Convert your NSF file into PST file with the simple and useful manual method that provide the step by step valuable tips to transfer all the data from the NSF file into PST file without changing the original content of NSF file .
To know or learn the manual steps visit: Manual technique to convert NSF to PST
Quickly switch MS Outlook from Lotus Notes email client by simply using of NSF to PST converter software. It's a smart application that enables you to export NSF data like email messages, attachments, contacts, notes, appointments, tasks, etc. to PST format. This tool is compatible with Lotus Notes version 6/7/8/9.8/9.0.1 and MS Outlook 2016/2013 /2010/ 2007/ 2003/ 2002/ 2000/ 98/97.
See more -  http://www.nsfpst.org/
You need an advanced solution for conversion of Lotus Notes NSF file database into Outlook PST and other file format, then I suggest you to use the technique which gives the accurate conversion result. I share a finest solution that import NSF file mailbox into PST with complete existing folders with exact format. It enables to open NSF file into PST within seconds.
Learn more details, here:- Export Lotus Notes Email to Microsoft Outlook
By using Converting software like NSF to PST converter, you can easily convert NSF to Outlook PST files.  You can also go by the manual method, Follow EasyTech Tools Blog. Manual way become a bit lengthy as only one file is import at one time and NSF to PST converter tool provides the functionality of batch conversion of NSF files to Outlook PST files. A free version of this tool also available.
Use suitable Lotus Notes to Outlook PST Converter tool to migrate your all NSF mailbox data (emails, contacts, attachments, calendar, journals etc.) to Outlook PST format.By Using this software also let you perform selective conversion of Notes mailbox data. You can save the mail items folder as PST, MSG or EML files. It also well supports all versions of Lotus Notes, MS Outlook and Windows platform. User can get more information, visit from: http://www.dominotoexchange.org
If you're looking for a free solution to convert NSF to PST format, you can try an easy manual trick. Since Outlook doesn't support NSF database format, you just can't import or export NSF database directly to Outlook client. There's no manual trick that can help you convert NSF to PST format. But you can save NSF files' data into any such format which is supported by Outlook client. Luckily Lotus Notes provides you two file formats into which you can save your NSF files' data: Comma Separated Value and Structured Text. After that, you can easily import the new file into Outlook client by using its Import feature. Refer to this blog post for more information - Export Lotus Notes Email and Other Data to MS Outlook
Thanks and best regards.
To perform Lotus Notes (NSF) to PST Conversion then try some manual technique before using NSF to PST converter tool. There are two manual techniques for NSF to PST conversion.
1. Import/Export Method
2. Setting up Co-existence
If you want the complete details about both these methods then visit here:  How to convert NSF to PST
When you viewing to convert your important data from NSF file to PST format, then you must go with the best tool NSF file to PST converter software which can successfully convert all data from NSF file into PST file and other new robust readable formats like MSG, EML, MBOX, CSV, HTML, and EMLX with initial data. It facilitates its user to convert address book into multiple formats. You must try to use this software once.
Get more information:
http://www.bulkecommerce.com/store/nsf-to-pst-converter-153.html
You can go for http://www.dominotoexchange.org and download NSF to PST Converter tool to successfully migrate your all NSF mailbox data email messages, contacts, tasks, notes, appointments, images, attachments, etc.The software converts unlimited NSF files to PST files.
Supported Platforms
    Lotus Notes- 6.0, 6.5, 7.0, 8.0 and 8.5
    MS Outlook - 97 and all above versions
    MS Exchange Server- all version
NSF to PST is an unambiguous application to make the conversion of Lotus Notes NSF files to Outlook PST files in an efficient and successful way. The migration is flawless and safe. The tool maintains the data integrity and restores data in original format.
Accessing Lotus Notes data to Outlook email client is became easy task now by using NSF to PST Converter. As there are multiple options to convert NSF to PST files but you require for taking a wise decision for email migration solutions that's really important. Well, go find the Top Three PST to NSF Converter that will be more easy for you to find the best Lotus Notes to Outlook Converter.
Smart NSF to PST Conversion utility to efficiently migrate from Lotus Notes Emails to Microsoft Outlook by converting the entire Domino Server mailboxes to Exchange Server PST files which are importable through Microsoft Outlook. From the Lotus Notes user mailboxes. It also converted mails are saved in EML, MSG, and PST file formats. Download NSF to PST Conversion tool for free to try its performance and preview all the converted items.
Get quick and safe conversion solution to convert your all Lotus Notes NSF file into MS Outlook PST format, with NSF to PST Converter Software. Through this software user can easily migrate all your NSF files data like emails, attachments, contacts, journals, tasks etc to PST file format. The free software also provides many advanced features, you can download this and evaluate the efficiency of the free product. Source link:- https://www.softknoll.com/nsf-to-pst-converter/
If any user of Lotus Notes want to move their all data to Outlook mail client, then it is very necessary to take a help of any professional NSF to PST Converter to migrate from Lotus Notes to Outlook. The software converts Lotus Notes file to Outlook importable PST file and provides option to save the mail items folder as PST, MSG or EML files. Go through: http://download.cnet.com/SoftKnoll-NSF-to-PST-Converter/3000-2369_4-77811072.html
It is better to use third-party software like Enstella provides its Lotus Notes Converter Software which is capable to do this task in fraction of seconds. It not only converts NSF file to PST file but also export into EML, MSG, HTML, MHTML, PDF, MBOX many more formats. You may use several other options like Export Lotus Notes contacts in VCF format and can  split large PST files upto 5GB to smaller files.
For further information please visit -> http://www.enstella.com/blog/2017/10/23/lotus-notes-nsf-to-pst-converter-software/
NSF to PST conversion becomes a necessity if you’re migrating from Lotus Notes to Outlook. They both are popular email client applications but use different file formats to store mailbox data such as Lotus Notes uses NSF and Outlook uses PST in Outlook. You can’t export your emails from Lotus Notes to Outlook directly without converting NSF to PST format. Luckily, it migrates from Lotus Notes to Outlook. Know more at: https://www.datavare.com/software/nsf-to-pst-converter-expert.html
As mentioned above there are many solutions for the conversion of NSF to PST. But here I would like to recommend you another solution named NSF to PST Converter Tool which safely converts NSF to PST without tempering any content. This software converts to multiple formats such as NSF to PST, NSF to EML, NSF to EMLX, NSF to MBOX and NSF to MSG. NSF to PST Converter also has a free trial version and good technical support team. For more info. Visit here - http://www.osttopstapp.com/nsf-to-pst.html
