MBOX to PST is very difficult task for all the users who are migrating MBOX file data into PST file, but it can be easy if you have reliable solution to use, sometime the data might get corrupt or damage due to hardware and software problem, improper shutdown of system and viruses infection. In such situation use the MBOX to PST Converter tool, which complete scan the corrupt MBOX file for error and recover it very fast and also save their MBOX file into PST, MSG, EML, HTML and RTF formats. This tool also change the MBOX file of many email clients application like- AppleMail, OperaMail, Sylpheed, Entourage, Thunderbird, Eudora, Spicebird etc. into PST file.
See more: MBOX to PST Converter tool
MBOX to PST Converter tool is ultimate solution for converting your MBOX files into Outlook's PST. Besides conversion, it can save MBOX file's data to various popular file formats, such as: EML, MSG, RTF and HTML. This tool works well to convert MBOX to PST even if the MBOX files are corrupted or inaccessible. It supports MBOX files which are created in any of these programs: AppleMail, OperaMail, Sylpheed, Entourage, Thunderbird, Eudora, Spicebird, etc.
Manual method to Convert MBOX to PST-: Manual for MBOX to PST
Try for free the demo version:- MBOX to PST Converter
You can easily transfer your MBOX file into Outlook PST file by MBOX to PST Converter Software and by manual tricks. The manual trick is simple to use but it take lots of time to convert MBOX file into PST file and it also consist of manual steps. If you want to learn or know the manual steps then visit the link: Manual trick to convert MBOX file to PST file.
Migration of MBOX to PST format is always a big task for every users. Now, it is easy for users to switch their MBOX format to PST format by using the best utility ZOOK MBOX to PST Converter. It is easy to use application which can easily extracts the multiple MBOX files to PST format instantly in few seconds. By using this special tool users can easily convert their MBOX files created by any email clients and import it to MS Outlook by converting it into PST format.
For More Info: - http://download.cnet.com/Zook-MBOX-to-PST-Converter/3000-2369_4-77406229.html
To do the email conversion job from saved .MBOX environment to PST format or MS Outlook, use the simple to use MBOX to PST file converter tool. It will helps you to convert all your saved MBOX emails in PST format without any loss of data.
Get the tool from here - https://www.softwaresuggest.com/softtweak-mbox-to-pst
For MBOX to PST conversion, one can try Mail Extractor Pro (Works on Mac Only).
It can convert Apple Mail, Thunderbird, Postbox, MBOX file to PST file format. With it you can easily convert / import mbox to Outlook 2016 / 2011 for Mac and Outlook 2016 / 2013 / 2010 / 2007 / 2003 for Windows.
You get more detail at http://www.mailextractorpro.com/
Try Mail Passport Lite (for MS Windows)
It helps you in converting MBOX / EML to PST files for Outlook and lead you hassle free migration for converting your mail database between these file format.
One can also use its PRO version for Converting MBOX/ EML/ THUNDERBIRD/ POSTBOX/ ENTOURAGE/ Apple Mail Database/ Apple Mailbox to PST For Outlook 2016/2013/2010/2007/2003.
For more : http://www.mailpassportlite.com
Instead of using a paid converter utility for MBOX to PST conversion, you should try an easy manual trick first. It requires no third-party paid tool or any cost. You can use the manual trick only if you're using Apple Mail client. I can share a blog post below that contains the detailed information about MBOX to PST conversion manually: MBOX to PST Manual Conversion – An Easy Tutorial | N. Sem's Blog
I hope the shared information would be helpful here. If the manual trick fail or doesn't work, then only you should try a professional MBOX to PST Converter tool. It can convert MBOX files into PST format without causing any alteration to the original data. You can use this software even if your MBOX files are corrupt. First you should download its free demo version which helps you save first 25 email items of each mailbox folders of MBOX file into new PST file.
Thanks and best regards.
Above suggested solutions are good for converting mbox file type to Outlook PST format. But I would like to add one more suitable MBOX to PST conversion tool that will be more effective compare to others. The software allows converting multiple MBOX files to single or multiple PST files and also allows to save individual messages as well as attachments. To get more details kindly visit this URL: http://www.mailsdaddy.com/mbox-to-pst-converter/
MBOX to PST Converter tool allows you to convert MBOX files into PST formast seamlessly and with utmost accuracy. This tool even allows you to convert MBOX files into other formats as well like EML, MSG, RTF and HTML. This tool supports all email clients using MBOX formats like: Thunderbird, Entourage, Spicebird, Netscape, Incredimail, ClawsMail, Pocomail, AppleMail, OperaMail, MozillaMail Eudora, Evolution, Sylpheed , Mulberry, SeaMonkey, etc.
Futhermore, this tool lets you recover data from any corrupt MBOX file. The tool allows you to preview the recovered or converted data before saving and is compatible with all Windows OS upto Windows 10.
To learn more about this tool, visit: https://www.sysinfotools.com/recovery/mbox-converter.php
Excellent MBOX to PST Converter that will help you to convert MBOX saved email, messages, contacts, calendars, appointments and other data items from their Entourage, Thunderbird, Spicebird, Apple Mail, Pocomail, Netscape, Incredimail, ClawsMail, OperaMail, MozillaMail, Evolution, Eudora, Sylpheed, Mulberry, SeaMonkey, etc. email clients application to an Outlook PST, EML, MSG, RTF, etc. file format
MBOX Converter tool is one of the reliable conversion applications, which is capable to import MBOX files into Outlook including all emails, emails formatting, metadata and attachments. MBOX Converter tool, which helps you to convert batch MBOX files to Outlook PST in one process with no issue.
Thunderbird to Outlook conversion via easy manual solution is secure, reliable and easy-to-use that transfer MBOX files of Thunderbird, Spicebird, Entourage, Pocomail, Eudora, Mulberry, Opera Mail, Mozilla Mail, Netscape, etc to PST file format. It effectively moves all mailbox data of these mail clients and all emails from MBOX files to equivalent Outlook PST files. It converts mailbox data to new or existing PST file.
If you are facing all kinds of difficulty with migrate mbox file to pst format, then you can take help of MBOX to PST converter software to easiest way to migrate all mbox file cratered by email clients including AppleMail, Entourage, PocoMail, Netscape, Postbox, Eudora, Spicebird, PowerMail, Claws Mail, Evolution, Thunderbird, Opera, GyazMail, Gnu, SeaMonkey, Sylpheed, Mulberry, Sparrow and The Bat! into PST and MSG format. Read more : http://www.mboxtopst.mergepstpro.com/
There is another amazing software also available in online to migrate your MBOX file to PST format. I like to suggest you to use of third party MBOX to PST Converter tool to successfully migrate all MBOX files created by multiple email clients like Mulberry, Evolution, Entourage, Apple Mail, PowerMail, Spicebird, Claws Mail, Eudora, SeaMonkey, Sylpheed, Netscape, and etc. The software provides user to save MBOX data in different format like PST, MSG, EML, TXT, RTF, HMLT, MHTML, PDF, DBX. Read more: http://www.mboxtopst.org
Hi Paul Richard
I would like to suggest you MBOX to PST converter tool to make the conversion of MBOX files to PST file format easy, this software provides easy GUI so any technical and non technical person can operate this utility with ease & effectively convert MBOX to PST, EML, HTML, RTF and MSG files formats without any data loss.
Hope this will help you!
Thanks
Regards
Marco
Thunderbird to Outlook PST Converter is the perfect solution to convert MBOX files to PST format. With this software, you can convert multiple MBOX files to PST format at once. It allows saving the resultant PST to the desired location. This software also provides different file naming option. With this feature, users can name the file as per their desire. For more details kindly visit:- http://www.outlookconverter.net/mbox-to-pst
If you are looking for a solution that easily converts all the MBOX files to PST format then use MBOX to PST Converter. This software allows the complete conversion of your MBOX files. With this effective solution, you can easily convert an unlimited file. This software is able to convert multiple files at once via Batch conversion option. Visit:- http://www.mboxtopst.filefixutility.com
If you are using Mac os then use MBOX to PST Converter tool. Yes, free versions are available but have some limited features over purchased Softwares. Here I want you to refer MBOX Converter to export your MBOX file into Outlook. The free version of the tool can export some of your emails to PST. You can also purchase the software from the official site. Visit here to download the free version:- https://www.mailvita.com/mbox-to-pst-converter-for-mac/
If you are looking a relaible and secure conversion tool for converting mbox to pst format. then use MailsDaddy mbox to pst converter ,this is the best GUI based application and produce a compatible PST format for MS Outlook. you can export all mbox data at once by using Bulk Export option and make seperate or single PST file for all mbox data.
i found this tool on filehippo website: https://filehippo.com/download_mailsdaddy-mbox-to-pst-converter/
With this tool, you can effortlessly convert mbox to pst and other formats like EML, MSG, HTML etc.
