WDCF Posted February 20, 2017 Report Share Posted February 20, 2017 it took the slimming scan to create restore point 185secs..and then it cleared. the claim of it being fastest scanner probaley reserved for pc's that have higher capacity hdd or something. VincentWraph, VictorRex, Michaelviono and 18 others 21 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 21, 2017 Report Share Posted February 21, 2017 You misunderstood Restore Point. Wise Care 365 doesn't create a Point, it just request Window system to create a Point. So, you should say Windows system took 185 seconds to create a restore point. If you have installed another similar cleaner, you can do a scan speed test. Link to comment Share on other sites More sharing options...
WDCF Posted March 4, 2017 Author Report Share Posted March 4, 2017 not concerned about restore points now. its about how fast the scan takes (advanced scan) mode. tonight, it took nearly 688 secs. yesterday, 657 secs. not trying to put down the namesake..just a nagging observation of how slow scan is. well...one cannot always have "perfection" Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 7, 2017 Report Share Posted March 7, 2017 well, the result was not good. But how many drives you choose to scan? and how many files that Advanced cleaner find out? Link to comment Share on other sites More sharing options...
