vag32 Posted September 14, 2016 Report Share Posted September 14, 2016 Hi, My Windows 7 is encrypted with VeraCrypt, but I think because of real time protection may have affected an encrypted partition. Well, I had to perform a restore and this partition would not open without the Wise installed received a message that is "System Event Notification Service" can not be started. Does "real time protection" function could be affected? Anyway it came only happen when installed Wise Care. sizekani, yapedJet, GregoryWak and 12 others 15 Link to comment Share on other sites More sharing options...
xilolee Posted September 15, 2016 Report Share Posted September 15, 2016 Hi vag32. :-) I'm not sure to have understood you (maybe yes, maybe not).You can find blocked or allowed applications by WiseCare365 "Real-time System Protection" in config_tray.ini, under [APPFILTER].I'm using the portable version and I have that file in Wise Care 365 portable folder.I think if you're using wise care 365 installed version, that file could be in its installation folder. Example ( allowed have =1 at the end): [APPFILTER]C:\Windows\System32\wbem\WmiPrvSE.exe=1D:\Applicazioni\Emsisoftemergencykit\BIN64\a2emergencykit.exe=1C:\Program Files (x86)\MBAM\mbam.exe=1 Link to comment Share on other sites More sharing options...
vag32 Posted September 16, 2016 Author Report Share Posted September 16, 2016 Hi vag32. :-) I'm not sure to have understood you (maybe yes, maybe not). You can find blocked or allowed applications by WiseCare365 "Real-time System Protection" in config_tray.ini, under [APPFILTER]. I'm using the portable version and I have that file in Wise Care 365 portable folder. I think if you're using wise care 365 installed version, that file could be in its installation folder. Example ( allowed have =1 at the end): I'm now using only the portable version without Real Time Protection enabled. Until the moment, everything is fine. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 18, 2016 Report Share Posted September 18, 2016 Thanks xiolee. @vag32, I'm not sure your problem is caused by system protection. I did a test in the virtual Windows 7 (vmware workstation 12, Windows 7 32bit), install VeraCrypt 1.18a, then Encrypt the system partation or entire system drive - Normal - Encrypt the whole drive - Encryption of host protected area (No) - Single-boot - Encryption options (AES, SHA-265) - set password and use PIM But, everything is okay. If you don't want to use system protection, you can disable it. Link to comment Share on other sites More sharing options...
vag32 Posted September 18, 2016 Author Report Share Posted September 18, 2016 Hi,I'm using it as a portable version now for preocaução and with system protection turned off. Ah! How to use portable, if you have an update you need to install locally in order to regenerate the portable version?Thank you very much Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 19, 2016 Report Share Posted September 19, 2016 Yes. Or, you can download the lates portable version from http://downloads.wisecleaner.com/soft/WiseCare365.zip Link to comment Share on other sites More sharing options...
