  • Please log in to reply
85 replies to this topic
#21 girivmw
girivmw
    Member
  • Members
  • PipPip
  • 11 posts
Posted 06 June 2017 - 06:38 AM
To recover ost files (Items including Mails, contacts, calendars, tasks, notes, journal items etc) and convert into PST file, try 'OST Extractor Pro'. It will works even your OST file is damaged or corrupted. Try it here: http://www.ostextractorpro.com/
  • ronnykingTib and Robertweatt like this
#22 lucasdawson1984
lucasdawson1984
    Member
  • Members
  • PipPip
  • 13 posts
Posted 13 June 2017 - 04:53 AM
The need to export OST to PST is generally common among Outlook Exchange users, it is done in order to convert OST to PST file so that Outlook can read it. But Exporting and archiving are manual methods and maybe sometimes turn out to be difficult for certain users and these methods only work if you are planning on using the same computer and not change or upgrade to a new one.
I recommend using third party conversion tools like Sysinfotools OST to PST converter. Professionals advise for using these tools as they seamlessly convert OST files to PST files without any problem.
Hope this helps, feel free to ask any questions.
#23 girivmw
girivmw
    Member
  • Members
  • PipPip
  • 11 posts
Posted 15 June 2017 - 06:26 AM
Try this OST to PST Converter tool for converting and recovering your OST data file. Learn More - How to convert OST to PST in Outlook 2016
#24 samleesam0123@outlook.com
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 16 June 2017 - 11:56 AM
Download ATS OST recovery software that easy to resolve all types of corruption problem for OST file and perfectly recover and convert OST file emails data into PST file data with all folders items like as emails, calendar, notes, draft and contacts etc. It is 100% risk free solution which can instantly save recovered emails data into PST, MSG, EML, EMLX, MBOX and HTML formats.
get more details:http://www.bulkecomm...er-software/159
#25 SteFun
SteFun
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 06 July 2017 - 11:18 AM
If you want to convert OST to PST format, you should try few easy manual tricks. By using the manual tricks, you can import the mailbox content from OST files into new PST files. There's no need to use any paid software for that. All you need to use is just MS Outlook client, that's it. It has few built-in features which you can use here, such as Archive, Export to a new PST file, Move the items to a new PST file, and Drag & Drop. But before using any of these features, make sure:
  • You're using the same computer system on which the OST files were originally created.
  • Your Outlook profile is connected to Microsoft Exchange Server.
  • And most importantly, the OST files are not corrupt.
Refer to this blog post for complete information - Convert OST to PST Format using 3 Easy Manual Tricks | N. Sem's Blog
But if the manual tricks shared in the above blog post don't work for you due to corruption, you should try a professional solution. Download OST Recovery software that works as a recovery cum converter tool. If the OST files are corrupt and you want to convert them into PST format, you should definitely try this software. It can first recovery mailbox content from OST files, and then save them into new PST files.
Thanks and best regards.
#26 lukaswright
lukaswright
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 10 July 2017 - 04:54 AM
Hi,
Just try the most amazing third party tool OST to PST Converter which successfully exports OST mailbox data items into Outlook PST format. The utility has various splendid features which enables user to extract OST data items along with their data items into PST format. By using this tool, users can export multiple OST files into PST format and get their data back in Outlook instantly without any extra efforts.
For More Info: - https://gallery.tech...utlook-e1ea9bb0
#27 avisaston
avisaston
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 24 July 2017 - 04:05 PM
Securely save your OST data into PST via OST to PST converter software. No get to worry software gives you some simple steps to convert your Orphan Storage File and easily migrate into PST. After downloading Gael OST to PST converter software you see multiple option to save OST files into PST ,EML.MSG,MBOX,HTML. As per your choice choose any option and migrate OST to PST
 with ease without any trouble .
For more info visit:- http://www.products....om/ostrecovery/
#28 John11
John11
    Advanced Member
  • Members
  • PipPipPip
  • 60 posts
Posted 01 August 2017 - 06:57 AM
To repair the corrupt OST files and convert it to an Outlook PST files there are 2 methods- OST to PST Converter and manual tricks. Both these methods are very simple and help the users to convert OST file into PST file in an effective way.  But it’s very tough task to search both these methods, so here I suggest you to read article: Conversion of OST to PST where you will know all the complete information about OST file and the various conversion techniques of OST to PST.
#29 Alisa Smith
Alisa Smith
    Member
  • Members
  • PipPip
  • 13 posts
Posted 04 August 2017 - 11:48 AM
For the large bunch of Outlook PST files, You have to go for some OST to PST Recovery Tool. If you have no idea or still confuse which one to go for, then you may try EdbMails OST TO PST Converter. The OST to PST Converter Tool exhibit some of the unmatchable features.
Some of its Features are
- Repairs Corrupted OST files
- Ultra-fast export of mails from OST to PST
- Allow Saving of OST files in different Format
For demo version visit:
https://www.edbmails...ost-to-pst.html
For more information visit:https://www.edbmails.com
#30 Alisa02
Alisa02
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 08 August 2017 - 11:31 AM
Here, We share another effective OST to PST converter to fix the error of OST files and access them quickly. OST to PST converter software performs flawless OST file recovery and OST to PST conversion. This tool is capable of saving recovered files in PST, EML, HTML, and MSG formats. https://www.edbmails...ost-to-pst.html
#31 girivmw
girivmw
    Member
  • Members
  • PipPip
  • 11 posts
Posted 22 August 2017 - 08:38 AM
If you are planning export ost to pst, then try OST Extractor Pro'. Support large ost file and convert your data accurately.
Try this ost to pst conveter at http://www.uslsoftwa...ert-ost-to-pst/
#32 avisaston
avisaston
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 30 August 2017 - 09:56 AM
Reliable and best migration tool to convert OST to PST go with GAEL OST to PST Converter software. just with few clicks you get achieve your best result during conversion and get best accurate result. Grate tool to transfer heavy large OST files in just few minutes. GAEL OST to PST Single tool with multiple features survive your OST database recover deleted files and convert multiple formats like MSG,HTML,MBOX,EML,EMLX,HTMLX, OFFICE365.
Read More Info Here :-  http://www.products.gaelinfotech.com/
  • christinatwits likes this
#33 christinatwits
christinatwits
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 30 August 2017 - 08:40 PM
Easy to use OST to PST converter solution to Export OST to PST file within few steps....
Here I shared the link: Best Microsoft OST to PST solution for Export OST to PST from where you will learn the best and popular manual techniques such as- Exporting, Archiving and Move items to new PST file. You can choose any one of the techniques for the conversion of OST to PST.
To download the software free demo version, follow:- http://www.osttopsts....com/microsoft/
#34 esofttools
esofttools
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 02 September 2017 - 10:58 AM
Convert OST file notes into Multiple format OST Converter to PST Software provides multiple additional formats- PST, EML, MSG, HTML, vCard and EMLX to recover data for OST file along with emails, contacts, calendars, task, notes and appointments. This software easy to use and this tool support MS-office versions 2016, 2013, 2010, 2007, 2003, and 2000.
Read More:- OST Recovery PST
#35 esofttools
esofttools
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 04 September 2017 - 12:05 PM
If you want to recover your extract emails from deleted folders of corrupted outlook OST file so that easily recover deleted folders emails of OST files along with attachments. Then esofttools presents OST Recovery Tool whereby you easily repair, recover outlook OST Emails, contacts, calendars and appointments.
Read More :- OST Recovery PST
  • esofttools likes this
#36 girivmw
girivmw
    Member
  • Members
  • PipPip
  • 11 posts
Posted 07 September 2017 - 07:34 AM
Convert ost to pst using third party apps is quite easy and hassle free. One can try OST Extractor Pro for recovering and converting ost data.
Read More: http://www.ostextractorpro.com/.
#37 margrethevestager
margrethevestager
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 16 September 2017 - 07:44 AM
Third party OST to PST export tool has an amazing feature through which user can quickly convert OST file into PST file and in many more different formats and able to repair corrupted OST file and recover it properly without any risk. OST to PST Converter utility can handle any size of OST file and convert it without any hazel.
For more info, Visit:  OST to PST
#38 emilybrowning
emilybrowning
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 18 September 2017 - 12:41 PM
OST to PST software is the best option for you to repair Outlook OST file which is not open and inaccessible OST to PST tool help you to repair your corrupted file in short time period with fast speed and with perfect accuracy.  Also you can convert OST file into PST file as well as 5 more different formats like EML, MSG, HTML, EMLX and MBOX file formats.
For more info:  OST recovery
#39 brettleesons
brettleesons
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 19 September 2017 - 12:56 PM
This OST to PST converter software safely converts all mail items of OST file Offline folder and saves them in new Outlook PST file, along with giving multiple formats option to save as EML, MSG, HTML, EMLX, and MBOX. You can test the software all version of MS Outlook office-365, 2016, 2013 & all lower version.
Read more: http://www.bulkecomm...er-software/159
#40 james_warner
james_warner
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 27 September 2017 - 09:44 AM
For demo version visit: https://www.edbmails...ost-to-pst.html
Also tagged with one or more of these keywords: Export OST to PST, Convert OST to PST, OST to PST converter, Conversion of OST to PST, migrate OST file into PST, OST to PST free converter
