as :- RTF/HTML and TXT. This application has strength to Export single one and limitless EDB Mailboxes Data to Outlook with all email attachment/properties/journal/embedded image/appointment and body information etc. This application divide your oversize of recovered PST File and make small PST File from 1 GB to 5 GB then you can open and read recovered PST File from all MS Outlook (UNICODE or ANSI).This software also endow free demo version to Extract 25 EDB Email per folder into each formats.
Get More Information So Visit Here :- http://bit.ly/2viPICW
#6 elviraperry
elviraperry
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 17 April 2018 - 05:27 AM
Exchange Server database files (EDB) can be converted Outlook PST files, but this Professional EDB to PST converter allows exporting EDB files both offline and online which makes it stand out among other competitors.
#7 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 186 posts
Posted 17 April 2018 - 08:33 AM
Recoverydatatools - EDB to PST migration is a surpassing way to recover corrupt EDB data and move EDB file to PST file format without any loss data. More details see here: http://www.recoveryd...-converter.html
