donwise Posted March 4, 2017 Report Share Posted March 4, 2017 Hello. Windows 10 en 64, WHF version 4.12 I hide folder on USB flash, eject it, connect again. After connecting hided folder became visible. WFH shows folder path without drive letter. ChnloveMum, cloncuche, Jabzooge and 1 other 4 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 7, 2017 Report Share Posted March 7, 2017 Thanks for your feedback. we will fix it as soon as possible. Link to comment Share on other sites More sharing options...
donwise Posted March 14, 2017 Author Report Share Posted March 14, 2017 Hello. I upgrade to new version 4.13 — the problem is still here. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 14, 2017 Report Share Posted March 14, 2017 Yes, I saw it. The developer team told me, it is a unfixable problem (because of current Hidden method) If you want hide a folder in your USB drive, I recommend you to use Hide USB Drive function. If you are using Pro version, Encrypt Files is the best choose. Link to comment Share on other sites More sharing options...
donwise Posted March 14, 2017 Author Report Share Posted March 14, 2017 It's a bit strange Did the method of hidding change from the version 3.41? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 17, 2017 Report Share Posted March 17, 2017 Yes, it is different with 3.41 The old method is not stable, so wise folder hider 4 does not use it again. Link to comment Share on other sites More sharing options...
