xilolee Posted June 13, 2014 Report Share Posted June 13, 2014 New italian.ini (updated the 13th of June 2014, remove .zip only) italian.ini.zip Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 17, 2014 Report Share Posted June 17, 2014 Thanks xilolee. Link to comment Share on other sites More sharing options...
xilolee Posted June 17, 2014 Report Share Posted June 17, 2014 Newer italian.ini (updated today) for wise care 365 3.12.271 italian.ini.zip Link to comment Share on other sites More sharing options...
Jayzx Posted June 19, 2014 Report Share Posted June 19, 2014 Nice change on WC 365 v.3.12 Can the "Clean out the memory xx.xMB" be displayed for atleast 2 seconds? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2014 Report Share Posted June 19, 2014 @Jayzx, This report window will be displayed 3 seconds. Link to comment Share on other sites More sharing options...
jstalewski Posted July 11, 2014 Report Share Posted July 11, 2014 Odd message from WiseCare 3.1.3 today: "Your computer hard working to create many of junk files for you" Is this legitimate or has the computer been compromised? It reads like a bad English translation of a Chinese user guide. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 14, 2014 Report Share Posted July 14, 2014 Thank you for your suggestion. We will modify it asap. Link to comment Share on other sites More sharing options...
tipstir Posted July 14, 2014 Report Share Posted July 14, 2014 Need to add network devices (files, folders , drives) from network server device (aka node) like NAS (network attached storage). Also those USB HDD that can be connected to NAS thus be on your network to gain access to the files when using the JetSearch plugin. I could really use this program if it had network support instead of just the local PC file system. Link to comment Share on other sites More sharing options...
xilolee Posted September 9, 2014 Report Share Posted September 9, 2014 Newer italian.ini for wise care 365 3.23.281 (a.k.a 3.2.3) (I've added .zip to the italian.ini, but it's not really zipped) Italian.ini.zip Link to comment Share on other sites More sharing options...
xilolee Posted September 30, 2014 Report Share Posted September 30, 2014 Tipstir's feature requests: Here are a few things I don't see in the most current version of Wise Care 365 V3.2.5. 1. Optimize MFT 2. Chkdsk (Check Disk for Errors) Thanks in Advance! Link to comment Share on other sites More sharing options...
payne Posted November 25, 2014 Report Share Posted November 25, 2014 buon prodotto facile da usare senza troppi applicazione confusionarie Link to comment Share on other sites More sharing options...
payne Posted November 25, 2014 Report Share Posted November 25, 2014 anche un modulo di riparazione FILE DLL, Link to comment Share on other sites More sharing options...
payne Posted November 25, 2014 Report Share Posted November 25, 2014 Hello everyone I am a new user Italian, for many years use Advanced SystemCare and I was fine in his work, I must say that from version 5 onwards have added too many applications confusing. your program Wise Care 365 is much more intuitive and easy screen with the right apps to use. the program and very good and is working without a council to improve the engine cleaning junk files, especially that of the register strengthening it. last advice and add the application to fix DLL.nessun such program I offer this service in the various integrated suite of optimization ones pc greetings to all: D Link to comment Share on other sites More sharing options...
payne Posted November 27, 2014 Report Share Posted November 27, 2014 add in cleaning the elimination of empty folders and files cloned Link to comment Share on other sites More sharing options...
Linkin Posted November 28, 2014 Report Share Posted November 28, 2014 add in cleaning the elimination of empty folders and files cloned Thank you so much for your advice, I have reported this to the tech team. Link to comment Share on other sites More sharing options...
payne Posted November 28, 2014 Report Share Posted November 28, 2014 I am happy to help ..The program shows very well and does a good job, in addition to the advice already given memory improvement in cleaning the junk files and registry and repair missing DLL,for future projects do not recommend to integrate a spyware scanning as do many super utility, I find it useless and superficial RichardGora, DavidBix, iapedJet and 37 others 40 Link to comment Share on other sites More sharing options...
payne Posted December 1, 2014 Report Share Posted December 1, 2014 the program has a good defrag engine, suggest you add the boot file defragmentation and file maping during system startup rgrun1 1 Link to comment Share on other sites More sharing options...
payne Posted January 3, 2015 Report Share Posted January 3, 2015 . Link to comment Share on other sites More sharing options...
Jayzx Posted January 23, 2015 Report Share Posted January 23, 2015 I noticed that in Wise Care 365 v3.43 Link to comment Share on other sites More sharing options...
xilolee Posted January 23, 2015 Report Share Posted January 23, 2015 I see it correctly... OS? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 26, 2015 Report Share Posted January 26, 2015 How did it appear? You open wise care 365, click system cleaner, click common cleaner, Scan, then you got this? Did you done other special operation? Link to comment Share on other sites More sharing options...
xilolee Posted January 26, 2015 Report Share Posted January 26, 2015 Ok i found how to reproduce it: 1) go to system cleaner - common cleaner 2) open some sections, just to make appear the scrollbar (you can do this also after the scan) 3) click scan and wait till it finishes 4) scroll If you open all sections and scroll down to the max, all sections will be moved to the right. Wise Disk Cleaner seems to work correctly, instead. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 29, 2015 Report Share Posted January 29, 2015 @xilolee Thank you very much! I got it. We will fix it asap. Link to comment Share on other sites More sharing options...
payne Posted January 29, 2015 Report Share Posted January 29, 2015 to further improve the cleaning of the register, a thorough work to eliminate the trace of the driver no longer 'installed on the system and file dll corrupt ... very useful boost this works for those who always updates its hardware with its drivers. as quoted in the past it would be useful to defragment the files ... I quote a mapping notes that before I used advanced system care, cleaning has very deep, but the program is very confusing for options and tools that I find confusing and superficial, especially the function of various Optimisation of the system, wise ones have fewer features and more concentrated with a wild simplified graphic not that the various system optimization ones are almost similar to the product iobit,so great wise Link to comment Share on other sites More sharing options...
Nesivos Posted March 11, 2015 Report Share Posted March 11, 2015 I like the new widget. I would like to make one suggestion regarding it. When the RAM usage exceeds the threshold level set for auto optimizing change the color of the widget to say red. That is it. Nice job. Link to comment Share on other sites More sharing options...
