  • Please log in to reply
16 replies to this topic
#1 sandy11
sandy11
    Advanced Member
  • Members
  • PipPipPip
  • 55 posts
Posted 16 December 2016 - 07:03 AM
If you are thinking to convert the MBOX file of popular email clients application like- AppleMail, OperaMail, Sylpheed, Entourage, Thunderbird, Eudora and Spicebird etc. into PST, EML, MSG, RTF and HTML file formats then use the MBOX to PST Converter Software.
Features of MBOX to PST Converter Software-
1. Support large size MBOX file.
2. Simplified Interface.
3. Saves the snapshots of MBOX recovery process.
4. Wide support to all versions of Windows.
To know more information visit:  MBOX to PST Converter Software
  • pherhealf likes this
#2 JasonBates
JasonBates
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 19 December 2016 - 10:05 AM
As I have experience, this conversion is also possible through the manual guide. To know how it is possible, read the reference: http://www.stellarinfo.com/blog/free-method-convert-mbox-to-outlook-pst/
#3 JerryB
JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 30 December 2016 - 05:43 AM
MBOX to PST conversion via easy manual solution is secure, reliable and easy-to-use that transfer MBOX files of Thunderbird, Spicebird, Entourage, Pocomail, Eudora, Mulberry, Opera Mail, Mozilla Mail, Netscape, etc to PST file format. It effectively moves all mailbox data of these mail clients and all emails from MBOX files to equivalent Outlook PST files. It converts mailbox data to new or existing PST file.
Get more details about the manual solution visit:- Convert MBOX Emails into Outlook PST
#4 Blake Marky
Blake Marky
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 07 February 2017 - 11:59 AM
Export MBOX files of different email clients like AppleMail, Eudora, Spicebird, Sylpheed and others in PST file of any Outlook version upto 2016 by making use of MBOX to PST converter tool which offers highly advanced features on intuitive platform. It also avails saving options like Office 365, EML and MSG. To learn more about software click here: http://www.mboxtopsttool.com
#5 smithjon
smithjon
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 21 February 2017 - 04:43 AM
Try the best solution MBOX to PST Converter which provides advanced features to user by which they can easily migrate entire data items to MBOX to PST format in few seconds. This utility can extract all the email messages, attachments, images, contacts, calendars, notes, etc. of MBOX to PST format without any error.
More more your preference you can visit:- https://gallery.tech...verter-8e762aeb
#6 Venn
Venn
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 07 March 2017 - 05:52 AM
If user requirement to convert MBOX file to PST, so the user can use the manual and automated software. Manual method works for few file conversion, but if the user needs to export MBOX files to PST so use the automated converter. For more information MBOX to PST conversion try this: https://exportmboxtopst.codeplex.com/
  • Venn likes this
#7 jamessnow
jamessnow
    Member
  • Members
  • PipPip
  • 27 posts
Posted 07 March 2017 - 12:06 PM
MBOX to PST Converter software from SysInfo has the ability to convert large number of MBOX files via batch conversion mode. This Tool easily performs corrupt data recovery and the preview of file before beginning conversion process. Users can view converted emails in CSV format. It provides you with a stop solution for successful conversion of MBOX to PST files.
For free Download visit: MBOX to PST Converter
#8 jameswold
jameswold
    Member
  • Members
  • PipPip
  • 27 posts
Posted 15 May 2017 - 05:15 AM
Mail Extractor Pro an advance migration solution as Apple Mail to PST Converter which convert your entire mail database from Apple Mail, MBOX, Thunderbird, Gmail, Postbox to PST for Outlook(both Mac & Windows). It convert huge amount of data seamlessly into desired PST format without any lag and keeping your previous data safe and secure for further use. It also comes with an easy to use free trial version so one can experience the migration using this converter tool.
For more: http://www.mailextractorpro.com/the-best-mac-mail-to-pst-converter-for-a-simple-way-of-transferring-emails
#9 Wolf_gang
Wolf_gang
    Advanced Member
  • Members
  • PipPipPip
  • 42 posts
Posted 09 June 2017 - 09:47 AM
As I can see, everyone is suggesting you to go for a third party tool. Obviously these tools are good for DBX to PST conversion but you have to pay for it.
My problem is "Why Pay When You Can Convert MBOX To PST files Free"
Yes, there are manual techniques which are easy too....which can convert your MBOX files  to Outlook.
For a step by step procedure, you may check out this article where they have mentioned the manual method to convert your MBOX files to PST
Manual for MBOX to PST file Conversion
Hope this answer helps
#10 Abrienne
Abrienne
    Advanced Member
  • Members
  • PipPipPip
  • 99 posts
Posted 12 June 2017 - 01:00 PM
MBOX to PST converter software, which not only converts the MBOX files of many clients but also migrates them to Outlook clients.
Users have two options to convert MBOX file to PST format, first is Manual and second is third party software. To perform conversion of MBOX to PST by using the manual method you need multiple email clients as well as some technical knowledge. Another hand third-party Another hand's automated solution user does not need any technical knowledge to convert MBOX files to PST. So I recommended use this MBOX Converter software  to convert multiple MBOX files to PST.
Visit: http://bit.ly/2nmKOjo
#11 SteFun
SteFun
    Advanced Member
  • Members
  • PipPipPip
  • 68 posts
Posted 28 August 2017 - 11:23 AM
Instead of using a paid converter utility for MBOX to PST conversion, you should try an easy manual trick first. It requires no third-party paid tool or any cost. You can use the manual trick only if you're using Apple Mail client. I can share a blog post below that contains the detailed information about MBOX to PST conversion manually: MBOX to PST Manual Conversion – An Easy Tutorial | N. Sem's Blog
I hope the shared information would be helpful here. If the manual trick fail or doesn't work, then only you should try a professional MBOX to PST Converter tool. It can convert MBOX files into PST format without causing any alteration to the original data. You can use this software even if your MBOX files are corrupt. First you should download its free demo version which helps you save first 25 email items of each mailbox folders of MBOX file into new PST file.
Thanks and best regards.
#12 christian007gray
christian007gray
    Advanced Member
  • Members
  • PipPipPip
  • 41 posts
Posted 26 October 2017 - 11:28 AM
If you want to convert MBOX files to Windows Outlook PST format then you can easily convert your MBOX files into PST format with MBOX Converter Wizard. There are several products on web but my recommendation is best and advance converter tool. This tool is very affordable and provides conversion of MBOX supported all files into multiple formats.
It supports both MBOX profiles Files and easily converts both files into different emails client application. If you want to convert MBOX to Outlook PST then MBOX converter tool easily export MBOX to PST format without any data loss. Windows MBOX Converter tool provide an option to merge multiple Maildir or MBOX files of Thunderbird to Single as well as Multiple PST file format.
Features of MBOX Converter Tool
  • Effortless way to convert MBOX to 10+ files formats.
  • Bulk conversion option for export multiple MBOX files at Once.
  • MBOX Unique Converter migrate multiple MBOX files into Single PST Format.
  • Convert MBOX files into 20+ Email Client applications.
  • Quick and easily tool provide Data Preview option before conversion.
  • All-in-one MBOX converter supports multiple files.
You can also download for free this MBOX to PST Converter from the given below link:
https://gallery.tech...utlook-a695c498
#13 mattrenshaw
mattrenshaw
    Member
  • Members
  • PipPip
  • 22 posts
Posted 16 December 2017 - 09:34 AM
MBOX to PST Converter application for converting MBOX files of these email clients such as Entourage, Netscape, Poco male, Spicebird, Apple Mail, Postbox, Mac mail, seaMonkey, Opera mail into Outlook PST format,the software is able to export MBOX file to PST, EML and MSG file formats
Visit at ; https://www.mailvare...-pst-converter/
#14 calorina
calorina
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 16 December 2017 - 12:01 PM
VOOK MBOX to PST Converter is a reliable answer to convert the multiple MBOX files into PST. This software perfectly performs the conversion of records from diverse electronic mail customers like Eudora, Mac mail, and many others. And keeps the information integrity after the conversion too.
For more information visit: - http://www.vooksoftw...om/mbox-to-pst/
#15 jameseva99
jameseva99
    Newbie
  • Members
  • Pip
  • 9 posts
Posted 06 January 2018 - 12:07 PM
Best MBOX to PST Converter application which can smoothly transfer or move all emails and other MBOX files of Apple Mail to Outlook PST format within few clicks. It provides you with a stop solution for successful conversion of MBOX files into Apple Mail, Entourage, and Thunderbird or Power mail in Outlook PST file created importable perform.
#16 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 132 posts
Posted 12 February 2018 - 12:07 PM
Go for a reliable and easy to use wizard to convert emails from multiple Thunderbird files into Outlook PST file format using Thunderbird to Outlook conversion tool. It allows you to export several MBOX files into Outlook data file format in batch.
#17 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 132 posts
Posted 26 April 2018 - 12:41 PM
try this mbox to pst conversion https://www.softknol...-pst-converter/
Also tagged with one or more of these keywords: MBOX to PST Converter tool, convert mbox to pst, import mbox to pst, mbox to pst software, MBOX to PST Conversion
