OST to PST
OST to PST convert OST to PST conversion of OST to PST export OST to PST
  • Please log in to reply
21 replies to this topic
#1 sandy11
sandy11
    Advanced Member
  • Members
  • PipPipPip
  • 55 posts
Posted 08 December 2016 - 06:48 AM
You can convert your OST file into PST file by OST to PST Converter Software and manual methods which is easily available in the web. But sometime when you are new to internet world then it’s difficult to find the solution. Here I suggest the Exporting method manual steps that will help you to move or export all your OST file data into PST file in few minutes.
Manual steps of OST to PST are-
1. Open the MS Outlook application.
2. Click on File menu and select the Import and Export option.
4. Click on Export to file option and click Next.
5. Select Outlook data file and click Next.
6. Click on the parent root and check the Include sub-folders option.
7. Browse the folder and save file and click finish button.
To know the complete details about it and to find the other manual methods to convert OST to PST visit the blog link: Manual method of OST to PST.
  • sizekani, Stevenjek, Shawnroums and 1 other like this
#2 jamesstewart50
jamesstewart50
    Member
  • Members
  • PipPip
  • 24 posts
Posted 20 December 2016 - 12:30 PM
Recover corrupt or damaged OST file data, I would like to refer an excellent third party software, known as OST repair tool. The software is designed designed with an advanced and secure algorithm to deal with all issues related to corrupt OST file and also allows to convert OST file data into a PST file format. In addition, the software also enables its user to save data in various other file formats, including EML, MSG, RTF, TXT, MBOX, BDX, HTML and MHTML. To know more about the software, visit: http://www.osttopstfreeware.org
#3 annabeleva
annabeleva
    Advanced Member
  • Members
  • PipPipPip
  • 33 posts
Posted 08 February 2017 - 10:04 AM
The .ost and .pst file are the essential part of the Microsoft Outlook .Normally both have their own existence in Outlook because .ost mailbox created in offline mode with connecting to Exchange Server and .pst mailbox create on Outlook with direct get down of mails from server .
Why OST need to be convert into PST format .
When outlook ost corrupted than it can't open into Outlook ,but one possible way is exist for Outlook OST opening and that way is :- OST File Recovery to Outlook PST in which you have to recover and convert OST file into PST file format via any third party tool such as Enstella Outlook OST to PST Software .
Read more and download software from here :-  http://planet.infowars.com/technology/ost-to-pst-converter-from-enstella-systems
e8654b1e-3335-4f8d-99bb-e9790e1f2970-lar
#4 Johnbrad
Johnbrad
    Advanced Member
  • Members
  • PipPipPip
  • 84 posts
Posted 10 February 2017 - 05:15 AM
Try manual tricks for OST to PST Conversion, It's provide reliable and efficient solution for offline storage (OST) file to equivalent personal storage (PST) file. This method safely converts all mail items of Offline folder (OST) file and saves them in a new Outlook PST file, along with giving solution to save as EML, MSG, RTF, HTML file formats. The best techniques to recover and convert Offline OST file into outlook PST extension without modifying internal content and attachments.
More details here:- Convert OST to PST format.
#5 jamessnow
jamessnow
    Member
  • Members
  • PipPip
  • 27 posts
Posted 24 February 2017 - 10:54 AM
Hello,
For Few offline OST files you can just convert your OST files to PST by forwarding your Emails. Just email your PST items to your personal email address. Just select the items, then right click and choose forward. But, if you have many OST files, you could drag the files to a new folder in My Documents, then just zip the folder and email that zip file.
For the bunch of PST files, you are left with no options other than buying Third party tool. I used SysInfo OST to PST Converter.  The tool really gave the effective results and I am fully satisfied. If you wish you too can downlaod the free OST to PST Converter
Some of its Features are
  • Repairs Corrupted PST files
  • Low Footprints of Exe file. Hence Ultra-fast
  • Saves in different Format
#6 Venn
Venn
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 01 March 2017 - 10:22 AM
To extract data from corrupted OST file and export into PST format I suggested you use OST to PST converter software. This tool exact solution to recover & convert data from OST file to PST. The tool easily converts entire data of OST file into PST format without affecting folder structure of OST file.
#7 Dima Smith
Dima Smith
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 01 March 2017 - 02:41 PM
If you are searching the inbuilt solution to extract OST file to PST you can just try OST to PST Software that easy to fix damage OST file data and save OST file data into PST/EML/HTML/TXT/PDF/MBOX/RTF and outlook profile etc. this software also provide the selective option you can just select OST emails according to your need and convert OST file to each forma as PST/EML/MSG etc For more info search in google:- PDS OST to PST Software
#8 JerryB
JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 146 posts
Posted 24 April 2017 - 05:34 AM
OST to PST conversion is easy with the help of smart OST to PST converter tool. The tool effectively convert all OST file data and no matter if OST file is corrupted or in invalid state. The tool quickly and safely convert OST file to PST, MSG, EML, DBX and HTML format. It also provide wide range of advanced features that doesn't match any other alternative solution.
Read more information about this tool, here:- http://migrateemails...-to-pst-format/
#9 avisaston
avisaston
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 30 August 2017 - 09:36 AM
suggest best utility as a expert try GAEL OST to PST Converter software which is available with latest version. GAEL OST to PST Converter software upgraded version works fast and convert easily OST to PST secure without wasting time. It provides multiple options to save your OST files items into MSG,HTML,HTMLX,MBOX,EML,EMLX, OFFICE365 etc.
Download demo version :- http://www.products....h.com/osttopst/
#10 christinatwits
christinatwits
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 30 August 2017 - 09:02 PM
You can try once time this smart solution with advance OST to PST converter Software, then you get can get whole recover corrupted OST file into Outlook PST few seconds.
Technical Solution of OST to PST Conversion in a Simple Way Use Free Download OST to PST Converter Software
OST to PST Converter is an email conversion tool that has been designed to export ( Convert ) all the all items of OST file data like emails, contacts, calendars, etc. from an Exchange Offline OST file to Outlook PST file format, ensuring that the original formatting of the items is intact after conversion. The software is able to export data from corrupt OST and supports the recovery of deleted data from offline OST file.
http://www.osttopsts....com/microsoft/
#11 Alisa Smith
Alisa Smith
    Member
  • Members
  • PipPip
  • 13 posts
Posted 22 September 2017 - 11:29 AM
For the large bunch of Outlook PST files, You have to go for some OST to PST Recovery Tool. If you have no idea or still confuse which one to go for, then you may try EdbMail OST to PST Converter. The OST to PST Converter Tool exhibit some of the unmatchable features.
- Repairs Corrupted OST files
- Ultra-fast export of mails from OST to PST
- Allow Saving of OST files in different Format
For more information please click the link: https://www.edbmails.com
#12 girivmw
girivmw
    Member
  • Members
  • PipPip
  • 11 posts
Posted 25 September 2017 - 06:47 AM
If you are looking for ost to pst converter, then try 'OST Extractor Pro' for safe and clean migration.
Get more info: http://www.uslsoftwa...line-read-this/
#13 kimmiadward
kimmiadward
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 13 October 2017 - 02:04 PM
For the Convert large OST file into Outlook PST files format, You have to go for some third party OST Conversion Tool. If you have no idea or still confuse which one to go for, then you may try KDETOOLS OST TO PST Converter tool users help you to recovers inaccessible OST file database (emails, calendar, attachments, contacts, folders etc) and successfully Convert OST file into different file format - PST, EML, HTML, MSG, TXT, RTF, vCal, vCard, MBOX format without losing any data.
Read more blog: https://gallery.tech...utlook-0926b9a6
#14 loresroze
loresroze
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 23 October 2017 - 05:39 AM
Now, get most popular OST to PST Converter software through which you can give you full authority to remove Outlook OST file corruption issues to extract OST file data and able to save converted OST emails into PST, EML, EMLX, MSG, MBOX and HTML formats.
More details:   http://www.bulkecomm...ftware-159.html
#15 romantrump
romantrump
    Member
  • Members
  • PipPip
  • 13 posts
Posted 11 December 2017 - 11:50 AM
Get download of ost to pst software to recover ost to pst and for conversion .
This software recover ost file .
Convert ost file to pst file .
Split large size of pst file .
Free demo is available for conversion.
Supportive versions are ost 2016 ,ost 2013 ,ost 2010 ,ost 2007 ,ost 2003 ,ost 2000 ,etc .
Go for software :-
http://prsync.com/at...ftware-2132814/
#16 Prinamwill
Prinamwill
    Member
  • Members
  • PipPip
  • 22 posts
Posted 14 December 2017 - 11:52 AM
Remarkable OST to PST converter is the better program that easily performs to repair corrupted, damaged OST file and convert the entire repaired OST file items into new created PST Outlook file that you can directly open in MS Outlook application. There another formats available MSG, EML, HTML and many more format for conversion data OST file included- emails, contacts, calendars and appointments.
Get More info: http://www.esofttool...-converter.html
#17 robertbroads
robertbroads
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 21 December 2017 - 07:46 AM
To fix the OST file corruption error and issue you need to repair and recover OST file and make it readable file by using ATS OST to PST Converter software. This software allows to Convert to outlook PST from recover OST file with other file formats like MSG, EML EMLx, MBOx and HTML file format. It can also extract emails from OST file with all emails metadata, bcc, cc, date, time and subject etc. ATS OST converter tools supports MS Outlook version, Office 365, 2016, 2013 and all lower version and all latest  32 and 64 Bit windows Etc.
Visit more information:   Export OST to PST Converter
#18 calorina
calorina
    Member
  • Members
  • PipPip
  • 27 posts
Posted 25 December 2017 - 11:59 AM
VOOK OST to PST converter is the one 100% safe and the reliable answer for users with the aid of which customers can easily get their perfect resultant PST documents. The resultant PST documents without problems importable to any model of ms outlook. Common it is the straightforward solution by which users get the wonderful results.
For more information visit: - http://www.vooksoftw...com/ost-to-pst/
#19 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 32 posts
Posted 30 December 2017 - 07:50 AM
Checkout OST to PST Converter software is a reliable and efficient software to convert offline storage (OST) file to equivalent personal storage (PST) file. you can smoothly recover unreadable Outlook OST file and convert OST into PST file format with all Outlook OST file emails Meta data like: cc, bcc, to, from, date, time and subject etc.
#20 margrethevestager
margrethevestager
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 03 January 2018 - 01:10 PM
Looking for a best OST to PST Converter tool, which easily convert corrupted OST file or healthy OST file in Outlook PST formats. I am using this tool and my 89 GB OST mails data recover without any problem and restore all data in Outlook PST.
Visit more details:    ATS OST to PST Converter
step-3.jpg-acb81b406d383686235e2a254eda3
Also tagged with one or more of these keywords: OST to PST, convert OST to PST, conversion of OST to PST, export OST to PST
