conversion of NSF to PST
conversion of NSF to PST Convert NSF to PST nsf to pst converter
  • Please log in to reply
38 replies to this topic
#21 tomrider
tomrider
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 15 November 2017 - 11:15 AM
try to best NSF to PST Conversion Tool. This  NSF Conversion tool to easily Convert Lotus Notes NSF file to Outlook PST.
more information Visit: NSF to PST Conversion tool
#22 santiano
santiano
    Member
  • Members
  • PipPip
  • 27 posts
Posted 06 December 2017 - 12:28 PM
The two known methods of conversion are there, first is manual and second is by NSF to PST converter tool. The manual method is, of course, free of cost, but it is a lengthy, time taking and tedious task, so conversion software is preferred as it is an easy, effortless, safe and effective process of migration.
#23 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 146 posts
Posted 20 December 2017 - 10:45 AM
NSF to PST Converter tool to migrate from Lotus Notes to Outlook. The software converts Lotus Notes file to Outlook importable PST file and provides option to save the mail items folder as PST, MSG or EML files format. It will support all version of Lotus Notes such as 6.0/ 6.5/ 7.0/ 8.0, 8.5, 8.5.3 and 9.0.1.
#24 max555
max555
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 23 December 2017 - 12:50 PM
With this tool of NSF to PST Converting you can easily convert From NSF to PST Emails file format this software will help you. Download link here : https://www.paidsoftware.download/nsf/
#25 alayenawill
alayenawill
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 17 January 2018 - 10:22 AM
A highly recommend application available online market, quickly download SysInspire NSF to PST Converter software which easily recover NSF file and export NSF to PST File. SysInspire NSF to PST Converter Software offers convert selective folders/ sub-folders to export data into PST and other formats such as- EML, MSG, HTML, EMLX, MBOX, vCal, ICS, vCard and many more format. It provides also free demo facility all users can freely use the software and convert NSF to PST File at free of cost.
Read more about: -  NSF to PST Software for NSF to PST Conversion to Convert NSF to PST
#26 jamon99
jamon99
    Advanced Member
  • Members
  • PipPipPip
  • 77 posts
Posted 18 January 2018 - 09:53 AM
An easy solution to convert NSF to PST is to deploy Export Notes Software which allows you to migrate each item of Lotus Notes like Emails, Contacts, Calendars, Journals etc. It supports all latest versions of Lotus Notes and Outlook too. Multiple NSF files can be easily exported to Outlook PST format. You can try the demo version of tool freely. Know more : http://www.datavare....ter-expert.html
#27 alayenawill
alayenawill
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 18 January 2018 - 11:06 AM
If you want to convert NSF to PST Outlook file so you can download the astonishing NSF to PST Converter software which effortlessly recovery of lotus notes NSF file and convert NSF to PST with maintains emails formatting, properties- to, bcc, cc, time, subjects and from. NSF to PST Software will convert all lotus notes NSF file to PST, EML, MSG, HTML, EMLX, MBOX, vCal, ICS and vCard format. Software supports all MS Outlook and lotus notes versions and not required outlook for NSF to PST Conversion.
Read more :- http://www.convertlotusnotesnsf.com/
#28 chen24
chen24
    Member
  • Members
  • PipPip
  • 27 posts
Posted 25 January 2018 - 09:53 AM
This conversion is also possible through manual method. But, it is not feasible for non-technical users.
Most of the users want to access their official lotus notes emails from Outlook. This requirement creates the demand of NSF to Outlook migration. In this situation, you can take help of third party tool like NSF to PST Converter.
You can also download its free demo from: https://www.sysessen...-pst-converter/
#29 jenniferhussain
jenniferhussain
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 20 March 2018 - 09:34 AM
All users can convert the lotus notes to outlook file, using this best NSF to PST Converter Software that securely perform to recover NSF file and convert NSF file to PST, EML, MSG, HTML, EMLX, MBOX, vCal, ICS, vCard and many more format with maintains folders structure and emails formatting/ properties. SysInspire NSF to PST Converter Software smoothly export NSF file to PST with maintains data integrity and never lose any information from lotus notes file. Software required lotus notes application and not required MS Outlook application for conversion NSF to PST File.
#30 alexaa
alexaa
    Advanced Member
  • Members
  • PipPipPip
  • 33 posts
Posted 27 March 2018 - 07:04 AM
convert your all NSF file data to Outlook PST file format completely with a reliable eSoftTools NSF to PST converter tool. It enables you to convert from Lotus Notes to MS Outlook PST without losing any data. This software has great efficiently to preserves the all original file data structure and saves converted files to PST EML, MSG, HTML, EMLX, ICS, MBOX, vCard and many more, format. You can convert.. you can use free demo version of software that converter 25 email each folder.
get more info:- NSF to PST
#31 selvi
selvi
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 27 March 2018 - 08:33 AM
Hi
If you're looking for a free solution to convert NSF to PST format, you can try an easy manual trick. Since Outlook doesn't support NSF database format, you just can't import or export NSF database directly to Outlook client. There's no manual trick that can help you convert NSF to PST format. But you can save NSF files' data into any such format which is supported by Outlook client. Luckily Lotus Notes provides you two file formats into which you can save your NSF files' data: Comma Separated Value and Structured Text. After that, you can easily import the new file into Outlook client by using its Import feature.
Refer to this blog post for more information - A Quick manual guide to Export Lotus Notes Email to MS Outlook
You can also try a professional solution if you're looking for a quick, easy and safe solution. Download free demo version of
NSF to PST Converter software to convert NSF database into PST format without causing any alteration to the mailbox content.
By using the demo version, you can save first 25 email items from each selected NSF database files into new PST files.
Thanks and best regards.
Selvi
#32 brookpotter56
brookpotter56
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 03 April 2018 - 06:54 AM
Lotus Notes to Outlook converter allows users to export unlimited IBM Notes NSF files to Outlook account . It successfully converts NSF to PST along-with text, attachments, folders and sub-folders, message properties like to, from, cc, bcc, sent/receive calendar, dates and times, items, task items, encrypted email and attachments. This tool provides facility to convert NSF file to TEXT and HTML file format because both of formats are simply accessible. See more -  http://www.nsf.topstconverter.com/
#33 alayenawill
alayenawill
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 18 April 2018 - 06:57 AM
NSF to PST Converter Software is 100% safe and secure that allows converting the emails from lotus notes NSF file into new created PST File. Using software extract every NSF emails, contacts, calendars, task, notes, inbox items, journals and appointments. Software perfectly convert lotus notes to Outlook, EML, MSG, HTML, EMLX, MBOX, vCal, ICS, vCard and many more format. For installing application there requirement of lotus notes application but not required of MS Outlook application to convert NSF to PST Outlook file with maintains all database.
#34 tomrider
tomrider
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 05 May 2018 - 08:36 AM
I Would like to suggest Download NSF To PST Converter Software, that software easily swift all Lotus Notes database NSF file to Outlook PST, MSG, EML, EMLX, MBOX, vCal, vCard, CSV and HTML file. Software capable easily export NSF file to office  365 & Live Exchange Server.
More information visit:  NSF to PST Converter
#35 marcobrown
marcobrown
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 05 May 2018 - 09:21 AM
Hi
If you want to convert NSF file to PST file format than you can go through freeware user friendly tool. There are various tool present in the internet.You can try this NSF to PST converter software for the for the best result.Earlier I use this reliable tool and get the very positive result.
Thanks
Regards
Marco!
#36 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 146 posts
Posted 14 May 2018 - 06:19 AM
NSF to PST converter Tool allows you to advanced converter solution for those who are facing corruption issue in Lotus Notes data files. Using this NSF to PST Converter Software you can easily and safely convert NSF file data into Outlook PST file format. To know more, you can download free trial version for 25 NSF emails to PST form our official website. visit http://www.osttopsta...nsf-to-pst.html
#37 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 228 posts
Posted 14 May 2018 - 01:06 PM
Using third party NSF to PST conversion tool you can easily transfer all NSF file to PST file format without hassle. To know more about NSF to PST conversion tool visit: http://www.recoveryd...-converter.html
#38 brizesaini
brizesaini
    Advanced Member
  • Members
  • PipPipPip
  • 146 posts
Posted 15 May 2018 - 12:46 PM
There are several options to Convert NSF to PST File but you have to require take the best solution here I am suggesting to download SysInspire NSF to PST Converter Software to Convert NSF to PST. NSF to PST Software will export lotus notes to outlook file, EML, MSG, HTML, EMLX, vCard, ICS and many more formats. Software also offers to convert selective NSF folders/ emails and convert multiple NSF files into any format with maintains all folders structure, emails formatting and emails properties- to, bcc, cc, time, subjects and from. visit http://www.osttopsta...nsf-to-pst.html
#39 blazecruze
blazecruze
    Member
  • Members
  • PipPip
  • 11 posts
Posted 19 May 2018 - 08:44 AM
NSF to PST Converter online software completely convert emails from NSF File into new created PST Outlook file, EML,MSG, HTML and CSV format. In software there several features are provided you can choose any feature to make good conversion of your NSF file included- emails, contacts, calendars, task, notes and appointments. Easily convert all contacts of NSF file into CSV format with maintains all data integrity. Software supports all NSF file versions and MS Outlook versions. visit :- https://www.softknol...-pst-converter/
Also tagged with one or more of these keywords: conversion of NSF to PST, Convert NSF to PST, nsf to pst converter
