Convert PST to MBOX
pst to mbox pst to applemail pst to thunderbird pst to entourage outlook to apple mail pst to mbox converter
  • Please log in to reply
8 replies to this topic
#1 jameswold
jameswold
    Member
  • Members
  • PipPip
  • 26 posts
Posted 21 December 2016 - 10:02 AM
PST EXTRACTOR PRO is an easy to use migration tool which help you to convert PST to MBOX simply. It not only convert it to MBOX but also convert PST to Apple Mail, Thunderbird, Entourage, RGE and EML file format. It helps you in converting your entire mail database and also your contacts, reminders, etc.
To know more: http://www.pstextractorpro.com/
  • Rodneyroorm, DavidDiary, Patrickeffob and 2 others like this
#2 Abrienne
Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 90 posts
Posted 26 June 2017 - 08:29 AM
I recently found this blog about how to export PST to MBOX which also discusses the top 3  to Convert MBOX to PST. There are a lot of Third Party tools available online that convert MBOX to PST. But you must try out the manual way first
You would find here the ways to Export Outlook PST to MBOX file
on a single Machine
by Google Take Out and
by Gmail Synchronization
They are quite simple steps if done as mentioned.
Good Luck.
#3 BellaS021
BellaS021
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 04 July 2017 - 11:47 AM
I would like to share another software that I found when I was searching for some solution to convert Outlook PST files to MBOX. It is named PST to MBOX Exporter and it helped me immensely in converting all my PST emails to MBOX at once.
#4 chen24
chen24
    Member
  • Members
  • PipPip
  • 14 posts
Posted 18 December 2017 - 10:19 AM
You can easily convert your PST file to MBOX from MS Outlook to Thunderbird mail. As both file formats are used by different email clients so it is not easy to use PST file format into Thunderbird mail. To convert your PST file into MBOX for different email applications than it is mandatory to use third party tool PST to MBOX Converter. It easily resolves the problem of conversion from PST format into MBOX format.  To Know more : https://www.sysessen...mbox-converter/
#5 Phillcalls
Phillcalls
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 19 December 2017 - 04:24 AM
On web earth there're uncountable Tools which we can use to export all saved email information such as email, message, contacts, calendars, appointments, etc. saved by any email client application to various other in which we want. But here I am with fresh solution that name is Outlook PST Recovery Tool.
This tool performs multiple function and its primary work it to repair all damaged Outlook PST files created by Outlook 97, 2000, XP, 2003, 2007, 2010, 2013 and 2016. The another benefit of this tool is it lets user save the recovered PST files in various file such as in  PST, MSG, MBOX, DBX, and EML file format as per user requirement. So must check this tool once and place your view.
#6 calorina
calorina
    Member
  • Members
  • PipPip
  • 27 posts
Posted 19 December 2017 - 10:26 AM
Export Batch Files with PST to MBOX Converter Tool
Get ZOOK PST to MBOX Converter to batch convert Outlook PST to MBOX format. It directly export & import PST file to MBOX with attachments to read PST emails.
For more information visit: - http://www.zooksoftw...om/pst-to-mbox/
#7 Mellany
Mellany
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 22 December 2017 - 05:18 PM
Gladwev’s OLM Converter Pro is highly recommended to the users with massive amounts of data to convert OLM to MBOX Mail because of its unique abilities. It has the capabilities that other tools can only envy; it can quickly transfer multiple folders from Outlook Mac to Apple Mail at single instance while maintaining complete data integrity. Download demo version free. http://www.gladwev.com/portfolio/olm-converter-pro/
#8 jamon99
jamon99
    Member
  • Members
  • PipPip
  • 18 posts
Posted 29 December 2017 - 11:19 AM
PST to MBOX Converter for Mac provides a good platform for easy and precise email conversion from PST to MBOX file.The software supports Outlook PST to MBOX migration for Thunderbird, Spicebird, SeaMonkey, and Netscape.It also supports Outlook 2003, 2007, 2010, 2013. For more information visit here:  https://www.sysessen...mbox-converter/
#9 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 32 posts
Posted 10 January 2018 - 11:40 AM
Want to migrate Outlook Email to Thunderbird? try PST to MBOX Converter- a relevant solution for you to migrate Outlook email to Thunderbird with attachments in a single conversion round. The PST to MBOX Converter tool supports batch mode conversion option. This software maintains all the folder structure the whole conversion process. It has very simple user friendly graphical interface, so anyone can easily understand and work with software without any problem. This software supports all the Windows editions like- 2016, 2013, 2010, 2007, 2003, etc. editions. For more details please visit https://www.softknol...mbox-converter/
Also tagged with one or more of these keywords: pst to mbox, pst to applemail, pst to thunderbird, pst to entourage, outlook to apple mail, pst to mbox converter
