James Britton
Get VHD Recovery Tool
If you can create VHD or Virtual Hard Disk files then you can also repair them when they becomes damaged. VHD file which is created by Disk Management feature and saved in Physical Hard Disk Drive when gets damaged then it need recovery so that user can re-get all the major data which they had saved in file. So here is advance solution that you should take whenever have corruption on your VHD file. See more: VHD Recovery Tool.
Kernel for VHD, a powerful and the most effective third party data recovery tool to recover complete data from corrupt or damaged VHD files. The tool is designed with an advanced algorithm to recover complete data in quick time and without any hassle. Kernel for VHD tool is embedded with three scanning modes - quick scan, extensive scan and file trace. For more information about the working of the scanni8ng modes, visit: http://www.vhdrecoverytool.com
or http://www.en.virtualdiskrecovery.com
VHD (Virtual Hard Disk) is a document arrangement which speaks to a virtual hard circle drive (HDD). This is composed basically to be utilized by virtual machines. It frequently contains the same hard drive areas found on a physical hard drive, for example, plate parcels and a document framework.
VHD recovery tool is equipped for reestablishing VHD files, which are harmed because of any reason. You want to repair your corrupted VHD file and restore all the essential data You can visit here: https://www.sysinfotools.com/recovery/vhd-recovery.php
There are many software vendors in the market which provide VHD repair or recovery tools. But before you can purchase any such paid software, you must try a couple of manual tricks to repair VHD file. They require no paid software or any other cost.
  • You can repair VHD file by running script on Windows PowerShell that will help you mount the VHD file in the root folder, and then you can run a CHKDSK on it.
  • You can repair VHD file by creating a new Virtual Machine, add the corrupt Virtual disk file to it and then compact it.
You can also try VHD tool, freeware utility provided by Microsoft. It can repair VHD file. You can read this blog post for detailed information - Repair VHD File Manually – Utmost Solutions for VHD Recovery | N. Sem's Blog
If nothing works for you, you should try professional recovery software. Download free demo version of Virtual disk recovery software to repair corrupt Virtual disk files and to recover maximum possible data from them.
Thanks and best regards.
There are few easy manual tricks to repair VHD file which require no 3rd party tool or any other cost.
·         You can run a script on Windows PowerShell that will help you mount the VHD file in the root folder, and then you can run a CHKDSK on it.
·         You can create a new Virtual Machine, add the corrupt Virtual disk file to it and then compact it.
·         Also, you can use VHD tool, provided by Microsoft, to repair VHD file.
If the manual tricks shared in the above blog post fail or don't work, you can try a professional recovery solution. There are many software vendors in the market which provide you such recovery solution.
But the problem is that everyone claims to be the best.
so how a normal user can compare and understand which one is good for them.
For that, I would suggest you to go for this blog.
This blog have mentioned all the best tools available in the market. They have done the research for you.
One of them is PST Recovery Tool.
You may checkout this blog for more details
Link: Best Data Recovery Software
Hope this answer helps
Hello,
If your VHD file is inaccessible and if you want to recover your most valuable data then you can try Hyper-V VHD Recovery Software software. This software painlessly recover VHD file items. This software is smartly programmed to solve the corruption issues of VHD files. It helps to recover most valuable and important data such as documents, images, videos etc.
Here are some of the important features of this software :
1. Recover corrupted / damaged virtual hard disk file.
2. Option to Scan and Recover any size virtual hard disk file.
3. Recover VHD  file items without installing virtual environment.
4. Option to recover data from Dynamic as well as Static Virtual Hard disk files.
Thanks and Regards
Danniel Jones
