wisecleaner_admin Posted August 17, 2016 Report Share Posted August 17, 2016 Dear users, We are very excited to announce the release of Wise Duplicate Finder beta! Find & Remove Duplicate File, Photo! Wise Duplicate Finder is a fast and accurate Windows duplicate file & photo finder, it is simple and easy- to-use. 1. Wise Duplicate Finder can help you find specified location duplicate document file, photo, email, video, audio, archive. 2. It provides four compare modes: a. Match filename and size; b, Partial content match; c, Exact content match; d, Only find 0 byte files. 3. It can help you remove duplicate files and only keep one. 4. When you delete duplicate files, wise duplicate finder can auto backup them, you can restore them in any time. Click here for direct download Wise Duplicate Finder beta However, there is still space for improvement for this beta version, please leave a comment or write down the bugs you found below. We would really appreciate that. Thank you! WiseCleaner Team *Release notes* v1.03.15 (2 Sep. 2016) - Improved advanced settings - Added file size and date modified - Minor improvements AnthonyPoelf, nohnigefearot81, nohnigefearxv76 and 25 others 28 Link to comment Share on other sites More sharing options...
ThisIsKurt Posted September 9, 2016 Report Share Posted September 9, 2016 Hi there The Simplified Chinese localization is now available for Wise Duplicate Finder (beta). 简体中文汉化现已可用 Download link (OneDrive): 下载地址 https://1drv.ms/u/s!AtnsLvzQfS6ei8Vj7OmiGFDl77GAGg For future reference, the corresponding version for this localization was 1.0.3.15 when posted.. 此贴发布时,软件版本为 1.0.3.15 PS: 1) The 'Keep One' button is confusing -- It invert selects multiple files if you at first 'Keep One' then 'Invert' then 'Keep One' again; such that it doesn't really only 'keep one'. 2) When the font gets larger than 8, characters in certain locations become no longer fully/properly displayed. Kurt Link to comment Share on other sites More sharing options...
GRomPES Posted September 19, 2016 Report Share Posted September 19, 2016 Проверил на WGet. Всё закачивается, ставится, запускается. Само приложение ещё не тестировал echo WiseDuplicateFinder del "%~dp0WDFSetup.exe" "%~dp0wget.exe" -cN -t5 -T15 "http://www.wisecleaner.com/soft/WDFSetup.exe" -P "%~dp0." "%~dp0WDFSetup.exe" /VERYSILENT del "%~dp0WDFSetup.exe" echo ================================= echo =============THE END============= echo ================================= pause PS: к слову Registry Cleaner и Disk Cleaner не работают через ключ /verysilent. А-та-та Link to comment Share on other sites More sharing options...
jacksotr Posted September 22, 2016 Report Share Posted September 22, 2016 Duplicate document check just completed duplicate check marks to delete WILD TANGENT duplicate games 4 and 5 duplicated of each game. PLEASE put a "DELETE ALL" option to save time and effort to use this new download Link to comment Share on other sites More sharing options...
xilolee Posted September 22, 2016 Report Share Posted September 22, 2016 Hi!!! I'm not able to translate "Match file name and size...", i.e. it is shown in English, and I can't full read it (probably because I'm using a custom scaling level). If possible, implements "hints" (tooltips) for all strings, for this entry. If possible, the hints/tooltips should be automatically got from the related settings. Translators could add more words in the hints later...! ButtonMinimize, ButtonMaximize, ButtonClose, ButtonRestore, don't work (English or Italian), i.e. they don't show the tooltip. frmDFSettings.btnAddFolder.Hint, frmDFSettings.btnAddKey.Hint, frmDFSettings.btnOk.Hint, frmDFSettings.btnCancel.Hint, don't work (English or Italian), i.e. they don't show the tooltip. Imo frmWDFMain.lblcaption.Caption should be bigger. In the about window, I can't fully read "Il nostro sito web" ("Home page"): it works with all your other software (even with my own custom scaling level). Maybe you are using bold or a bigger font size or the entries were reduced, don't know... If you need screenshots, or more explanations, let me know... italian.zip Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 23, 2016 Author Report Share Posted September 23, 2016 Thanks xilolee. We will fixt it shortly. Link to comment Share on other sites More sharing options...
geogeo.gr Posted November 4, 2016 Report Share Posted November 4, 2016 Update Greek translation to WDF 1.15 WDF_greek.zip Link to comment Share on other sites More sharing options...
geogeo.gr Posted July 25, 2017 Report Share Posted July 25, 2017 Update Greek translation to WDF 1.21 WDF_greek.zip Link to comment Share on other sites More sharing options...
Meisterfleister Posted December 14, 2017 Report Share Posted December 14, 2017 Hello. I have got a humongous .bak file in C:\Users\[me]\AppData\Roaming\Wise Duplicate Finder 12,5GB!!! Why is this file still here? Why do I need it? Is the program waiting for me to close it? (a bug?) I have not touched this program in months. But this file is eating half my C-drive!! Can I kill it without killing the program? Is it a search duplicate of my pc/a partition? If so, why is this program DUPLICATING files instead of just pointing to them? All my space is gone, lol.. I will not delete it if it means I kill files that should not be killed. But 12,5GB in a roaming folder= Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 15, 2017 Author Report Share Posted December 15, 2017 Hi Meisterfleister, These are backups that files you have deleted. If you are sure don't need them again, you can delete them. Also, you can disable auto-backup option. Link to comment Share on other sites More sharing options...
Meisterfleister Posted December 16, 2017 Report Share Posted December 16, 2017 Thank you for the info and reply. I was wondering about another option since for now I don't have the time to look at every file, yet at the same time I want my space back, as well as not deleting files (because deleting can harm) Can I move the 15GB bak file to another partition? Or does the program only look at C when looking for this backup bak? (I could move it 2 times ofcourse ). (If the program only sees C drive for this bak, maybe something for the next update, but my bet would be I can search the whole pc already ) Now I use file shredder to kill files. It 3x overwrites. So this 15G loses 3 points/bit. (got a WD black) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 18, 2017 Author Report Share Posted December 18, 2017 HI, Yes, you can change the default folder to another partition. or, you can move these files to another folder, then change the backup folder to this new one. Link to comment Share on other sites More sharing options...
alakfd Posted March 26, 2018 Report Share Posted March 26, 2018 Hi great tool! thx 1. Is it possible to show dates with time? (hour:minute:second, not only days) 2. is it possible to export the same columns as the application shows, and even more? (Id of group of the same files; Size in bytes; Creation date with seconds precision, not only Modification) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 28, 2018 Author Report Share Posted March 28, 2018 Hi alakfd, Current version, it already display date and time. If you didn't see it, please give me a screenshot. About export function, I will send it to developer team. Link to comment Share on other sites More sharing options...
xilolee Posted September 1, 2018 Report Share Posted September 1, 2018 Hi! The program currently doesn't detect the new version: I'm using 1.2.5.27. I'm going to update it to 1.2.8. Link to comment Share on other sites More sharing options...
geogeo.gr Posted September 18, 2018 Report Share Posted September 18, 2018 Update Greek translation to WDF 1. 28 WDF_greek.zip Link to comment Share on other sites More sharing options...
Roselinea Posted February 8, 2020 Report Share Posted February 8, 2020 Hi there, I have a question about Wise Duplicate finder, how can you tell that it has worked and has deleted the files? I don't receive a notification, so I am unsure if it has worked or not? Thank you Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 10, 2020 Author Report Share Posted February 10, 2020 That is a good question. In the current version (1.35), Wise Duplicate Finder doesn't show a report (or a message) that the deletion is finished. But, the scan result will refresh after deleting. I will forward your question to the developer team. Maybe they can improve it in the next version. Link to comment Share on other sites More sharing options...
xilolee Posted January 5, 2021 Report Share Posted January 5, 2021 Hi! FrmWDFMain.btnKeepOne.Caption=Keep one In the interface, it is in bottom-left corner (after a search). What should it do? Currently, it opens the register window. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 6, 2021 Author Report Share Posted January 6, 2021 @xilolee Keep One is only valid for PRO users. Your license key has been updated, and sent to your mailbox, please check the inbox and the spam folder. Link to comment Share on other sites More sharing options...
xilolee Posted January 6, 2021 Report Share Posted January 6, 2021 Thank you! Anyway, I think (for an user that uses the free version) it would be better to open a message box saying "This feature is available in the pro version". In the registration form, I wasn't able to use the paste function (with the right-click) and I wasn't allowed to write @ (in the email entry). The same happened with WRC and WFH. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 7, 2021 Author Report Share Posted January 7, 2021 @xilolee Thanks for your feedback. We will fix it in the next updates. Link to comment Share on other sites More sharing options...
