Anjum Posted April 8, 2017 Report Share Posted April 8, 2017 Hi ! Dear friends I am using Dell inspiron i5 laptop. The problem is my system is not identifying battery. the Baterry was 100% charged and now drooping 1 unit as standby position. friends my laptop battery neither charged nor works. the massage showing 'plugged in but not charging'. Please help what i should do, my laptop battery starting works? Thanks. sizekani, cloncuche, Jabzooge and 3 others 6 Link to comment Share on other sites More sharing options...
Mikeethestud Posted June 4, 2018 Report Share Posted June 4, 2018 Take out the battery, remove the dust and then plug it again the laptop and then try if it is charging Link to comment Share on other sites More sharing options...
harvey_43 Posted June 16, 2018 Report Share Posted June 16, 2018 Whenever the system doesn't recognize the AC adapter, the battery WILL NOT charge. If you haven't yet tried a new OEM Dell adapter, that's the first thing to do. If that doesn't get and keep the adapter recognized, replace the DC power jack in the system. And if that fails to solve the issue, replace the mainboard. The adapter completes a charge circuit with a center wire. If that charge circuit is not closed, the battery WILL NOT charge, even if the adapter powers the system. Link to comment Share on other sites More sharing options...
jamesmehraa Posted September 25, 2018 Report Share Posted September 25, 2018 Sometimes charge gets stored in capacitors that affect power follow. So try these steps it might help you. First, you need to switch off your laptop and remove your battery. Unplug the power cable as well. Now press the power button and keep it pressed for 10-15sec. Now attach your battery and connect your laptop to your charge and see your problem must be resolved. Link to comment Share on other sites More sharing options...
alsen Posted November 12, 2018 Report Share Posted November 12, 2018 If it is in warranty period then contact your near buy call center. Link to comment Share on other sites More sharing options...
sony Posted November 22, 2018 Report Share Posted November 22, 2018 i have the battery problem too on my asus laptop. i have tryed all kind of tips, but not change the board or repair the powercircum or similar things... the last powerlevel was round about 75% - a good state to take out the battery and leave them anywhere. the next action was put it in the laptop after a while of time... and for a few seconds it tryes to load the battery and then abort and nothing in the end of the days i think the whole tips i read for battery rescue is bullshit - perhaps there only 2 reasons why the battery dont work 1.) the battery is gone or 2.) the charge circum is gone Link to comment Share on other sites More sharing options...
KaranJohar Posted November 23, 2018 Report Share Posted November 23, 2018 I have faced the same problem on my HP Laptop when I visited the service centre they said Your Battery is gone and It's not connecting to the Laptop. So I changed the battery and now It's working fine. Link to comment Share on other sites More sharing options...
Anjum Posted November 27, 2018 Author Report Share Posted November 27, 2018 Please no more suggestion. Thanks to all. Link to comment Share on other sites More sharing options...
ankit213506 Posted May 22, 2020 Report Share Posted May 22, 2020 Your battery is not showing the real percentage. Replace the battery with new one Link to comment Share on other sites More sharing options...
