djdanby Posted December 27, 2015 Report Share Posted December 27, 2015 I have found a bug. I can not see seconds after boot. See Attach File. Wise Care 365 - 3.9.3. Pro Windows 7 Enterprise X64 Link to comment Share on other sites More sharing options...
xilolee Posted December 27, 2015 Report Share Posted December 27, 2015 Hi djdanby. That has been solved by WiseCleaner Team in the next version (3.9.4). Link to comment Share on other sites More sharing options...
djdanby Posted January 3, 2016 Report Share Posted January 3, 2016 Ok. Thanks for the Info Link to comment Share on other sites More sharing options...
doggie007 Posted January 10, 2016 Report Share Posted January 10, 2016 You should do this ... Dramatically increase the status of Defrag module, update its GUI appearance and func. and speed! it looks very ugly on that moment, now. off-topic here: How would you compare Wise Care 365 versus Glarysoft Glary Utilities? Link to comment Share on other sites More sharing options...
doggie007 Posted January 10, 2016 Report Share Posted January 10, 2016 I value program's Registry Cleaning module. Link to comment Share on other sites More sharing options...
bluedraft Posted May 24, 2016 Report Share Posted May 24, 2016 Hi, any chance to add a service manager/editor and the ability to apply profiles to enabled/disable various services at once like in advanced uninstaller? Thanks in advance for any reply, best regards. Robertthaps, Jeffreyvup, Titan3J and 26 others 29 Link to comment Share on other sites More sharing options...
WiseCleaner Posted May 25, 2016 Report Share Posted May 25, 2016 Hey bluedraft, Thanks for your suggestion. Actually, wise care 365 has already included services manager, you can see it in System Tuneup -> Startup manager. Link to comment Share on other sites More sharing options...
bluedraft Posted May 25, 2016 Report Share Posted May 25, 2016 Thanks but it's like the one the comes with windows, I mean there is no option to save or apply profiles. Link to comment Share on other sites More sharing options...
WiseCleaner Posted May 26, 2016 Report Share Posted May 26, 2016 Hey, "I mean there is no option to save or apply profiles"? Sorry, I can't understand it. Can you tell me more details? Link to comment Share on other sites More sharing options...
xilolee Posted May 26, 2016 Report Share Posted May 26, 2016 I think he probably wants something like profiles in windows xp... Removed in windows vista onwards. An user could create more profiles, with different services configurations (see blackviper.com). Link to comment Share on other sites More sharing options...
bluedraft Posted May 27, 2016 Report Share Posted May 27, 2016 I never used vista, so I really can't tell, but I was talking about enable/disable various services at one and save that configuration as a profile so in case of a clean os installation or similar scenarios you can enable/disable those services by applying the profile you previously saved. Its really handy and it saves time. You can see this function in programs like advanced uninstaller where you have predefined profiles (minimal, safe, gamer) and also can create your own profiles, also there are apps that are exclusively dedicated to "optimize" services like "easy service optimizer" and "kickstart", in these cases the profiles are only predefined by the authors if I remember well, you can check them, both are free and portable. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 27, 2016 Report Share Posted May 27, 2016 Okay, understood. Thanks for your suggestion, I will send it to developer team. Link to comment Share on other sites More sharing options...
djdanby Posted July 29, 2016 Report Share Posted July 29, 2016 Hi, i have found a new old bug. I can not see Boottime :-/ Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 2, 2016 Report Share Posted August 2, 2016 hey djdanby, which version did you use? Link to comment Share on other sites More sharing options...
djdanby Posted August 4, 2016 Report Share Posted August 4, 2016 hey djdanby, which version did you use? Version 4.23 Link to comment Share on other sites More sharing options...
djdanby Posted August 4, 2016 Report Share Posted August 4, 2016 And another problem with Version 4.23. This message popup at irregular intervals. And although my PC has been around for hours. Link to comment Share on other sites More sharing options...
xilolee Posted August 5, 2016 Report Share Posted August 5, 2016 Does Wise boot booster appear at irregular intervals? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 9, 2016 Report Share Posted August 9, 2016 Hey djdanby, 1, Please open wise care 365 folder, normally it is C:\Program Files (x86)\Wise\Wise Care 365 if you are using a x86 system, the location is C:\Program Files\Wise\Wise Care 365 2, Find the file BootTime.exe and WiseBootBooster.exe, 3, Right clik the file and select Proteries - Details, then tell me the File version. Thanks. Link to comment Share on other sites More sharing options...
djdanby Posted August 11, 2016 Report Share Posted August 11, 2016 BootTime.exe File Version: 1.1.1.47 WiseBootBooster.exe: 1.7.4.78 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 12, 2016 Report Share Posted August 12, 2016 Thanks. These two files are latest. we will check them. It can't display the boot time only once? or every time you start PC? Link to comment Share on other sites More sharing options...
djdanby Posted August 16, 2016 Report Share Posted August 16, 2016 Every time I have never seen a Number. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 17, 2016 Report Share Posted August 17, 2016 Well. 1, When you use previous version (4.21, 4.19, or earlier), does it display the time? 2, What is your system, Win 10/8/7/vista/xp, 32 bit or 64 bit? Thanks. Link to comment Share on other sites More sharing options...
djdanby Posted August 26, 2016 Report Share Posted August 26, 2016 I can not test it. I have no older version of WC365 :-/My System is Win 7 Enterprise x64 Link to comment Share on other sites More sharing options...
xilolee Posted August 26, 2016 Report Share Posted August 26, 2016 Hi WiseCleaner_Admin! (Ivan!) I just want to bring again to your attention the old problem with the slimming system function on windows 7 OSs. When using the slimming system, some files will be marked as missing/deleted/corrupt by MS SFC tool (sfc /scannow). Hence the guys that help to fix SFC problems will put a bad reputation on your programs (all of your programs, the entire company). Given that I think that's not fair, I suggest you to fix that problem... Topics that show the bug: http://forum.wisecleaner.com/index.php?/topic/3090-wdc-affecting-sfc-scannow-results/ http://forum.wisecleaner.com/index.php?/topic/4561-system-slimming/?hl=%2Bwindows+%2Bslimming+%2Bsystem Link to comment Share on other sites More sharing options...
djdanby Posted August 28, 2016 Report Share Posted August 28, 2016 The Boot Time is coming back with new Update. Thank u Link to comment Share on other sites More sharing options...
