Try the DBX to PST Converter Software that fast scans the multiple DBX files for error and after recovering all the data from it convert DBX file into PST file. This tool also protects the new generated PST file by giving the advance feature of password protection.
See more at: DBX to PST Converter Software
If you're looking for a free solution to convert DBX to PST format, you can try an easy manual trick. Though the manual trick doesn't convert DBX files into PST format, but you can migrate from Outlook Express to Outlook with ease. The manual trick doesn't require any paid software or any other cost. You just need to use Windows Live Mail application, that's it. Windows Live Mail application has both Import and Export features which help you import email messages from Outlook Express client and export them to Outlook client. If you don't know how to do that, you can take help of this blog post - Convert DBX to PST Format Manually – 3 Easy Steps | N. Sem's Blog
The manual trick is easy and effective, but sometimes time-consuming, especially when you have thousands of email messages stored in the multiple DBX folders. In such situation, you should try a professional converter utility. Download free demo version of DBX to PST Converter software that can convert single as well as multiple DBX files into PST format within a few minutes. It's a safe solution that doesn't cause any alteration or modification to the original data. It keeps the DBX files intact or untouched during conversion. By using its demo version, you can save first 25 email messages of each selected DBX folders into new PST files.
Thanks and best regards.
Hi,
My Name is Virat and I am an IT professional from Newyork.
Converting your DBX files to PST is quite complicated. So I would suggest you to go for DBX To PST Converter from SysInfo.
It's a renowned name in this sector and I have used some of their tools too.
And trust me, I liked it.
Canno't compare with others as I have been their fan due to their simple UI and also for their accrate results. Their tools are quite reliable.
You can check out their reviews. Plus can download their demo version before using their full version.
Hope it helps.
Regards
Virat
If you are looking to convert DBX file then try the latest solution DBX to PST Converter by which you can convert your DBX file to PST format in few seconds. It supports all the version of MS outlook. It is the best utility which you can easily migrate your unlimited data DBX to Outlook PST format without any technical issue.
Download now:- http://zook-dbx-to-pst-converter.soft32.com/
Use perfect solution and easily convert to Outlook Express email files to an Outlook email file format. If you like to transfer Outlook Express DBX file data such as: messages, contacts, calendars, appointments and other items into in an Outlook PST file format then here I am recommending a blog post that will elaborate you how to convert and export Outlook Express email from DBX to PST in all windows version. See: DBX to PST Converter Tool
Best solution to easily repair and convert OST data into Outlook by taking OST to PST Converter which is great solution which has much capacity to Convert OST File
to PST file after repairing corrupted/ damaged OST File. This software let you Restore OST to PST, EML, MSG and HTML formats. By taking help of this software you can
Split large PST File into Small PST File 1 GB to 5 GB.
Now from here you're going to know how to safely perform mail migration between two widely usage email client application: Outlook Express and Outlook. Here's introduction of DBX to PST Converter tool which will help email user to access the information of Outlook Express in an Outlook email application. If you are looking to access email information of Outlook Express such as their messages, contacts, calendars, appointments from their inbox, sent, draft items folders in Outlook application where PST is the medium of email then have a look at: DBX to PST Converter
Whynot you try manul method for this? As it is easy and effective too..
You may follow this step by step process
Open Microsoft Outlook.
Open Windows Live Mail.
In the Windows Live Mail window, click the File button and select Exportand then select Email messages.
Select Microsoft Exchange as the format and then click Next.
You will see a message that all email will be exported to Microsoft Outlook or Microsoft Exchange, click Ok to continue.
You can export all email folders or select the appropriate folders that you want to export by using the Select folders option.
After you select the appropriate option, click OK and wait for the export process to be completed.
When the Export Completedialog box appears, click Finish.
Note: This process can take some time , depending on the number of messages that you are exporting.
Courtesy: EasyTechTools Blog: Convert DBX to PST Format
Hope this manual process works. But if it doesnot work the you may checkout this DBX To PST Converter from SysInfoTools.
Thanks and Regards​​   ​​​
There is no direct method to import Outlook express to Outlook. You have first export DBX file to WLM, then import the exported DBX file on WLM and last export it to Outlook.
To avoid the long and lengthy process as you are asking for the go for third party tool the directly converts DBX file to Outlook PST. The best DBX to PST Converter that can easily migrate DBX files to Outlook and allows users to split resultant PST file into small PST files and also performs the batch DBX file to PST Conversion.
For More Visit:  https://gallery.technet.microsoft.com/Process-to-Import-OE-to-ca42e869
In the Windows Live Mail window, click the File button and select Export and then select Email messages.
When the Export Complete dialog box appears, click Finish.
Or else you can try DBX To PST Converter Tool for the flawless conversion of DBX To PST Conversion.
Use the DBX to PST converter or manual tricks for the conversion of DBX to PST.
1. Manual tips- The manual technique is for those users who are looking for free solution to convert DBX to PST manually with the simple steps. To know the manual techniques visits here: Manual steps of DBX to PST
2. DBX to PST Converter software- DBX to PST Converter tool is a professional tool which is used to convert DBX to PST without any losing of original DBX file data. This DBX to PST converter tool is also used if your DBX file is not opening and wants to repair it fast.
Download DBX to PST Converter to Move From Outlook Express to Outlook 2016, 2013, 2010, 2007 for free.  The software supports batch conversion of Outlook Express DBX files to Outlook in quick time. It automatically locates dbx files from local storage. The DBX Converter wizard can also convert DBX files to Outlook PST, EML, MSG, and MBOX file format as well. Download DBX Converter Software for free.
DBX to PST converter is a tool which can effortlessly migrate your DBX documents into outlook PST without problems. It is a not unusual record format in order that most of the customers need to get right of entry to it via outlook that is commonly used email customer. This software program deals with the email messages and file attachments in DBX file layout to transform them into PST format easily with none records loss.
